#26 |
Re: Right blinkers work but only tail light blinker works on left
The blue and white wires do go throw the core support but i dont think it unplugs. Not a 100% sure but i will take a look tomarrow. Thares a hole the wirs pass throw in the core sapport and it has a black gromment looking thing that sits in the hole. Is the black grommet/ hole plug also a wire conecter. Like the one that conects the rear tail lights ?
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#27 |
I am sorry, your original post said tail light. I was assuming you were working on the rear of your truck. Same rules apply no matter where. You have to have power to the bulb, front or back of the truck.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
#28 |
I gess i should of bean more clear the tail light workes fine its the frount im having issues with. So lets me be clear thare is nothing wrong with rear tail light. It works thw way is sappost to. The FRUNT park light does not blink when i go to use the left blinker. From what i understand the side marker is not suppost to blink. But the right one does. The right blinks work fine thoue. Its the left. I whant to get thr left side marker AND parlight to work. They do light up with my lights on. They just dont blink. So they do have power.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) Last edited by 71gmcC15; 02-08-2018 at 09:22 AM. |
#29 |
The front side markers ARE supposed to blink. The rear side markers do not. So ALL of your lights work including headlights? Just the front left amber markers (both) do not blink? Still sounds like a bad ground. You might wanna try attaching a ground wire or using a the test light to ground the big front marker socket. That is supposed to be grounded by the housing it sits in.
#30 |
ok yes you are correct just the amber dont blink on the left (both) i will try grounding the big socket on the front after school
#31 | |
#32 |
If yours is a 71, then yes, the front side markers are supposed to blink. I think 68 and 69 were just reflectors with no bulb. I think Tutone was referring to the rear side markers. But yea, bad bulbs or bad ground is the first thing to check for.
#33 |
ok makes seance now
#34 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here are your wiring diagrams for the markers and the trucks with marker turn signals . The first one is just the markers and the second is the markers that only flash in the front.
This is a PDF so I hope you can open it. turn signal marker.pdf
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#35 | |
#36 |
Ok i got a test light and found thaer is no power to the blinker. ( i just put the hazzards on ) Wich is blue wire right? I tryed to just wiggle the socket around the the housing and it did nothing it has a good ground on the housing. It light up fine on the white wire side.
#37 |
not sure what this is
#38 |
This is whare the white and blue wire go throw the core support
#39 |
This is the mess it runs into
#40 |
I just when out and tryed it again and i noticed when i turn mt headlights on the white wire light up like it is ment to but the blue wire has a little power . Not much it barrly lights the test light up. Is this normal?
#41 |
Who Changed This?
![]() Join Date: Jan 2013
That's either a high resistance wire (maybe partially frayed or some strands cut in the wire) or a bad ground.
#42 |
I dont thinks its the ground i growndedit and it did not matter. I think i will unravel the tape and see if the wire is broke or frayed.
#43 | |
Msgt USAF Ret
The marker lights are not grounded to the fenders but they are grounded through the front turn signal lamps to the light blue and dark blue wires. Their power comes through the same brown wires that the signal lamps do. If you look at the PDF I posted you can see that the brown wire for the marker lights go to each light and the wires coming out of the lights are wired into the power wires for the front signal lights, light blue for left and dark blue for the right light. When the parking lights are on all four lights are lit by the brown wire and the front turn lights are grounded normally. The marker lights are grounded through the front turn signal wires which have no power unless the turn signal switch is on for that direction. When the turn signal switch is placed in the R or L turn, the marker light for that side will have power on the same wire LB or DB depending on which marker is working, L or R and will ground through the brown wire through the nearest light. If the parking lights are on there will be power on the brown wires and when the turn signal switch is selected for L or R there will be power on the light blue or dark blue wires and the brown wires at the same time. If you have 12 volts on both sides of the light at the same time the light will not light up. It sounds confusing but it really is ingenious. If you notice when the turn signal is on, the front turn light and the marker light will flash alternately. The light blue and dark blue wires come through the firewall block along with the purple wire for the parking light power for the L and R turn/parking lights. You will have to check the light blue or the dark blue wires for bad connections or broken wires depending on which light is not working, If your parking lights are working then the lights have good grounds and the problem is on the power side. Here is two diagrams that show the front turns with the purple wires and the light and dark blue wires going to the front lights. this one doesn't show the marker lights. This one shows the front light wires and the markers but they don't flash. If they flashed the ground wires from the markers would be connected to the front turn lights, dark blue and light blue wires instead of to the ground.
#44 |
Msgt USAF Ret
Your pic in post 37 is the fuse for the battery gauge on the alternator side. You will have one for the battery side near the terminal on the right fender.
The plug in post 38 is for the front parking/turn light and it is a connector not just a grommet.
#45 | |
#46 |
After almost a year I finally got it to work. It was just a lose wire under the dash in the moon shap plug haha
