Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 11-09-2017, 10:06 AM   #101
tchevs
Re: LS Swap Electric Speedo face and template
i will take two of these if you make anymore.
tchevs is offline   Reply With Quote
Old 11-14-2017, 07:07 PM   #102
Ole Greenie
Ole Greenie's Avatar
I would as well!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 11-24-2017, 12:55 AM   #103
wildmanaaron
I need something like this for a 73-87 using the earlier speedo
wildmanaaron is offline   Reply With Quote
Old 12-20-2017, 08:59 PM   #104
MidLifer
MidLifer's Avatar
Put me in line for a kit if/when you make more. Thanks.
MidLifer is offline   Reply With Quote
Old 12-22-2017, 12:58 AM   #105
ls1nova71
ls1nova71's Avatar
I currently have 2 kits left, going to have to get some more made up. I sent you a PM.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-22-2017, 01:03 PM   #106
UP GRADE
one set closer
UP GRADE's Avatar
I'll take one..
UP GRADE is offline   Reply With Quote
Old 12-22-2017, 03:38 PM   #107
MidLifer
MidLifer's Avatar
Thanks. Paypal sent.
Old 12-22-2017, 10:55 PM   #108
ls1nova71
ls1nova71's Avatar
Originally Posted by UP GRADE View Post
I'll take one..
PMs sent
Old 12-23-2017, 06:20 PM   #109
lutronjim
ls1nova71
Would you mind going over what I would need in addition to your kit.
I would assume I would have to find s10 speedo.
I am running a GM 'connect and cruise' in my 70 C10 stepper.
lutronjim is offline   Reply With Quote
Old 12-24-2017, 04:48 PM   #110
UP GRADE
one set closer
UP GRADE's Avatar
Ls1nova71 didn't receive the pm.
Old 12-25-2017, 01:23 AM   #111
ls1nova71
ls1nova71's Avatar
Well, I thought I sent it, but don't see it either. I sent it just now.
Old 12-25-2017, 01:26 AM   #112
ls1nova71
ls1nova71's Avatar
Originally Posted by lutronjim View Post
ls1nova71
I'm not super familiar with the C&C engine combo, but I don't think that package is set up for a regular electric speedometer being that it is a GenIV engine. Do you have a wire in your harness that says it's foe a speedo?
Old 12-25-2017, 10:02 AM   #113
lutronjim
Yes I am currently running a Dakota Digital box to drive the speedo. I have seen signs of it studdering lately and I am afraid it might be on the way out. It uses a wire marked for the speedo to get pulses.
Old 12-26-2017, 04:59 AM   #114
ls1nova71
ls1nova71's Avatar
Ok, so apparently that system does have a speedo output. I would check your install instructions and if it is putting out a 4000ppm signal like the older engines do, then it would work. As for what else you need other than my kit, depends on how much work you want to do. I include the face, the stencil for painting the numbers on the lens, and 2 paper templates for making the mounting plate and rear cover box. If you dont want to make those 2 parts, CaptainFab was making them at one time and may still have them, but you'd have to check with him to be sure. Other than that, you'll need an S10 speedo obviously, and sockets for the lights, a small LED for the high beam indicator and I usually put in a plug so the cluster can be unplugged to remove it when necessary. It's all laid out in detail in the electric speedo thread along with directions on how to do it.
Old 12-26-2017, 04:05 PM   #115
UP GRADE
one set closer
UP GRADE's Avatar
Pm sent
Old 03-12-2018, 11:57 PM   #116
krue
Designated A-hole!
krue's Avatar
Interested if you have any made? May need 2.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-27-2018, 09:12 AM   #117
COOP3726
I want one. PM me and I will send you the payment.
Thanks.
COOP3726 is offline   Reply With Quote
Old 03-27-2018, 11:57 PM   #118
ls1nova71
ls1nova71's Avatar
Thanks.
PM sent
Old 04-06-2018, 02:44 PM   #119
COOP3726
Do you have a wiring schematics for the cluster with the speedometer in it?
Old 04-07-2018, 11:47 PM   #120
ls1nova71
ls1nova71's Avatar
Are you talking about a schematic for a '96 S10? What exactly do you need to know?
Old 04-09-2018, 07:48 AM   #121
COOP3726
I'm sorry for sending you this. I found the link where you had posted the wiring for the 71 C10 speedo. Thanks again for all your help.
Old 07-06-2018, 03:49 PM   #122
cebra
If you have any currently, I will take one. Shoot me a PM.
cebra is offline   Reply With Quote
Old 07-24-2018, 06:20 AM   #123
Bay67C10
I’ll take a kit. Thanks!
Andrewortiz54@gmail.com
4084696001
Bay67C10 is offline   Reply With Quote
Old 07-24-2018, 09:11 PM   #124
Hidesertchevy
I'll take a kit
Hidesertchevy is offline   Reply With Quote
Old 08-02-2018, 04:50 PM   #125
misfit0313
If these kits are still available, I would like one please.
misfit0313 is offline   Reply With Quote
