Old 10-14-2017, 04:30 PM   #101
Jaysonb
Jaysonb's Avatar
Re: 73 gmc short Sierra Grande C1500
New hood fit up. Now it's apart to start priming, and painting the front end.
Jaysonb is offline   Reply With Quote
Old 10-14-2017, 05:19 PM   #102
Dads79GMC
Dads79GMC's Avatar
Looking great!! Did you end up dropping the rear a bit?
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 10-14-2017, 06:29 PM   #103
Jaysonb
Jaysonb's Avatar
I still plan on it, but haven't got to it yet.
Old 11-06-2017, 01:14 AM   #104
Jaysonb
Jaysonb's Avatar
Slow but sure progress on this old girl! The front end is getting painted tonight, I have the vent windows apart, blasted, painted, and the new seals put in one of them. The firewall insulation pad is in, there are still a few retainers to install there. Had to send the new engine harness back to get reworked a little, I'm hoping to get that back before the fenders are ready to install, as I hate leaning over new paint.
Old 11-06-2017, 02:59 AM   #105
Jaysonb
Jaysonb's Avatar
The hood and fenders turned out pretty good, a little more dust than I like, but it will sand and buff nice. I'm kinda chicken to lay the clear on nice and slick this time of year, the shop is heated, but the service door has to be cracked open when the exhaust fan is on, and it sucks cold air in. I guess a little peel is easier to sand out than a bunch of sags, and runs!!
Old 11-06-2017, 10:45 AM   #106
Dads79GMC
Dads79GMC's Avatar
Yes!! Looks great!
Old 11-07-2017, 10:59 PM   #107
Jaysonb
Jaysonb's Avatar
Hood and fenders mounted up!
Old 11-08-2017, 08:08 AM   #108
flashed
That looks great ,love the color too.
flashed is offline   Reply With Quote
Old 11-08-2017, 01:53 PM   #109
Low Elco
Maaan, that's gonna be gorgeous. Nice work.
Low Elco is offline   Reply With Quote
Old 11-14-2017, 05:51 AM   #110
Jaysonb
Jaysonb's Avatar
I finally got the ac condenser put together, and installed! The last time I worked on it, I was lacking sleep and after putting it together wrong 3 times, I gave up. With that in, I thought I would see how some of the shiny stuff fit. Not bad at all. I have to repaint, and spiffy up the grille a little before that goes in. I decided to go with a color matched bedliner, instead of black, but I think that will be last on the still pretty long list of things to do.
Old 11-14-2017, 05:57 AM   #111
Jaysonb
Jaysonb's Avatar
I also tightened the tilt up, cleaned and painted, and installed the steering column. Does anybody know where that wire goes.......
Old 11-14-2017, 05:59 AM   #112
MrFinland
MrFinland's Avatar
Wow! It looks amazing!
MrFinland is offline   Reply With Quote
Old 11-14-2017, 06:41 AM   #113
Jaysonb
Jaysonb's Avatar
Thank you Sir! I am enjoying watching your build, you guys are doing top notch work!
Old 11-14-2017, 07:17 AM   #114
Jaysonb
Jaysonb's Avatar
It blows me away how much they get to rebuild the vent windows! I was nervous about trying it after reading about how difficult they are to rebuild. There are a few high end specialty tools that make the job pretty easy. A plastic pry bar, and a mini bar clamp. I'm not in a huge hurry, and it seems to take about 25 min.
Old 11-14-2017, 08:49 AM   #115
Jaysonb
Jaysonb's Avatar
All cleaned up and ready to go as soon as the glass frames dry! Very easy to rebuild these.
Old 11-14-2017, 11:19 AM   #116
MTCK
MTCK's Avatar
Great work! Appreciate the intel on the vent windows. I’ve been tripping over a junkyard set for my crew for two years that need a rebuild and dreading doing it.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-14-2017, 11:54 AM   #117
Jaysonb
Jaysonb's Avatar
They were a piece of cake!
Old 11-14-2017, 12:05 PM   #118
Jaysonb
Jaysonb's Avatar
I just drilled out the 2 rivets that hold the top of the hinge to the frame so I didn't have to mess with the hinge rivet, then used 1/8x1/8 rivets to put it back together, and they are hidden in the door. I did use the vise to clamp down on the hinge rivet to tighten it up a little. 1/8"x1/8" rivets for the post seal as well.
Old 11-14-2017, 12:50 PM   #119
Dads79GMC
Dads79GMC's Avatar
Great info on the windows Jayson, they look amazing as does the rest of the truck. Mike
Old 11-14-2017, 12:51 PM   #120
Dads79GMC
Dads79GMC's Avatar
What was your impression of the door panels when you popped them out of the box for the first time and put them on the truck?
Old 11-14-2017, 04:26 PM   #121
MrFinland
MrFinland's Avatar
Thank you sir! Nice to hear that someone follows our building thread. We try to do so good that we don´t later harm.
I would like to see live your truck and Mike´s truck and talk about your guys building them, but "a little bit" too long distance between us. This writing is so slow because I know so bad English. But these pages (67-72chevytrucks.com) are a good English language lesson for me.
I really appreciate your skill in making a trucks. Continue to do the same thing.
Old 11-14-2017, 08:03 PM   #122
cochino12
It followed me home?
cochino12's Avatar
Damn! Truck is looking great!!!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-14-2017, 09:48 PM   #123
Jaysonb
Jaysonb's Avatar
Thanks guys. Mike, when I pulled the door panels out of the box I thought, wow, very thin, light, and flimsy. But they seem to fit perfectly, the woodgrain insert is metal, and very nice, so I think once they are fully installed they will be fine, a little self adhesive mass backing might go along way also. I would buy another set.
Old 11-15-2017, 05:20 AM   #124
LT7A
This truck is coming together beautifully! An idea to consider on the bedliner. Difficult to color match the metallic paint because the different material and finish is going to throw the light differently. And being a gray in lieu of a "color" you will probably need to darken it up some to get it to match. What do you think of doing a non-metallic gray a couple of shades darker than the paint? It would be clearly not be the ubiquitous black, but still look purposeful. In my line of work sometimes a "near match" doesn't look nearly as good as a purposeful shift in shades.
Regardless, dig the truck. Same color as my first square.
Old 11-15-2017, 10:23 PM   #125
Dads79GMC
Dads79GMC's Avatar
Adam, thanks again for the NOS body panels!!!!
