Old 02-09-2018, 12:40 PM   #1
MHeffeGMC71
No name LMC dash cluster ???
I can’t get the tack to work with my LS 6.0 swap. I called LMC to see who makes the cluster and try to find a wiring diagram but since I did not buy it from them they will not help me at all. I called New Vintage Gauge and they said it’s not one of theirs. The tack will only send a V4 signal. I have had the truck in the shop for 3 weeks now so any help you can give me would be great.
MHeffeGMC71 is offline   Reply With Quote
Old 02-09-2018, 02:04 PM   #2
ls1nova71
ls1nova71's Avatar
Re: No name LMC dash cluster ???
We need more info like what engine do you have, but i can give you some tips. Do you have it hooked to the white wire coming from the PCM that gives it a signal? For the 4 Cylinder tach signal, you will need to change the tach resolution from 6 to 3 in the tune, some sort of tuning software will be required. Also, if your PCM is newer than '03, you may need a pull up resistor to strengthen the signal enough for it to work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-09-2018, 02:17 PM   #3
mongocanfly
mongocanfly's Avatar
ls1nova knows the electronics but....
just curious.. who did you buy it from and what makes you think its from lmc?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
