11-28-2017, 01:39 PM | #26 |
Re: Odd tachometer problem - any ideas?
If you are lucky, you will be able to see the bad solder joint on the circuit board. Then you can just touch it with a hot solder iron and re-flow it. It may work again for years.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
