10-13-2017, 08:08 PM | #601 |
Re: What did you do to your Blazer/Jimmy today?
10-17-2017, 11:24 PM | #602 |
Thanks for the feedback guys. Exterior work in high gear now. Door handles, locks, mirrors and trim going on.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
10-20-2017, 03:10 PM | #603 |
I tackled (but not finished) patching my hardtop that the original owner decided to put a sunroof in. I could not locate a top and decided to fix the original. I have attached a before shot and then a shot of the outside top and an inside shot. The pain job is temporary as Ill probably paint the entire thing next year. This was a bear to fix as the inside has lines in it and the front header to deal with. A little more filler and sanding inside then some quick paint.
10-21-2017, 10:27 AM | #604 |
Carpe manana
Nice work guys!
10-21-2017, 01:35 PM | #605 |
And heres an after. I got the white paint from napa....its a rocker paint and comes out textured...doesnt look too bad. It will work unitl I restore the whole top. Cannot ev3n tell there was a sunroof now.
10-28-2017, 08:21 AM | #606 |
Awesome job. Can not tell you how many tops I've seen with holes cut in them; Why?
10-28-2017, 08:26 AM | #607 |
Just a couple teaser pics. I'll post engine/engine compartment before and after in a few days.
10-28-2017, 09:16 AM | #608 | |
Anyway looks great! |
10-28-2017, 09:22 PM | #609 |
Not mine but my buddies had a leaky pinion seal and a "clunking" noise....
replaced the seal and found where some PO had once been in the carrier and hadn't shimmed the carrier bearings correctly... it had about .020 side to side play...... fixed it all and replaced the u-joints....and since he's an electrician....we pulled some wire and put up some lights in my addition.... rained all day, but we had a successful day...! Discovered it was a a limited slip
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-01-2017, 10:32 PM | #610 |
Got it all back together today, started right up and got the engine to operating temperature. This is the last picture before the fan, radiator, core support etc. covered up the front area. I had the upper alternator bracket in the wrong place that's fixed now. Also I've got to move the water pump bolt/stud to the correct location on the waterpump(thanks Pete!). Glad I put water in it as I found a pin hole in the upper radiator hose too.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 11-02-2017 at 08:46 PM. |
11-02-2017, 09:11 PM | #611 |
Leaking upper radiator hose fixed,freshly painted air cleaner assembly.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 11-02-2017 at 09:20 PM. |
11-06-2017, 10:33 AM | #612 |
First drive...
11-06-2017, 05:03 PM | #613 |
NICE looks good.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-06-2017, 05:27 PM | #614 |
Started to put the dash back together.
11-07-2017, 11:48 AM | #615 |
11-18-2017, 11:49 PM | #616 |
11-19-2017, 09:38 PM | #617 |
11-20-2017, 12:26 PM | #618 |
Installed 4 inch lift and 33 inch tires over the weekend.
11-26-2017, 11:15 PM | #619 |
3rd brake light installed under the tailgate handle. Light purchased from Custom Dynamics.
Photo Gallery of 1972 K/5 Blazer CST |
11-26-2017, 11:25 PM | #620 |
Replaced the head unit today. JVC KD-AVX44 replaces Kenwood EZ500.
11-26-2017, 11:27 PM | #621 |
Nice looks good, I put one of those 60" strips under my tailgate with brake b/u light and turn signals.
11-27-2017, 06:06 PM | #622 |
Active Member
Finally got my 72 interior apart and ready to replace rusty floor boards, kick panels, rockers and most of where so many rot.
Bought a 72 P/U cab & chassis with good parts and cut the floor out. I know many of you don't agree with ruining a good truck cab, but at 5K to fill my list of aftermarket parts, I decided to do it this way. Beside, it's fun. Any advice from those of you that did this, is appreciated. I'm sorry if the pics came out upside down, I'll see what I can do.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM Last edited by Moreyel; 11-27-2017 at 06:25 PM. Reason: Pic problems |
11-27-2017, 10:56 PM | #623 |
Finished restoring 15x8 Steelers from M1009 and polishing and painted hubcaps on my all original numbers matching 72 k5 blazer!
11-28-2017, 10:50 PM | #624 | |
Active Member
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM |
11-29-2017, 05:10 PM | #625 |
I used a patch from a parts hardtop...smc resin and painted with a white rocker panel molding paint from Napa that sprays textured. Ill use a bedliner and paint the whole top.
