Old 01-02-2018, 01:49 PM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
034 Phase II Heads?
I bought these heads from a local circle track racer. I dont have the heads here at home, but the guy building my 400 sent me these pictures. Can someone verify these as 034 phase II. Only mark I can see is the bowtie.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 01-02-2018, 09:30 PM   #2
PGSigns
PGSigns's Avatar
Re: 034 Phase II Heads?
Only way to know for sure what they are is a picture of the casting numbers.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-03-2018, 02:44 PM   #3
parrisc19844x4_468
Jimmy
casting number is the same for both phase I and phase II. 034
Old 01-04-2018, 08:41 PM   #4
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Text is not mine, highlight is. I'd say they're the Phase 2 version based on that.
10134392 Phase 2 Cast Iron Bow Tie Head
The Phase 2 Bow Tie cylinder head (casting P/N 14011034) has the highest performance potential of any cast iron Chevrolet head. It is intended for off-highway applications only. Although the Phase 2 cast iron Bow Tie cylinder head has the same casting number (14011034) as the Phase 1 head it replaced, there are several significant differences between these two heavy-duty cylinder heads. The Phase 2 cast iron Bow Tie head can be identified by its redesigned outer water jacket wall with a machined bar between the exhaust manifold flanges. (Phase 1 castings have a raised parting line between the exhaust manifold flanges.) The area around the tapped water temperature sensor hole is also machined flat on the Phase 2 head. The Phase 2 Bow Tie head has a revised combustion chamber design with a true volume of 64cc's. The quench areas beneath the spark plugs are filled to increase compression in competition engines. The intake valve seats are machined for 2.02" diameter valves; the induction hardened exhaust valve seats are finished for 1.60" diameter valves. The intake and exhaust ports are identical in Phase 1 and Phase 2 cast iron Bow Tie heads. The 184cc intake runners will satisfy the airflow requirements of most competition engines while enhancing throttle response and mid-range torque. In unmodified form, the Phase 2 Bow Tie head will flow more air than any production cast iron small-block head. Extra-thick wall sections allow the ports to be enlarged to increase their flow capacity. The manifold heat riser passages are deleted in Phase 2 Bow Tie heads to produce a cool, dense intake charge.
Technical Notes: The valve spring pockets in cast iron Bow Tie heads are machined for up to 1.50" diameter competition valve springs. The rocker stud bosses are tapped for screw-in studs; studs and pushrod guideplates are not included. Use GM Performance Parts studs P/N 3973416 (3/8") or P/N 3921912 (7/16") and hardened pushrod guideplates P/N 3973418. Use 5/8" hex-head spark plugs with tapered seats and 3/8" reach. A bare casting weighs approximately 42 pounds. Valve seats are heat-treated.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 01-04-2018, 09:07 PM   #5
Bigdav160
Bigdav160's Avatar
I read that paragraph and look at the picture and think phase 1.
I see a parting line and not a machined bar
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-05-2018, 03:49 PM   #6
parrisc19844x4_468
thanks. I was told by the seller they were phase I but he want real sure.
034, bowtie vortec, heads
