Old 12-14-2017, 10:35 AM   #226
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: "Elwood" the 77_remix
Last night I focused on the brake lines. The Wilwood calipers require AN fittings, which were part of the braided stainless hose kit. It includes an adapter to attach to stock lines. Of course I was having no part of keeping the ugly stock shielded lines.
I bought new hard lines from Oriellys and bent them to follow the contour of the axle housing. Fortunately this line is rather forgiving and made my tube bending skills look much better than they are.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-14-2017, 10:59 AM   #227
N2TRUX
Happy to be here
N2TRUX's Avatar
I also replaced the flex line that attaches to the housing. I found out the hard way that the new one was a bit narrower than the old. No big deal unless you have hard lines with no room for variance. I will be remaking one side of the axle hard line to accommodate the narrower bulkhead.
Articles-
"Refining Sierra"
Old 12-14-2017, 11:03 AM   #228
N2TRUX
Happy to be here
N2TRUX's Avatar
After looking at the parts coming together, I decided I really liked the satin black accented with polished fatner them I had going. I decided to paint the differential cover satin black instead of cast iron.
Which version do you prefer?
Articles-
"Refining Sierra"
Old 12-14-2017, 11:08 AM   #229
83GMCK2500
My vote would be for satin black cover, subtle and classy with the hardware. The cast iron cover draws the eye and it looks good but I think it takes focus away from the more interesting features you have going on back there.
Love following your builds, wish you had an instagram for these too!
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-14-2017, 12:12 PM   #230
Advanced Design
Advanced Design's Avatar
I also prefer the look of the black cover.
Advanced Design is offline   Reply With Quote
Old 12-14-2017, 12:35 PM   #231
N2TRUX
Happy to be here
N2TRUX's Avatar
I do cover my builds on my Instagram feed. I just cant go indepth like I do here.
Articles-
"Refining Sierra"
Old 12-14-2017, 12:36 PM   #232
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for the input.
Articles-
"Refining Sierra"
Old 12-14-2017, 01:46 PM   #233
LT7A
Since ya asked... When focused on just the third member, I do like the contrast of the black with the fasteners. However, for overall presentation, I like the third color to differentiate (see what I did there) various elements. Biggest question, why didn't you knock out the big dent in the lower right of the diff cover while you had it off? (Kidding)
Old 12-14-2017, 07:39 PM   #234
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by LT7A View Post
..... Biggest question, why didn't you knock out the big dent in the lower right of the diff cover while you had it off? (Kidding)
You know I tried, right. I'm not sure why that dimple is there, but I can tell you they wanted it to stay.
Articles-
"Refining Sierra"
Old 12-14-2017, 08:02 PM   #235
StorminNorman
With that brake tee mounted center high like that, Will it hit the bed floor when you air that thing out ?
StorminNorman is offline   Reply With Quote
Old 12-15-2017, 10:56 AM   #236
N2TRUX
Happy to be here
N2TRUX's Avatar
As a matter of fact, it probably will. I built the last two that way, but they were static dropped. I totally forgot that the pumpkin goes that close to the bed. I wasnt satisfied with the line on the right side. Looks like I'll be remaking both sides.
Articles-
"Refining Sierra"
Old 12-15-2017, 12:17 PM   #237
N2TRUX
Happy to be here
N2TRUX's Avatar
I have been trying to find the correct U joint to mate the original drive shaft from the 12 bolt to the 87 10 bolt yoke. I know its out there, but so far I'm not having much luck. I consulted Chris Lucas and he gave me a Oriellys part number. It was sorrect for the drive shaft, but too big for the yoke. I'm headed back to Oriellys today.
Articles-
"Refining Sierra"
Old 12-15-2017, 12:25 PM   #238
N2TRUX
Happy to be here
N2TRUX's Avatar
Since my U joints wouldnt work, I moved on to the brake line. The rear supply line runs along the passanger side of the frame. Mid ways there is a factory union that makes a good point to start replacement. I run that along the frame and add another union before the crossmember. This allows the section that goes to the soft line to be much more manageable in length.
I got the long and short line bent and flared. I used Made For You Products nylon clamps to hold the line in place. With everything tested for fit, I pulled the lines to paint them satin black.
Articles-
"Refining Sierra"
Old 12-15-2017, 02:32 PM   #239
rustytruck50
rustytruck50's Avatar
I have the answer....it's to hold the big, round metal shavings collector magnet. It has a hole in the center which fits the dimple.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 12-15-2017, 04:08 PM   #240
cruizin01
Can you measure the openings? Feel that it shouldn't be too difficult to find the correct combo joint.
cruizin01 is offline   Reply With Quote
Old 12-15-2017, 04:48 PM   #241
83GMCK2500
Have you tried looking through here: http://www.jegs.com they have the cap and length dimensions listed for the conversion series joints. My guess is 1350 x 1330 sized.
Devin
New Daily, the '96
Old 12-16-2017, 12:29 AM   #242
N2TRUX
Happy to be here
N2TRUX's Avatar
Good answer. Must have been optional though. Mine doesn't have a magnet.
Articles-
"Refining Sierra"
Old 12-16-2017, 12:33 AM   #243
N2TRUX
Happy to be here
N2TRUX's Avatar
Have you tried looking through here: http://www.jegs.com/p/Spicer/Spicer-...14754/10002/-1 they have the cap and length dimensions listed for the conversion series joints. My guess is 1350 x 1330 sized.
I went by Oriellys today and spent an hour researching. A young employee and the store manager went through several dozen combinations and we couldn't find the right fit. Tomorrow I'm going to a local drive shaft shop. If they can't figure it out, I'll get a new yoke put on my old drive shaft.
Articles-
"Refining Sierra"
Old 12-16-2017, 01:18 AM   #244
cochino12
It followed me home?
cochino12's Avatar
Ken I had this same problem a couple years ago, turned out two parts stores in town had u-joints placed in the wrong box from the manufacturer. I've got the correct part numbers on the wall in my garage somewhere I'll grab them tomorrow if you'd like.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-16-2017, 12:49 PM   #245
rustytruck50
I'd bet it did at one time....a couple of guys that worked in dealerships I worked at would pull those out and leave them in the drain pans or use them to post stuff on their tool boxes....the rear suspension is really looking great!
-Doug
'05 RCSB Sierra 2WD
Old 12-16-2017, 09:56 PM   #246
N2TRUX
Happy to be here
N2TRUX's Avatar
Adam I truly appreciate your offer, but I got it resolved.
Articles-
"Refining Sierra"
Old 12-16-2017, 10:16 PM   #247
N2TRUX
Happy to be here
N2TRUX's Avatar
The kid at Oriellys gave a valiant effort to finding what I needed, but just couldn't find it. Talking with the Manager I said my next stop was at a driveshaft shop. If they didn't have what I needed I was going to have it built.
The store manager suggested Northwest Drivetrain Service so I gave them a call. The man said the magic words. "I have what you need" and "we're open on Saturday ". Folks we have a winner!
What this conversion requires is a 1310 / 3R combo U joint. This uses external clips in the driveshaft and internal clips on the differential. This took some effort for a fairly common conversion but I feel like it's worth it. I went from a 12 bolt with 3.08 gears to a 10 bolt with 3.42 gears for less than $100.00
Articles-
"Refining Sierra"
Old 12-16-2017, 10:33 PM   #248
N2TRUX
Happy to be here
N2TRUX's Avatar
To back up just a bit, I'll go back to Friday night. My shipment from Switch Suspensionarrived. As mentioned I opted for a pair of ViAir 444 compressors in satin black.
I unpacked the box from Switch and discovered a couple of extras in the box. Seth sent a shirt and stickers along with the stealth black air pumps.
Articles-
"Refining Sierra"
Old 12-16-2017, 10:46 PM   #249
N2TRUX
Happy to be here
N2TRUX's Avatar
I played with the placement of the compressor location, but there's not a lot of options. The intake filter should be somewhat protected from the elements if possible. The output hose is rather rigid so the location chose it self.
Time to call it done for now
Articles-
"Refining Sierra"
Old 12-16-2017, 10:56 PM   #250
N2TRUX
Happy to be here
N2TRUX's Avatar
Saturday morning we took care of pure driveshaft issues. After Chris got that painted he moved on to the gas tank. It was in good condition, but had a factory undercoat sprayed on randomly. He grabbed a grinder with a wire cup and went to work.
After he stripped the tank it was blasted with coats of sealer primer, then topped with satin black. Rather than try to suspend it for painting, he opted to spray one side at a time.
Articles-
"Refining Sierra"
