Old 12-24-2017, 05:36 PM   #26
Deerelindel
Re: Lets see your tow mirrors. '69 K20 needs your ideas.
Originally Posted by SS Tim View Post
While I know this a real problem for you the flyswatters are not a solution. Looked for half an hour through my pictures and can't find more than bracket pictures. Finding a good usable set will be very difficult plus they are not that usable in that they vibrate badly.
Understand about the rust issue but for moderate to limited towing I think the camper four points are the best choice. Most car trailers here go 96" wide and they push 102" (its fun walking around Willow Springs Raceway pits).
For a full timer I'd jump up to the DG5 West Coast or a current bubble back aftermarket style that is similar with heated heads even.
Do you have the mounting location for the flyswatters? What book did this diagram come from?
1968 GMC 1 ton 4*4 with Detroit Diesel 6v53t 9ft stepside
1978 Chevrolet C50 350sb 8ft fleetside
Deerelindel is offline   Reply With Quote
Old 12-24-2017, 08:33 PM   #27
SS Tim
SS Tim's Avatar
The design location MAY be in the factory asembly manual.
I'd have to look harder to find it.
The diagram is from a parts manual.
Here are more pictures showing the factory installation.
Have you located a set of usable or better flyswatters to install?
SS Tim is offline   Reply With Quote
Old 12-24-2017, 10:56 PM   #28
Barnfind46
Barnfind46's Avatar
I found these mirrors at a wrecking yard on a square body. they were universal and adjustable. They work fairly well.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 12-25-2017, 09:15 AM   #29
Andy4639
Old member
Andy4639's Avatar
Talking Re: Lets see your tow mirrors. '69 K20 needs your ideas.
My mirrors on the ramp truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-25-2017, 12:19 PM   #30
suburban99
suburban99's Avatar
I made these out of 3 different mirrors for my 72 K10 to fit the existing holes in the doors. They are ok around town but shake pretty good on the freeway. Most people that I drive by are looking at the truck so they don't care if I cut them off...
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 12-26-2017, 06:07 PM   #31
Deerelindel
I have the mounts for the door but need the arm and the mirror its self.
Old 12-27-2017, 10:28 PM   #32
SS Tim
SS Tim's Avatar
A little period inspiration
mirrors, towing
