06-13-2017, 04:32 PM | #1 |
Just another bagged and ls swapped c10
this is where it started. 71 long bed.
06-13-2017, 05:28 PM | #2 |
Re: Just another bagged and ls swapped c10
Picked up the 5.3
06-13-2017, 05:30 PM | #3 |
Got it moved over to its build spot
06-13-2017, 05:32 PM | #4 |
Started pulling it apart
06-13-2017, 05:36 PM | #5 |
Got the cab off.
06-13-2017, 05:39 PM | #6 |
Notched out the front cross member
06-13-2017, 05:42 PM | #7 |
Got the lower control arms ready for the bags.
06-13-2017, 05:43 PM | #8 |
Oh yeah, I am turning it into a short bed.
06-13-2017, 05:44 PM | #9 |
she cut up
06-13-2017, 05:45 PM | #10 |
Got everything tacked. Double checked all measurements and everything is perfectly level.
06-13-2017, 05:47 PM | #11 |
Frame welded and a reinforcement plate is welded in in the inside. Started mocking up the trans cross member.
06-14-2017, 05:37 PM | #12 |
Whats the cross member notch for?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-14-2017, 06:36 PM | #13 |
The notch will get me 3'' closer to the ground. You can buy the drop members, but i have a lot of time on my hands.
06-14-2017, 06:51 PM | #14 | |
What are you doing for steering?
06-15-2017, 11:51 AM | #15 |
Awesome work so far.. Coming along nicely.
06-15-2017, 04:01 PM | #16 | |
Thank you! |
06-15-2017, 09:35 PM | #17 |
Seen it a thousand times, boring. Just kidding! Thanks for sharing your build. Looks like it's going to be a nice truck. I like your method of raising the front crossmember. I haven't seen that exact approach before.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
06-16-2017, 08:48 AM | #18 |
I have saw this way done a couple times. Once I get everything mocked up, ill see if it meets my goal for how low i want it to be. If not i will Z the frame up front.
07-05-2017, 04:56 PM | #19 |
Started building the transmission cross member.
Instagram @c10josh |
07-05-2017, 04:58 PM | #20 |
I went ahead and z'd the frame. Started boxing in the front portion of the frame.
07-21-2017, 11:32 AM | #21 |
Started building the step notch.
07-21-2017, 11:35 AM | #22 |
She going to be low. Still a lot of work to do on the notch. 4 link is next.
10-31-2017, 09:29 AM | #23 |
Turned the axles down so I could use 2001 Silverado rear disc brakes. Just need to fab the mounting bracket.
11-14-2017, 06:45 PM | #24 |
did you buy a 4 link kit for the rear or make your own?
11-16-2017, 01:04 PM | #25 |
Its a switch suspension 4 link kit.
