Old 11-24-2017, 12:55 AM   #1
69BUCKET
275/60/15 fronts?
Want to get same size for 4 corners to rotate them...but wondered if this size works with 2" drop spindles and 2" lowering springs.
69BUCKET is offline   Reply With Quote
Old 11-24-2017, 09:43 AM   #2
PGSigns
PGSigns's Avatar
Re: 275/60/15 fronts?
What year truck? I had them on my 66 with 15X8 with 4" back spacing and when I did my drop with 2 1/2" spindles ans 2" springs they hit the fenders. I went to 235's on the same wheels and they worked.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-24-2017, 01:37 PM   #3
68Stepbed
68Stepbed's Avatar
Some have done it with the right backspacing on the wheels, but overall, they're just a bit too big.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-24-2017, 02:15 PM   #4
Clyde65
Clyde65's Avatar
I did the same as PGsigns, only I went with a 7” rim.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-24-2017, 02:18 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
With a 2" inch drop they'll work on the front ,but any hard cornering or big bumps you'll wish you ran a 255, 245/60 tire, so in the long run a 275/60 is big for the front.
Malo83 is offline   Reply With Quote
Old 11-24-2017, 02:24 PM   #6
69BUCKET
My truck is a 69 2wd 6 lug with I believe the 15x8 steel wheel.
So with my total 4" drop...will 255/60 even work?...
Old 11-27-2017, 04:09 PM   #7
69BUCKET
Anybody have a picture of a 255/60/15 with 4" drop in front? Or a 245/60/15 with 4" drop?
Old 11-28-2017, 10:15 AM   #8
68Stepbed
68Stepbed's Avatar
3.5/5 drop with 15x8 wheels, 255/60/15 front 275/60/15 rear.
Matt
Old 11-28-2017, 11:40 AM   #9
69BUCKET
that's the one right there!!...
Thank you sir!!
Did you have to grind control arm like i've heard?...
Old 11-29-2017, 04:01 PM   #10
68Stepbed
68Stepbed's Avatar
Thank you sir!!
Not with these wheels. The backspacing on the wheels above are 3.75" The stock 5-lug rallies are 4.25" bs, which are usually the ones needing clearance, but not always. I'm not sure why some do and some don't. If you keep it 6 lug and run the 6 lug rallies, they have 4" bs, which also clear.
Matt
Old 11-29-2017, 04:47 PM   #11
69BUCKET
Thank you for the info sir. I do plan on keeping it 6 lug...its finally coming inside garage to start the strip down.
