Old 11-13-2017, 04:11 PM   #1
Ramiro0727
72 front crossmember
We have a 72 front crossmember with disk brakes. We want to swap out the 69 front crossmember with drum brakes. What is easier to change it out. The whole crossmember or the A arms and other stuff and bolt them to the existing crossmember.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 11-13-2017, 05:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 front crossmember
Thanks,
Ramiro
Depends if the engine is in it or not. If no engine I always swap the whole thing....
LockDoc
Leon
Old 11-13-2017, 05:33 PM   #3
Ramiro0727
LockDoc
LockDoc the engine will be out of it.
Old 11-13-2017, 05:35 PM   #4
LockDoc
LockDoc's Avatar
It will be a direct bolt in.
LockDoc
Leon
Old 11-13-2017, 08:39 PM   #5
Ramiro0727
LockDoc
Thanks LockDoc
Old 11-14-2017, 01:41 PM   #6
kwmech
As stated a direct bolt in, but I find 99% of the time the whole thing needs to come apart anyways to be rebuilt. Easier for me to handle a lower control arm than a 300 lb + frame section and wrestle it in to line up the holes
Old 11-14-2017, 08:58 PM   #7
Ramiro0727
Kwmech you have a good point. my son is planning on replacing all the bushings on the A arms and lower control arms. Maybe that’s the route he should do.
Ramiro
