02-21-2018, 04:01 PM | #1 |
53 years young
I was gifted a 1965 Chevrolet C30 fleet side that hasn't ran since at least 1992. Everything is in acceptable shape considering the elements of being outside in CA weather. According to my Uncle he had did an engine swap with a 68 Camaro and went from a 230 to a 292. However, I read the number stamped on the block and it comes back to a 1970-72 250. If there is an easy way to confirm this it would be greatly appreciated. I am super stoked to bring it back to life and completely restore it back to its original beauty.
As of yesterday I installed a new Summit Racing Distributor and plug wires and she fired right up. (What a beautiful sound) There is oil in it and so although I don't know much about old cars I do no the basics of machines. I am just here for any information on where to go from here as far as electrical, fuses, transmission fluids, engine oil, engine components, Ill take any advice I can get, thank you in advance and I look forward to sharing my restoration. |
02-21-2018, 04:28 PM | #2 |
Re: 53 years young
Nice looking C30.
Welcome. |
02-21-2018, 04:38 PM | #3 |
Re: 53 years young
Wow that's a pretty dang good gift. I look forward to following your work.
02-21-2018, 05:12 PM | #4 |
Re: 53 years young
That's for sure a 70's era engine. And a GMC hood. Is the dash a Chevy or a GMC?
250's are pretty good engines. I did my truck as a driver- just replaced or repaired stuff as needed. It turned into a fun vehicle. Drove it to work today.
Everybody has to believe in something. I believe I'll have another beer. |
02-21-2018, 05:47 PM | #5 |
Re: 53 years young
Easy way to tell 250 from 292 is side covers are taller on a 292 (6"). If shorter it's a 250. Both great engines. The 292 has more power, but the 250 will wind out a little further, which you may prefer as that truck has some really low gears, probably 4.56
Enjoy your new project, keep it simple and refurbish original parts whenever you can and you will have a lot of fun and learn a lot.
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
02-21-2018, 05:53 PM | #6 |
Re: 53 years young
Thanks I figured it had to be a 250 based on the information I googled and the characteristics of it also, but thanks for helping clarify. Ill double check the dash but I am pretty sure its chevy, Ive spent more time focused under the hood than in the cab (naive noob). But I didn't know the hood came from a GMC? Will that affect any of the lighting then or will it be interchangeable with a Chevy?
02-21-2018, 05:54 PM | #7 |
Re: 53 years young
Thanks to everyone for their information, I am hoping to update every week or so.
02-21-2018, 05:57 PM | #8 | |
Re: 53 years young
02-21-2018, 06:07 PM | #9 |
Re: 53 years young
4.11's are real. Maybe used in an automatic trucks (at least that is where I have seen them) otherwise 4.56's
There might be a tag on the rear diff and if not you have to look at the ring gear and there will be numbers stamped on it, or just count the ring gear teeth and pinion gear teeth and divide the two.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-21-2018, 06:13 PM | #10 | |
Re: 53 years young
02-21-2018, 06:41 PM | #11 |
Re: 53 years young
Easier way to tell whether it’s a 292 or not is position of fuel pump. On a 292 it’s behind the motor mount.
Did you use a dedicated 12v power supply for your new hei? |
02-21-2018, 07:19 PM | #12 |
Re: 53 years young
I pick up a "refurbished," battery from a discount battery store, but I don't have the money yet for a good powerful battery. Ill check out the fuel pump location.
02-21-2018, 07:31 PM | #13 |
Re: 53 years young
Battery doesn’t matter.
What I meant was that your new distributor needs 12v power to it to run right. That means that you can’t hook it up to the original wire. The original wire is a resistance wire that only supplies 8 or 9volts to the distributor. I see you had an older hei installed. Maybe but not likely, the wire was already changed. Not hard to see in your pics that the pump is in front of the mount making it a 230 or 250. The other clue to your story is that Camaro’s never got a 292 from the factory. |
02-21-2018, 07:53 PM | #14 | |
Re: 53 years young
02-21-2018, 08:15 PM | #15 |
Re: 53 years young
Simply follow the wire to the junction box on the firewall.
If it’s cloth covered and the wire looks like aluminum, it’s the resistance wire. Your hei will function with it but the module might overheat. |
02-23-2018, 01:24 AM | #16 |
Re: 53 years young
You've got a 250 there buddy.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-23-2018, 10:05 PM | #17 |
Re: 53 years young
Ok I'll check it out and if anything Ill replace it with a stronger wire. Do you know is there anything with the fuses I should look into? Because I could not find very much information on the fuse size or what they would even function. I don't have a manual or anything for the truck when my uncle gave it to me.
02-23-2018, 10:38 PM | #18 |
Re: 53 years young
Usually you can read the fuse amps and what they’re for on the fuse box.
Of course after 50 years they might be a bit fuzzy. |
02-23-2018, 10:42 PM | #19 |
Re: 53 years young
Ok I will have to get in there and take a closer look then.
Would you know anything on the bolt pattern for the 8 lug?? |
02-24-2018, 12:43 AM | #20 |
Re: 53 years young
IIRC it’s 8x6.5.
02-24-2018, 06:00 PM | #21 |
Re: 53 years young
Thank god for advil cuz this truck is giving me a headache.
02-24-2018, 07:47 PM | #22 |
One foot in front of the other
Re: 53 years young
We can all relate.
02-27-2018, 05:37 PM | #23 |
Re: 53 years young
This maybe a dumb question but does the oil pressure always drop between startups? While trying to start it the oil pressure slowly goes up but then when I turn it off and go to turn it back on right after, the pressure has gone back to 0. *I have yet to get it started, I have to rebuild the carb but then all should be good to go*
02-27-2018, 08:48 PM | #24 | |
Re: 53 years young
It's a GOOD thing the oil pressure gauge moves at cranking RPM. Does it try to run and backfire/sputter or does it just crank with no try at all?
02-28-2018, 03:15 PM | #25 |
Re: 53 years young
Yes as I am cranking the engine over it slowly creeps up but I was just unsure if it is supposed to drop so rapidly after the engine is off. The engine hasn't yet been started and able to idle so I have not seen the pressure stabilize yet. Hopefully after this weekend I can get everything in order and put the carb back in and pray to some divine entity it starts.
Tags |
1965, c30, restoration |
