#26 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Finishing Bed Wood with oil: Does it last, Let's just see
You will have to repeat the oil treatment on at least a yearly basis, as it dries out. If it doesn't take very long, no big deal.
#27 |
![]() Join Date: Oct 2012
Tung oil has been used by the Chinese since 400BC. It is used to preserve both stone and wood.
It was used on the Great Wall of China and by the US Military in WWII. Good stuff.
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
#28 |
![]() Join Date: May 2012
It's funny you say that about stone. I have my drying lines for may rags right next to my slump stone wall. The area where the rags hit the wall is shell hardened from the oil. I've tried scrubbing and wire brushing the area... NOGO... shell hardened and not moving, permanent now. Starts making you think, subterranean foundations in basements. Probably way more expensive than a modern membrane... in the short run. But man, the tung oil really sucks into a CMU and hardens real nice.
White K20 |
#29 |
Been a bit over a year since the bed wood install with tung oil, and 9 months since the last oiling.
Spent ten minutes applying oil this afternoon. But I did spend a little extra time touching up the strips and tail gate to repair scraped off and scratched paint this morning before oiling. What the wood has been through since last oiling. Lots of leaves from trees it was parked under a lot of the time during fall and winter. Caused a lot of black from rotted leaves, but it cleaned up on hose down. The biggest damage I did to the wood was hauling railroad ties. The creosote soaked old ties left black scrapes along the wood from being shoved in and dragged out of the bed. Scraped up some bed strips and the tailgate. I scrubbed the crap out of the bed the week after I hauled the ties with a stiff scrub brush and simple green; and the black marks came out. I was really surprised. Anyhow, I have not babied the wood, it gets no special treatment. The wood is getting an orange like patina. Looks real good. I slathered on some oil using a green scotch brite and a heavy hand to bring up as much amplitude as the scotch brite will enable. I did not wipe the bed wood down with a cloth after the application. I set it in the sun and forgot about it. All good... the easy button... it's why I went with oil. The oil in the pic below is wet, it is a pic after fresh application. Will update again on the next oil treatment.
White K20 |
#30 |
![]() Join Date: Jul 2015
Thats a second on that one. Nice thing about Tung Oil, Linseed Oil, Danish Oil they all can be reapplied directly over the old finish...see how it goes!
#31 |
I'm a woodworker by trade and had extra maple wood grain laminate and exterior glued ply on hand. Since it was free and left over from a commercial job I used it to see how it would work. Was an Experiment which I could always chnge to oak or pine later. Plus I had to stop the financial bleeding on the truck at end of the project.
I like when I go to a cruise in and someone asks "how did you get such a good finish on that" Durable. UV resistant and looks great. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#32 |
![]() Join Date: Jul 2017
Any update on the oil? I’m planning my re-do of the bed for the summer
JMC1965 1967 C20 LWB
#33 | |
![]() j
White K20 |
#34 |
I have chosen a similar route to bed wood preservation. I painted the bottoms and sides with POR-15 like the Mar-K tests and gave two coats of an oil based "antique" stain to the tops. It merely has some gray to it that soaks into the coarser grains and gives it a little bit of an aged look. Form here, I hope that the occasional reapplication of some sort of oil will be all it takes. My truck will always be garaged when not being driven to work and such, and I bet this will last my lifetime with a little elbow grease every year or two. I have treated quite a few wood trailer beds with used motor oil and the owners of the trailers that I bowered them from were always appreciative and said that it helps especially when the trailers are in constant use and/or stored outside.
I think we are onto something here considering that we do not require that glossy show quality bed wood.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#35 |
If you can. Post pics and the products you used, and periodically update the progress of the products performance. I think it's valuable to out with the results so truckers down the road can see how other options fair in the real world. We all see what varnish does.
![]() j
White K20 |
#36 |
![]() Join Date: Sep 2002
jeffahart,
I didn't see how long it took for the tung oil to fully dry after the first application. Did it take a longer or shorter time to dry on the additional applications? Larry |
#37 | |
j
White K20 |
#38 |
horsepower junkie
almost a year since last update. hows the oiled wood? i am ready to do my own and thinking of going the oil route.
67 ![]() 71 olds cutlass "S" mom bought new..12.30s@113MPH |
#39 | |
![]() Quote:
![]() j
White K20 |
#40 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Lot of nice looking wood beds...I treat my wood bed once a year (whether it needs it or not) with used motor oil. I mop it on liberally on a hot summer morning after a good high pressure cleaning a day or two prior to oiling. The oil seeps through and coats the fastening hardware protecting it as well...Nothing fancy because I haul dirt, rock, straw and brush as well as tools and fuel barrels. My truck spends it's life outside in the rain sleet snow and blazing sun...Nothing Fancy...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#41 |
![]() ![]() Join Date: Mar 2016
I have planned to use beetle kill pine and am interested in seeing you're results.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#42 |
Here's a couple pics from last Oct 2018 when I last did an application. Normally I will touch up the strips and wheel wells with white canned rust-oleum. Then I will apply the oil next day, week, month or whenever I get around to it. Oiling only takes about 15 minutes. But, how's it holding up? Last Oct when I went to oil I noticed the second big board from the left was cupping up about a 1/4". So I lashed it down, you can see the bolts to the cross members. That same board had continued to open up. I have always had my eye on that particular board. If you look at the original pics you can see the faint black lines in the same board. It has continued to open a bit each year. I don't think it's going anywhere now. I dripped extra oil in the cracks and that has now hardened like a resin.
I like the dark patina. I like that the wood is getting hard. I don't like that it's opening up. I think I will get 10-15 years. I think the wood will still be structurally viable in that time frame. But it won't win a show prize! The truck stays outside and the bed get's abused. But.. it's not the usage abuse, it's just flat the weather. Wood doesn't like weather. You have to maintain wood. It's why I tried this (almost) maint free solution. Easy maint anyway, not like paint or varnish. I was at a restoration shop Saturday. The owner was looking over my truck, he commented on the bed wood and said they spray a poly clear coat like for paint jobs. He said it won't split with that. I really doubt it though, let me see the three to five year bed spent outside. His stuff is expensive and his clients probably both garage and cover their expensive toys. But, everyone comments on the bed wood and has an opinion, I listen and I am interested. But I really want to see the five year, been in the elements solution. Keeping wood looking natural and pristine is a tough one. Paint is the pest protection you can get, and sometimes boards still crack and move. You can get paint that's pretty damed good, but there is no guarantee how each board is going to behave. But I wanted my wood to look like wood. So there's that, the satisfaction I get when I look at the wood. Anyhow thats the update. Would I do tung oil again? Not sure yet. I will definitely know in five more years. Would I do yellow pine again? Not sure on that either. Next time I may just mill some railroad ties. I posted this to help people decide. Not really an evangelist, just hoped to get a good solution to keep the natural look. ![]() j
White K20 |
#43 |
Oh also, one other thing. The zinc bolt heads are beginning to rust now too. I mean patina!
![]() j
White K20 |
#44 |
Nice! Thanks for the update. FWIW I'm thinking your bed looks fantastic given the minimal amount of time required to maintain it and the fact that you don't really protect it at all. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#45 |
horsepower junkie
thanks for the update!
#46 |
I've finished cutting my wood , now I need to drill some holes , sand and finish. How is yours looking now ?
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 06-18-2019 at 01:18 AM. |
#47 |
horsepower junkie
i finished mine with penofin. https://www.penofin.com/wood-stains/...ish-wood-stain
my truck sits inside. i drive it to work 2-3 times a week. the wood is pine.
#48 | |
Anyhow, great job. Your'e going to love looking in the bed and seeing that wood! ![]() j
White K20 |
#49 |
horsepower junkie
i specifically posted this so i can find it later! so then i will know when i did it. i will update in 6 months or so.
#50 |
I oiled so I will log an update. Wood has taken on a nice dark patina. I like it a lot. The wood is getting really hard. I posted a pic of the bottom also. I have not touched the bottom since install. Over the weekend I touched up the strips with the canned white Rustoleum, and took some steel wool to the wood to bring up a little amplitude then oiled. I abuse the bed pretty badly, no mercy. It lives outside. It ain't pretty, but it looks like I might get 20 years if it continues to get harder.
Top Bottom
White K20 |
