12-09-2017, 12:14 PM | #1 |
What size cooler lines for 4L80E
Have found that GM used 5/16" cooler lines on the 4L80E until 1998. They must have gone to 3/8" when they moved the return line to the middle of the transmission case. All the radiators I have found for my 67 to 72 truck have 1.2" - 20 threads for 5/16" cooler lines so there will be some restriction at the radiator even if I run 3/8" lines to it. Thinking about splitting at the radiator and adding an aftermarket cooler in parallel to keep the flow up. Since GM ran 5/16" lines on the 4L80E in the early years I assume that unless I work the transmission hard I would be ok even if I stayed with the 5/16" lines.
1968 SWB Step Side, Big Block, 4L80E , Running! |
12-09-2017, 02:13 PM | #2 | |
Re: What size cooler lines for 4L80E
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-10-2017, 02:26 AM | #3 |
Run an aftermarket with 1/2 lines....Its cheap insurance. I run a derale with fan more than acquit bout 250 bucks for the whole kit. But they offer smaller ones a little cheaper. I went big for the 3800 stall 😜
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
