01-08-2018, 09:02 PM | #451 |
Re: finally come
got a new hoist to left the front end in order to suspend the floor for removal. the back end is already blocked up high enough the pull the rear receiver.
01-10-2018, 01:09 PM | #452 |
Re: finally come
the biggest box i got thus far, guess a full floor pan will do that!!! pics to come unboxed
01-10-2018, 03:49 PM | #453 |
Re: finally come
Whoa, that's a big box. Glad to see its from LMC. Heard if there's any problems they'll stand behind their word and make things right.
Can't wait for the pics. |
01-10-2018, 09:08 PM | #454 |
Re: finally come
They make Suburban floors now ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-10-2018, 09:33 PM | #455 |
Re: finally come
01-10-2018, 09:37 PM | #456 |
Re: finally come
i wish, its a pickup floor. i have the rear support for a burb from Az. from rocker to rocker with enough to graft to the rear floor pass'd the support and enough to graft to the new pan. i will need to cut the pickup rear cab support out and use the burb support. i will put a few pics to show my crazy plan...
01-10-2018, 09:42 PM | #457 |
Re: finally come
should be enough to graft from both sides this is the burb it came from, saw it in person during thanksgiving!!!
01-11-2018, 09:23 AM | #458 |
Re: finally come
Cool!!! I have bought stuff from LMC. I liked it all.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
01-11-2018, 10:03 AM | #459 |
Re: finally come
Looks good just dont let it get away from you. Hope you are bracing it so you keep the measurement right.
01-11-2018, 10:24 AM | #460 |
Re: finally come
i got it tied at the a and d post had a buddy weld it up good...
01-11-2018, 10:28 AM | #461 |
Re: finally come
unboxed
01-11-2018, 10:30 AM | #462 |
Re: finally come
Even has the firewall flange
01-11-2018, 10:32 AM | #463 |
Re: finally come
spot weldes are nice, i will delete the two on the cab brace.
01-11-2018, 10:36 AM | #464 |
Re: finally come
the rockers will be the last piece off, then the new ones right back on. im working from the inside out to keep it tied while keeping know reference point.
01-11-2018, 10:41 AM | #465 |
Re: finally come
Nice
01-11-2018, 12:30 PM | #466 |
Re: finally come
Looks like you are ready for "this weekends project".
01-19-2018, 09:02 PM | #467 |
Re: finally come
its the weekend!!! so here's todays value added task. i got tube 7' of 2.5x2.5 with 3/8 wall thnkness ima slot it in 2 spots so a link can slip in and cross pin it with a bolt say half down. the tube will lift from under the cross bars i have bolted to the a and b pilar.
01-29-2018, 02:44 PM | #468 |
Re: finally come
one 1/2" drill bit and a cutoff wheel later, it works. now i can lift the front off frame. i will come up with a second way to hold it in the air for safety!!!
01-29-2018, 09:10 PM | #469 |
Re: finally come
Always good when it works. That right there is a WIN
01-29-2018, 09:57 PM | #470 |
Re: finally come
01-30-2018, 08:10 AM | #471 |
Re: finally come
Great idea
02-07-2018, 08:21 AM | #472 |
Re: finally come
Looks like I need to visit and see what you have going on !!!
02-07-2018, 12:13 PM | #473 |
Re: finally come
03-18-2018, 01:18 PM | #474 |
Re: finally come
found this awesome nos suburban bumper today!!!
03-18-2018, 01:19 PM | #475 |
Re: finally come
Got dimples?
