12-25-2017, 02:49 AM | #1 |
Dually 49
Ok so I'm trying to make a 2wd dually out of my 3600 ..
I have a 3800 dually cab n chassis .But I want a more modern ride . Anyone use a 88 to 98 or newer c3500 dually frame or what would be the best way to go . I want it low but not slammed I also have a 5.3 w od tranny to run . |
12-25-2017, 07:05 AM | #2 |
Re: Dually 49
The track width of a C30 will be wide under that body. Sheet metal from a medium duty might cover better. Might consider a way to make original front end ride better. I can't think of any independent front suspension that is narrower that is 8-lug to use the spacers and Budd-type wheels
12-26-2017, 11:27 AM | #3 |
Re: Dually 49
I used to have a 92 3500, and I can tell you that the frame gets really wide just to the rear of the cowl area. It's almost directly under the doors. No way you could sit a 49 cab on it except just sitting on top of that frame.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
12-30-2017, 02:19 AM | #4 |
Re: Dually 49
So I found a 1972 dually .
I do body work and mech. I'm just trying to find a frame that could work without having to redo the whole frame. Making the fenders wider are no problem . |
12-30-2017, 09:54 AM | #5 |
Re: Dually 49
You will have to widen the fenders for sure. Figure guys are swapping that body onto S10 chassis because they are such a good match.
12-30-2017, 09:59 PM | #6 |
Re: Dually 49
it should work with the 72 chassis. Measurements can be found here https://www.gmheritagecenter.com/doc...olet-Truck.pdf
On the other hand this truck sits on a 90 something or later dualie chassis and runs a Duramax. He has an album on the truck on FB.
Tags |
2wd, 3600, 3800, 5.3, dually |
