Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 01-23-2018, 03:39 AM   #76
fredscarryall
fredscarryall's Avatar
Re: Fastfreddys 454ss
Found a better alternative then drilling and tapping the lug nuts to fit the hub studs. I desided to call AZ pro performance. The place I ordered the disc kit from and told that my studs where a 14x2 mm and the kit said they should be a 14x1.5 mm. Within 20 minutes they gave me a call back and where air shipping the correct studs to me. These guy are really stand up guys. You rarely see customer service like this. So today I used an air chisel with a pointed tip and got them off in 5 minutes.
fredscarryall is offline   Reply With Quote
Old 01-26-2018, 02:52 AM   #77
fredscarryall
Wheel studs showed up today. Went on with an impact and a large washer. Took about 5 minutes.
Old 01-26-2018, 03:10 AM   #78
fredscarryall
Ran into another problem. When I ordered my front disc kit from AZ properformance. I decided not to order the kit with the $95 stainless steel brake line kit ( that comes with the correct banjo bolt) because I just replaced my factory front brake lines. So I didn’t get brake line banjo bolt. I though I could just use my stock one off my truck.Turns out they are a different size. Doesn’t say anything about this in the instructions.I had to go to 2 parts stores to get dorman 14100s (10x1.0x20) banjo bolts.the dorman are 27mm long, so I’m going to cut them down to 20mm. The left ones are factory and the the right ones are the dormans that are to long.
Old 01-26-2018, 07:18 AM   #79
fredscarryall
Wanted some cooler designed nuts
Old 01-26-2018, 07:33 AM   #80
fredscarryall
I want more performance out of my front pads, then the sport brake pads supplied by Baer brakes that came with the kit. So I ordered a set of ebc yellow stuff organic pads and red stuff ceramic pads. Not sure which one I will pick. Then I will match the backs.
Old 01-26-2018, 07:41 AM   #81
fredscarryall
While I was under the front. I noticed the sway bar bushings were a little cracked and worn out. So I Put in Energy Suspension 3.5178R 1 1/4 greasable sway bar set
Old 01-31-2018, 01:05 AM   #82
LT7A
You're really gettin after it with this truck! You're putting on some nice components. If I lived closer to Gresham, I'd come help just to get a shot at using the stuff you're taking off, ha!
LT7A is online now   Reply With Quote
Old 01-31-2018, 02:50 AM   #83
fredscarryall
Because I did an air ride with a brake upgrade. When the suspension is all the way up the flexible factory brake lines weren’t long enough. I had Some steel braided ones made the went from 25” to 30”. After a quick brake bleed.i finally got everything installed. Here’s how it looks with the front air deflector a inch off the ground.
Old 01-31-2018, 03:02 AM   #84
fredscarryall
Next thing on my list to do is a removable wind splitter. But mine will be black or carbon fiber. With yellow fog lights. Also in the process of making a rear fiberglass air diffuser.If I get enough interest in these roll pans. I going to make a mold and reproduce them and actually make them affordable.
Old 02-01-2018, 02:59 AM   #85
fredscarryall
Rolled the rear bed wheel openings so the the tires won’t rub. Here its fully dropped. Can barely slide a 4” tall creeper underneath. Drove it down the driveway about 50 feet and the brakes where grabbing way nicer. Couldnt go on the maiden voyage because the front air line has a hole in it.
Old 02-08-2018, 05:10 AM   #86
fredscarryall
More pics. Went for a drive. Handles like a Porsche and stops like you wouldn’t believe. Tinted my fog lights with yellow film. Major problem now is the stock alternator isn’t cutting it. Bought a tuff stuff 250 amp alternator. I’m going to attemp a cs144 conversion.
Old 02-09-2018, 03:39 AM   #87
fredscarryall
Installed my wind splitter today. Took a total of 3 hours to do. It’s made of aluminum and I wrapped the top with carbon fiber.
Old 03-07-2018, 03:22 AM   #88
fredscarryall
I installed a 320amp/180amp at idle billet alumnium alternator from quality power. It’s a 1 wire self exciting. Which means All you need is one wire going from the alternator to the battery and as soon as the alternator starts spinning it charges the battery. I asked them while they were assembling it, if they could paint it black. It’s the highest amp alternator that anyone makes that fits cs130 profile and under $500. Because of the amperage output I had to use a 1 gauge wire. I cover the wire in black loom so you wouldn’t see a bright red 5/8s wire running around in the engine bay. It was little cheaper alternative then buying another optima yellow top, second battery tray,wire and an isolator, also takes up less space and weight.
Old 03-07-2018, 10:08 AM   #89
Tiger Joe
So I gotta ask a couple things here.
1- no offense, but why bother with a roll cage? like I said before I owned one of these trucks and they are way underpowered. you haven't mentioned any performance mods yet, so just curious why you would go through all the expense when its not necessary?
2- you said in your very first post you would be keeping everything to turn this truck back to stock since its "collectable" but you've cut the frame and now rolled the wheel arches? seems like you've gone past the point of being able to turn back to stock?
Tiger Joe is offline   Reply With Quote
Old 03-07-2018, 11:25 AM   #90
fredscarryall
Since I just just dumped a bunch of money into making it ride and stop better.Thats always my start point in every build for me. Doesn’t make sense to me to have 600 horse and no way for the truck to stop ( because we all know how much these brakes suck) or have 600 horse on stock suspension and no way for the truck to handle it. The plan as far as performance is first to put a high flow fuel pump ( which I just did), rebuild and bore the tbi, bolt on procharger, install a better cam and buy some performance heads. Then have a custom chip made so the computer can handle it. As far as mods and being able to put everything back to stock. It sucks as far as having to notch the frame because you really can’t reverse that. But as far as rolling the fenders. It’s really just simply hammering in the inside lip of the fender from the poor stamping,when the fenders were made at the factory.so the tires don’t rub. Does change anything from my standpoint. I could alway bend the fender lips back, but I think that would be retarded. Then lastly the cage,thats more for rigity and some looks. Im not planning on getting t boned or have a roll over from a simple signal car road corse. If I do plan on drag racing or running a big road corse.I will have the entire cage kit. So to start out with 4 point and add the rest of the kit in to be able to pass tech as needed.
Old 03-07-2018, 01:48 PM   #91
54 jimmy
54 jimmy's Avatar
looking good. love the 454ss trucks. looks to me like you know the rules of p (proper planning prevents piss poor performance).
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 03-08-2018, 08:53 AM   #92
Tiger Joe
wow a procharger? nice way to drop some serious coin there.
what are you doing for a trans? gonna stick with the 400?
Old 03-08-2018, 11:09 AM   #93
fredscarryall
Planning on keeping the turbo 400 and add a shift kit. Then I’m going to add a bolt on gear venders overdrive. I would just have to get a shorter driveshaft. Then I have to descide to keep the 3.73 rear end ratio or go with a 4.11. It just depends on what the overdrive rpm final shift point number are. The nice part is these overdrive units can handle 1200 horse power and you can have an overdrive bolted in. In about 2 hours
Old 03-13-2018, 12:15 PM   #94
mingoman
You have one awesome 454SS truck fred! Really enjoy seeing your work.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 03-14-2018, 01:47 AM   #95
fredscarryall
Installed the removable rear wing today
Old 03-14-2018, 02:01 AM   #96
fredscarryall
Put in a new dash bezel from lmc truck. Bought a new headlight switch and dash light dimmer switch off amazon. My high/low beam switch broke in my column and while I was in there I replace the turn signal lever. I had to take the entire top part of the column apart just to get to the high/low beam switch. It took almost 4 hours and fought every step of the way. No wonder the previous owner never replaced it. Why did GM make something so complicated.
Old 03-14-2018, 09:58 PM   #97
hutcholdschool
All the updates are awesome. Really like your truck. Thanks for posting.
hutcholdschool is offline   Reply With Quote
Old 03-16-2018, 03:16 AM   #98
fredscarryall
Installed a new gas door, carbon fiber door and tailgate handle. Next will be a custom grille
Old 03-17-2018, 03:10 AM   #99
fredscarryall
Custom grille
Old 03-17-2018, 03:26 AM   #100
fredscarryall
Sold the cowl induction hood and went with a ram air. The only difference Is I am going to make the air inlet fuctional. Like Trikey Air and Billets Redx
