Old 11-20-2017, 01:36 PM   #26
davepl
davepl's Avatar
Re: Radiators
In my truck I'm fine with the factory 4 core, but for my LS car I'm running the old big block BeCool aluminum with a steam port return bung welded in and that works fine.
In fact, the fans rarely ever run as long as you're in some kind of motion. The LS motor sure seems to stress the cooling system less than the old big block did!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-20-2017, 05:45 PM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Radiators
My fans hardly run as long as the truck is moving. The one fan will run as long as the AC is on but even then once moving it shuts off and the temp gauge and the scan gauge both read the same at 190*.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
