Old 11-05-2017, 12:18 PM   #76
gringoloco
A guy with a truck
gringoloco's Avatar
Re: #the 77_remix
Where do you source the nylon clamps?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-05-2017, 12:31 PM   #77
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: #the 77_remix
Those appear to be made 4 you clamps.
They are very nice.
www.made4youproducts.com
I think Summit Racing has them too.
https://www.summitracing.com/search/...lamps-brackets
Keith
Convert to disc brakes.
Old 11-05-2017, 03:38 PM   #78
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
They are very nice.
Keith is correct. Those are Made 4 You Products clamps. I use the extensively on my builds. They are well made and come with stainless screws.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2017, 11:03 AM   #79
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Yesterday I was on call and had some running to do. I worked on more small projects trying to accomplish what I could in the time available. The license plate bucket needed attention, so I focused on that.
I blew it apart and noted how badly the lens on the light had faded. Summit was sourced for a Goodmark brand replacement housing. In the interim, I spent some time cleaning the edges of the housing up and prepping for paint.
Another issue was addressed that I had been meaning to get to for a while.The bottom bolts of the license plate rattled badly when the truck was at idle. I had placed some rubber bumpers at the contact point but it didn't resolve the rattle. I bought a pair of the plastic bolt holders and installed them in the bottom. To do it right I had to drill a hole then make it square with a small file. Its tedious work, but it matches the top now.
Articles-
"Refining Sierra"
Old 11-06-2017, 12:25 PM   #80
UKNOWME
UKNOWME's Avatar
Re: #the 77_remix
I bet that is my mysterious rattle too!!!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-06-2017, 12:33 PM   #81
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
I know that the correct color is argent silver, but I decided to see what the ACE chrome paint looked like. This will match the bumper on the back side, and most of its is covered on the front side. Hopefully the purist wont hate me.
Articles-
"Refining Sierra"
Old 11-06-2017, 12:36 PM   #82
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
If you have a frame around your plate it's entirely possible. I just did the same update on Scarlett. After I had the duals ran to the back she rattled badly. Added the extra plastic sockets and the problem was solved.
Articles-
"Refining Sierra"
Old 11-06-2017, 02:31 PM   #83
mcbassin
Still Learning
mcbassin's Avatar
Re: #the 77_remix
Looking forward to following along here too Ken. Keep up the good work
Old 11-06-2017, 09:33 PM   #84
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: #the 77_remix
Wondering Ken, what did you use on the backside of the quarter-panel that is visible in front, and behind the wheel-wells. The original undercoating (or paint, but it peels off like undercoating) on mine is coming off. I think I could easily spray anything back there, but cleaning and scuffing it seems impossible in the small area unless I completely take the bed apart.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-06-2017, 10:49 PM   #85
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Glad to have you along for the ride buddy
I'm fortunate that so far all of my builds have been rust free so I rely on the factory E coat to protect the areas that I cant reach. For the accessible areas I use the same formula as the frame, etc. Start with scuffing the surface with coarse grit paper, then follow with Scotch Brite. From there I clean with brake cleaner, then coat with undercoating.
Articles-
"Refining Sierra"
Old 11-07-2017, 10:27 PM   #86
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
As promised, I have a comparison between the stock incandescent tail light bulbs and the LED replacements that I purchased. I was cautioned by Chris Lucas to watch out for physical size of the LEDs as some are inherently larger than the bulb they replace. I looked for this in the advertised specifications. For some reason the seller thought I would be concerned with the package dimensions rather than the size of the item in the package. In case your interested the package was 3.2 x 1.7 x 0.5 inches. I looked in the reviews to offer some insight and found great information on the 1156 and 1157 bulbs. None was to be had for the 194 bulbs so I "assumed" they would be fine.
Upon arrival, I opened the packages and compared them to the bulb they would replace. It was clear that the info sourced on the larger bulbs was correct. Unfortunately the 194 replacement was obviously too long. It certainly looked cool as the body was made of machined aluminum, but clearly not going to fit inside the housing.
Articles-
"Refining Sierra"
Old 11-07-2017, 10:39 PM   #87
Mtblack412
Re: #the 77_remix
Following along on this build! I can’t wait to see where this build takes you. Awesome as always.
Mtblack412 is offline   Reply With Quote
Old 11-07-2017, 10:48 PM   #88
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Ok, so the 194s will stay as incandescent for the moment. Lets look at the other bulbs. Since I didnt have the ability to mount the lenses in place I did a bench test. I used an 18v battery for a power source so they are running a tad bit on the high side.
Thats not suposed to be an issue for the LEDs as the specs state they contain a brightness chip to allow a working voltage of 9v to 30v. Just in case your running a 24 volt system these have you covered.
So what are the results? Its much harder than you might think to get a good quality picture looking straight in to a light. In case you cant tel from the pics, the LEDs are about 50% brighter with a much whiter light. They also cast a larger illumination pattern. Note that they fill the lens with light rather than a bright spot in the center.
In conclusion, are the iBrightstar LEDs worth 7.00 per bulb? I do believe that I am satisfied with the results. Would I buy them again? I do believe that I would, so this is a 5 star recommendation for the 1157 and 1156. The 194s not so much, but they do look darn cool.
Pic #1- Reverse lights
Pic #2- Tail lights
Pic #3- Brake lights
Articles-
"Refining Sierra"
Old 11-07-2017, 11:14 PM   #89
85supersierra
85supersierra's Avatar
Re: #the 77_remix
You mentioned that you where on call. Just curious as to what it is that you do when your not setting the bar for truck builds?
85supersierra is offline   Reply With Quote
Old 11-08-2017, 10:25 AM   #90
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
My company operates arcade games. ABC Music Company I have technicians that do my service work during the week, but I rotate with them on the weekends.
Articles-
"Refining Sierra"
Old 11-08-2017, 10:29 AM   #91
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: #the 77_remix
I like the results of these LEDs. The lens still looks like a regular light pattern when they are on as compared to some LED retrofits that you can tell are LEDs.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-08-2017, 10:57 AM   #92
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
That was my thoughts too. There are some very nice LED panel lights out there. I just dont feel that they would look right in this build. These amplify the volume of light with out creating a hot spot. More of a flood light than a spot light.
Articles-
"Refining Sierra"
Old 11-08-2017, 12:16 PM   #93
GAc10boy
GAc10boy's Avatar
Re: #the 77_remix
All in for this one. One of my all-time favorite trucks and I'm a 67-72 guy . Keep up the killer work!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 11-08-2017, 01:34 PM   #94
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Thanks for the follow.
Articles-
"Refining Sierra"
Old 11-08-2017, 10:48 PM   #95
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Another late night on the job, so limited shop time. I try to find small jobs that I can complete on nights like this. I ordered a new Goodmark license plate light from Summit and it came in today. What better way to spend a rainy evening than doing final assembly on my license plate project.
I considered paint the new light, but that gold irradiate coating was such a nice contrast to the chrome silver I left it for now. I added stainless button head fasteners, and polished the bolt heads that hold the bucket in place. The entire package can go in to storage now till its time to install.
Articles-
"Refining Sierra"
Old 11-09-2017, 10:35 AM   #96
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
As the small parts for the rear come together, I'm working on supplies for the rest of the truck. I have been searching for a contemporary version of the 78 vinyl that I plan to use. Its a bit more red than the 77 with out being too red. I priced it from SMS and its 80 a yard. I could almost do leather for that price, and I'm not keen on using 40 year old materials.
I had Chris Snowden of Snowden Upholstery supply searching for a while. He finally found what I was looking for in a contemporary vinyl with a vintage look.
The stitch work will be done by Brent Davison of Sculpt Garage on an original bench seat modified for comfort and great looks.
The woodgrain by @lowsierracompany will match the exterior. Cab temps will be controlled by a Restomodair #haymaker blowing through Brothers Trucks vents. Sound damping comes from Restomodair Membrane and the elements kept out with Precision Replacement Parts seals.
Articles-
"Refining Sierra"
Old 11-09-2017, 01:11 PM   #97
Claytona08
Claytona08's Avatar
Re: #the 77_remix
Just read up on The Remix, great work on your thread with very good detail on parts selection and vendors you plan to use.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 11-09-2017, 02:13 PM   #98
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Thanks for following. Its moving slow while waiting on parts. Should pick up speed soon.
Articles-
"Refining Sierra"
Old 11-10-2017, 10:31 AM   #99
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: #the 77_remix
Last night I had enough shop time to remove the gas tank. I siphoned the remaining gas and removed the filler neck and vent hose. The original line clamps were still on the fuel lines so I waited to drop the tank before disconnecting them.
With the tank down I could access the factory squeeze clamps and remove the lines. The clamps went in the trash, and lines are saved till I decide how I'm going to route them when I go back in.
I inspected the gas tank to determine if there was any need to replace it. The new tanks are cheap, but I dont think one will be required. Inside was super clean, and the outside has no rust to be concerned with.
I am considering updating to a 87 tank with internal pump. The external pump works just fine so I'm perplexed if it's worth the expense. It will clean the frame up a bit so I'll think on that for a while.
Articles-
"Refining Sierra"
Old 11-10-2017, 02:20 PM   #100
83GMCK2500
Re: #the 77_remix
As mentioned earlier we have teamed with RestoMod air on this project. They will be providing several of their innovative products including a Haymaker II Custom Air Conditioning System.
I recently received a kit of the RestoMod Air Membrane For those that aren't familiar, Membrane is the only true thermal insulation with sound dampening material combined. Several companies offer sound deadner, or thermal barrier but no one has combined the two until now.
I will be doing some thermal testing to show the difference this barrier makes as the install progresses.
I kicked around their site a bit, saw the kit for 67-72s, nothing for squares. Do you know if they will be offering a kit for squares? Specifically for ones with a factory system looking for a more modern upgrade. Also, what do the controls look like or does the kit utilize the OEM controls?
That deadener/insulation is neat, looking forward to your reviews on it as you install and experience on the road.
I reread the thread and I didn't see...what's under the hood of the '77? Are you fuel injected?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
