01-15-2018, 10:57 PM | #1 |
6.0 install
Has anyone install a 6.0 and transmission from a 2006 Chevy G3500 into a 67 C-10? The truck was a work truck that we just had a new GM block installed about 5000 miles. The box truck was in an accident and totaled. I believe the trans is a 4L80e?
01-15-2018, 11:11 PM | #2 | |
The Older Generation
Re: 6.0 install
Quite a few people have. There is a special forum for these swaps called "LSx Swaps" and I will move your thread there. LockDoc
01-15-2018, 11:16 PM | #3 |
Re: 6.0 install
thank you
01-16-2018, 08:23 AM | #4 |
Re: 6.0 install
In short, Yes! This has been done thousands of times. Read through the FAQ thread. You will find all the basic info you need in there. There are lots of knowledgeable, friendly board members in here.
01-16-2018, 10:22 AM | #5 |
Re: 6.0 install
Welcome! Your in a good place with tons of helpful friends!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-19-2018, 04:46 PM | #6 |
Re: 6.0 install
Just spent the last 18 months (very part time) putting the very same combo in my 71 C10. Most if not all of what I needed to know came from this forum. Good luck with your swap!
What I had the most problems with: - Mounts - don't mess around, buy good mounts. You don't want to have to install your engine more than once. I ended up using CPP perches and Dirty Dingo plates. Not cheap but well worth it in the end. - Fuel supply - I really really really wanted to keep my in-cab tank. I tried a frame-mounted in-line Walbro 255 first, and it lived up to what I read about them, they aren't good at pulling fuel. As soon as it would heat up (from the nearby exhaust) it would start to starve the engine. Then I put a Walbro into the cab tank, and now I am getting tired of listening to it. After a while it starts to whine like a dentist's drill. Next step will be getting the tank out of the cab. - Oh and as far as fuel lines, use braided hose with AN connectors and "Seco seals". That last part is $10 well spent for a dozen of those puppies. They are little aluminum seals that go on the end of the male AN fitting and prevent leaks. - One thing I learned after going through 3 rear main seals thinking that I wasn't putting them on correctly is you have to put thread sealer on the flexplate bolts or they will p*ss oil. Probably should have known that but with my old manual trans, the flywheel bolts did not leak. BTW if you plan to refresh the rear main, buy one of the alignment tools to get the new one right. Sac City Corvette has a good one that isn't too expensive. That's what I wish I had known up front which would have saved me time and sweat. Have to say I'm loving the feeling of 350HP to the rear wheels. Next project is a locker, because it's hard to keep from doing one-wheel peels! |
01-19-2018, 05:15 PM | #7 |
Re: 6.0 install
It's not a bad swap to do. I've done 6.0, 5.3, 5.7, they're all pretty much the same. There's a link in my sig to the budget build I did on my rusty truck.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-21-2018, 09:48 AM | #8 | |
Designated A-hole!
Re: 6.0 install
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-21-2018, 11:47 AM | #9 |
Re: 6.0 install
Some people on this list may know how to make that work, but I don't. I actually bought the plate with seal at one point and I popped the seal out and used the Sac City tool to align the plate. So my answer would be that you could do that but that doesn't save you from having to align the plate.
01-21-2018, 05:09 PM | #10 |
Re: 6.0 install
There is a different alignment tool used to install a complete rear cover. Its a GM tool and pretty expensive for a one-time use. My wife works at a chevy dealership which allows me the extremely fortunate ability to borrow their tools from time to time and that was how i did it.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
