Old 12-02-2017, 01:04 AM   #1
coldgin
Aluminum radiator
It's that time for a new radiator for my 1969 GMC 3/4 ton 4wd....i checked entropy and they told my radiator in my truck is their custom....which cost$550.....nope its not....i know i have the heavy duty one....anybody know where i can get one that will be a direct replacement?i checked Amazon and there is one advertised on there for like $160....and it says it will fit my truck....it is made by prime cooling ....
coldgin is offline   Reply With Quote
Old 12-02-2017, 02:03 AM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Aluminum radiator
Try engineering cooling products.
Jcfcamaro is offline   Reply With Quote
Old 12-02-2017, 02:52 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Champion cooling. CC369 is a direct replacement.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-02-2017, 03:11 AM   #4
In The Ten Ring
I bought a KKS radiator and so far, it seems to be fitting the bill of my 250 I6 very well. It took some trips back and forth from Advance Auto to get the right hoses though.
Rock Auto may still have their Vista Pro 4 row brass and copper unit on closeout. It sits rather high for my truck but I could make it work I think, I ended up getting the KKS also and going with it but I will hang onto the Vista Pro. In fact, I might even get another one and sock that away too.
In time I plan to get my original OEM radiator recored although I know that will be very expensive.
Unless cost is your main hangup, why not get an American company (several on here) custom make you one? You might be able to get one to sit right on the rubber cushions and give you a horizontal filler cap. *I truly dislike the angled ones like my KKS.
In The Ten Ring is offline   Reply With Quote
Old 12-04-2017, 07:22 PM   #5
weq92f
weq92f's Avatar
Originally Posted by Ccas View Post
Champion Radiators is a decent quality box welded radiator. However, their 2 and 3 row radiators are inadequate for many higher performance v8's in cars today. You need to go to their 4 radiator for best cooling and that still isn't as good as 2 big rows. Their units are all also fabricated tanks which do not resemble original at all. Fitment is semi-OEM. Because of the fab'd tanks, modifications are often needed for fitment.
I'm all for plugging board sponsors and such but, in support of others, I must say that my Champion 3-Row is looking The Business up next to what it is replacing here in my world. I bought the CC369 with fans. This all aluminum piece of kit is welded, polished aluminum boxes that look very nice. It test fitted nicely down into the factory lower perches and the factory upper mounts fit down on the welds just fine! It's definitely not exactly just like the stock 4 row BB radiator, but it will fit in there no problem. Once I have it all together, I have no doubt it will cool the BB.
Pics available...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-04-2017, 08:22 PM   #6
In The Ten Ring
The hose fitment problems I had with my KKS radiator were with the hoses fitting on the engine side....those fit the radiator fine.
I call it the Trump Effect.....even before the election I spoke with my old welding teacher and he said "we needed a new band saw at the college and because of Trump I want to only buy USA made from now on." That motivated me to once I get the truck running to either recore the original radiator or have a custom unit built stateside.
Ccas, I might give you a call. My truck is a 250 six cylinder, dad knocked a hole in the original radiator decades ago and no idea where that is. It had a small radiator in it from a junkyard that worked great but had several leaks sealed up my coolant impurities. I'll try and drop you a line. Mostly I want something to fit the brackets with new rubber (my lower brackets I bolted in so those can be moved and exchanged for 3 row), fit the engine outlets, and with a horizontal cap....I'd also like an overflow outset set to a direction of my choosing. Can you do that?
Old 12-04-2017, 08:40 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Pics available...
-klb
I have a cc369 in both my 68 and my 72, dropped right in. My 72 is a big block with AC. Been running cool and perfect for several years now. Their warehouse is in Lake Elsinore, about 30 mins from me. I bought them over the counter. They have very good customer service and I will buy one again if the need arises on my other vehicles. I’m not a spokesperson for them, just relaying my real world experience.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-05-2017, 02:59 AM   #8
In The Ten Ring
Oh OK, so you guys aren't exclusively "per order custom" then?
That's OK, most truck owners want the biggest engine they can, obviously they are compensating for something.
I had a roommate in college that felt "owning a gun was compensating for something." I asked him if he planned to defend himself with the body part he was referring to.
Can you direct me to those USA makers you are referring to?
Old 12-05-2017, 03:30 PM   #9
weq92f
weq92f's Avatar
I didn't mean to disrespect the 3 row or Champion all together.
... Hope we're ok.
No disrespect given or taken. It's all good, just keeping it real!
-klb
Old 12-05-2017, 06:41 PM   #10
dfwright
dfwright's Avatar
This post is meant to be read if you have already decided a nice aluminum radiator is the way to go.
We've been a sponsor on these forums for a little over a year now. I'd like to throw our name in there for consideration.
I wish I had known about you a year ago. I also have the CC369 radiator in my truck, and it's fine, but I did have to modify the mounts to fit it, in my case. I don't have a big block, but I did have the original heavy-duty radiator. I have nothing bad to say about the champion, and I am happy with it, but a platinum board vendor I could reach out to with questions, who stands behind their product would have been an easy choice for me.
I wish you the best here on the forum!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-05-2017, 07:13 PM   #11
In The Ten Ring
I guess he can't direct me......
Old 12-08-2017, 10:52 PM   #12
coldgin
So how much is it for your radiator?
Old 12-08-2017, 11:45 PM   #13
macdaddy70
I put a champion 3 row in mine back in the spring. It fits good and truck is running cooler. No issues to date.
macdaddy70 is offline   Reply With Quote
Old 12-09-2017, 12:43 PM   #14
MoFormula
Just ordered my radiator from CCAS last Thursday. Very attentive and prompt service. It should arrive next week.
MoFormula is offline   Reply With Quote
Old 12-19-2017, 03:54 AM   #15
coldgin
Ordered my radiator friday from engineered cooling products....got it monday afternoon.....
Old 12-29-2017, 08:52 AM   #16
coldgin
Well I've been trying to find time to finish installing my radiator....when they say direct fitment i call bull**** all day long....the big thick tanks are alot wider the rubber isolators for the stock radiator.....for anybody needing a radiator i would just go to oreillys and order one....at least you know it will fit
Old 12-29-2017, 11:21 AM   #17
Hotcorner
Hotcorner's Avatar
Return it, brother!
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 12-29-2017, 09:40 PM   #18
In The Ten Ring
My KKS fit just fine, no lower bracket problems at all. Like I posted above though, I would recore my original (although it is a replacement the original owner got out of a junkyard) or I would have a custom radiator made, one with a horizontal filler cap.
Old 12-29-2017, 09:49 PM   #19
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a Champion 2 row aluminum radiator in my truck. I has large tanks like a 4 row, so I had to use stock 4 row rad mounts and rubber isolators.
My truck has a pretty damn snotty 355 in it, and I rev that thing near 7,000 grand quite often. Stock 180 degree thermostat, and I have not had a single cooling issue to date.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-03-2018, 12:28 AM   #20
Z10
Z10's Avatar
Pictures are worth a 1,000 words. A large 2 row is more efficient than a 3 or 4 row radiator. It's counter intuitive.
Some light reading starting at post #2
http://www.pirate4x4.com/forum/gener...rass-tech.html
I'm personally using an Engineering Cooling Products 2row here in HOT West Texas and after 12k miles and 3 summers it absolutely does the job. Personally tested behind my ZZ4 in 110 degree weather traveling 75mph with the A/C blasting. Good stuff.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-03-2018, 12:29 AM   #21
Z10
Z10's Avatar
Last pick.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-03-2018, 02:49 AM   #22
mcmlxix
Collector of Projects
mcmlxix's Avatar
I like the Cold Case stamped ends better than the fabricated style...
Rich
1972 K5 Blazer CST Click HERE
Old 01-04-2018, 01:12 AM   #23
Z10
Z10's Avatar
Here is my build utilizing the ECP rad and a custom fabricated shroud utilizing 2003 Pontiac Grand Am fans. You can see more on my build thread. Link in my signature.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-04-2018, 09:34 AM   #24
zicc1835
zicc1835's Avatar
good info here when.... i get there ill give Ccas a shot
zicc1835 is offline   Reply With Quote
Old 01-04-2018, 12:06 PM   #25
SparkyRnD
SparkyRnD's Avatar
We make radiators here in the USA by hand, and we're a board sponsor:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
