Old 02-22-2018, 03:57 PM   #1
1969 Project
1969 Project's Avatar
T-stat to drill a hole or not to drill a hole?
I am getting ready to replace my thermostat and was wondering if it is necessary to drill a 1/8 hole in it before installing , if so what are the benefits? I heard that by drilling a hole it could cause the temp to fluctuate. The PO did not drill holes in the current thermostat and the temp is at a constant 190.
1969 Project is offline   Reply With Quote
Old 02-22-2018, 04:04 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: T-stat to drill a hole or not to drill a hole?
If it ain’t broke, don’t fix it. I’ve never drilled a hole in one, never had any issues either.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-22-2018, 04:20 PM   #3
Rich69shortfleet
Necessary? No. Helpful? Yes. It allows the engine and radiator to be completely filled with no air pockets being trapped. Drilling one or or two 1/8" holes in a thermostat creates no issues or fluctuating temps that I've ever seen. Many thermostats nowadays come with holes already in them....
Rich69shortfleet is offline   Reply With Quote
Old 02-22-2018, 04:30 PM   #4
Toms67
Toms67's Avatar
X2.
Toms67 is offline   Reply With Quote
Old 02-22-2018, 05:12 PM   #5
demian5
demian5's Avatar
They have the jiggle thing in them though.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-22-2018, 05:42 PM   #6
mikecaddy500
mikecaddy500's Avatar
Always drill two holes in them, it stops air pockets.
mikecaddy500 is offline   Reply With Quote
Old 02-22-2018, 05:45 PM   #7
Grumpy old man
Grumpy old man's Avatar
Never drilled holes in any of them over 45 years ,So now it's the thing to do ?
Old 02-22-2018, 06:13 PM   #8
demian5
demian5's Avatar
Millenials...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-22-2018, 06:32 PM   #9
weq92f
weq92f's Avatar
Apparently it's the in thing to do now. This thread is the first I've heard of it!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-22-2018, 06:50 PM   #10
K20super
It also helps with aluminum heads because it is not as much of a shock due to temperature change when it opens.
K20super is offline   Reply With Quote
Old 02-22-2018, 07:38 PM   #11
harpo231
harpo231's Avatar
My t-stat has patina ...
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-22-2018, 08:05 PM   #12
jocko
jocko's Avatar
I have heard of this before (recently), but have never done it. It came up in a discussion about the lack of wp bypass passage in the L31’s vortex heads and this was brought up as a possible mitigation. Having said all that, I HAVE had an air pocket in a rad and, if this would prevent that. I’m all for it. But I do wonder why, if it’s such a good idea why they didn’t come like this originally and still don’t as far as all the replacements I’ve bought.
What is this jiggle thing you speak of Demian??
Hey! I used to live in Lake Forest!!
Old 02-22-2018, 08:58 PM   #13
Toms67
Toms67's Avatar
I had a Corvette years ago. And they are notorious for running hot. The person that built my motor. Put a bleed hole in the thermostat. And it did run cooler. I think maybe it helps with extra circulation. But it seem to work for me. Just my two cents.
Old 02-22-2018, 09:09 PM   #14
hjewell2
hjewell2's Avatar
-klb
Just a tad overkill - but yes one 1/8 inch hole drilled helps for the purpose of air pockets
hjewell2 is offline   Reply With Quote
Old 02-22-2018, 09:46 PM   #15
garyd1961
A bypass hose is what you need not a hole in your thermostat especially on a vortec. The bypass hose keeps the water circulating through the heads eliminating hot spots. I have never know a SBC to have a problem with air pockets, these old trucks ran with air in the radiator.
garyd1961 is offline   Reply With Quote
Old 02-22-2018, 09:55 PM   #16
HO455
HO455's Avatar
It isn't anything new. It is an old racer modification. I was doing it back in the 80's. The reason is that it makes it easier to vent air out when refilling the water. Used to be you were allowed to dump the water out of your radiator between rounds and refill it to cool the motor down for the next round. Some guys used to put little valves in the top of the intake water passages to vent air too.
RIP Bob Parks.
Old 02-22-2018, 10:01 PM   #17
1972RedNeck
1972RedNeck's Avatar
$10 says the PO's thermostat has a little notch in the seat to let air through. If such is the case, no holes necessary.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-23-2018, 01:27 PM   #18
1969 Project
Thanks Fellas! I don't have any issues with my engine running hot and if the cooling system is bled correctly wouldn't you not have to worry about air in the system?
Old 02-23-2018, 11:46 PM   #19
6T7 C10
FWIW I drilled one very small hole in mine. The heater core looks to be higher than the top of the radiator and I did it to purge air pockets faster. Some thermostats already have a hole with a rivet looking piece that accomplishes the same thing. I have heard of guys propping a thermostat open with an aspirin on reassembly to let air out then the aspirin melts away and the system goes back to working normally. Without a hole I imagine air could accumulate around the thermostat and it would not open as soon but once it did it would purge the air. Probably over thinking it a bit but love the trucks.
6T7 C10 is offline   Reply With Quote
Old 02-23-2018, 11:57 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
I haven't ever seen an actual flow diagram of the coolant circulation system of a Chevy engine, but I suspect that the bypass port in the SBC water pump or the bypass hose in a BBC probably covers this issue.
~Steven
Simi Valley, CA
Old 02-24-2018, 09:50 AM   #21
Is it necessary to drill a hole in the thermostat? No, or they would come with the hole already drilled. Is it an effective way to keep a truck running cool as that thermostat allows in a wider set of circumstances? Yes. Is there any negative affect from drilling al 1/8" hole? No, only good. I never did it in all my years till a friend who is an ace mechanic suggested it when my truck seemed to run a tad hot after fresh heads bumped my compression. I'm a baby boomer and he is generation X. If it's a millennial thing to do, there's at least one good thing we can credit them . But I think it's an old school track trick that has found it's way into the mainstream.
Old 02-24-2018, 11:16 AM   #22
CANUCIT
CANUCIT's Avatar
Drill
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline   Reply With Quote
Old 02-24-2018, 02:49 PM   #23
BRL
BRL's Avatar
Years ago I rebuilt a SBC and upon its first run my 50/50 mix kept spewing out of the radiator overflow and fill hole like a coffee pot peculator!
Assumed it was an air pocket trapped in there somewhere and was causing steam.
Removed the thermostat and drove a few days and eventually it settled down, so I put the stat back in.
I read someplace that the hole causes the engine to take a bit longer to warm up but can be helpful if the stat should seize closed.
BRL is offline   Reply With Quote
Old 02-24-2018, 02:56 PM   #24
davepl
davepl's Avatar
Small block Chevrolets have an internal bypass in the water pump, do they not? Seems redundant...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-24-2018, 03:09 PM   #25
BRL
BRL's Avatar
Could very well be, that was my first rebuild and really don't know what was causing that problem.
ETA: Oh I think I see what you're saying, didn't know SBC water pumps had a bypass.
...oops!
