Old 02-23-2018, 03:19 AM   #1
jocko
jocko's Avatar
Post your "Special Paint" RPO truck (aka: the Definitive Special Paint thread)
The title says it all. There are a bunch of special paint threads posted throughout the forum and new RPO codes seem to be popping up every now and then, so thought it might be a good idea to start a one-stop-shopping showcase of original paint trucks with "Special Paint" RPOs on the SPIDs. So, the idea is post a pic of the truck and the SPID, and we'll start a library of sorts of Special Paint codes. I've yet to figure out how to decode the color by just looking at the RPO - have only been able to know what one should be by comparison to an original one. So, if that's the best we can do, it would still be helpful.
Lots of interesting tidbits on Special Paint floating around out there. "Normally" Special Paint terminology seemed to be used when a factory color that wasn't necessarily available on a light duty truck was used - or - when a non-standard two combination was used (not a "Custom Two Tone" though, as RPO codes existed for those HERE). For instance, I had a 76 K20 that was just good ol Orange. But in 76, RPO 88 orange was a medium duty or above color - so it took a Special Paint RPO to get it on my K20. That's just one example.
I'll go first, please share yours (or one that you have the info on, you don't have to own it of course)
71 Cheyenne Super
Special Paint RPO = 4001BB
69 C20 CST
Special Paint RPO = ZP3 (This one really confuses me, I think ZP3 evolved into a two tone combo code in the square body years, this is the only time I've seen it in this era. All other Special Paint RPOs I've seen in the 67-72 range looked like some variation of the one listed above for the Cheyenne Super).
Old 02-23-2018, 03:24 AM   #2
jocko
jocko's Avatar
Re: Post your "Special Paint" RPO truck (aka: the Definitive Special Paint thread)
70 C20 CST Longhorn
Special Paint RPO = 1001M1 (this is the Canadian-only Purple, I believe? - but I think I've also seen that same code for a Canadian only green...)
Ok, show us what you've got. Kevin, Robert! Post yours up too even though they are floating around in other threads! Thanks guys.
Old 02-23-2018, 09:54 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Special paint code ZP3 for a fleet color specific to Pacific Telephone & Telegraph.
Outside was repainted but interior was not. Toggle switch and lamp were for roof top mounted service lamp.
1969 C10 stepside short bed. 6-cyl 3 on the tree Chevy optioned with leaf spring rear suspension and heavy duty springs.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-23-2018, 02:53 PM   #4
Keith Seymore
Keith Seymore's Avatar
Special paint process, per author/illustrator/historian Eric White.
This was written specifically for Pontiac Motor Division, but you get the idea:
Originally Posted by Eric White
The procedure for getting a special-paint car ordered went like this:
• The customer (or dealership) determines what color is desired.
• An "All Series Special Equipment" order form is filled out.
The information required for a special-paint-request on this form is:
• Lower Color Paint No.
• Upper Color Paint No.
• Make of Car & Year Paint Used.
I am guessing that obtaining the correct paint no. would be left up to the ordering salesman/dealership paint department.
In the '60s and early '70s, before colored plastic/fiberglass trim parts became common, any color paint could be ordered, as long as the dealer could supply the paint formula no. on the S.O. form. After the mid-'70s when the crash-bumper fillers became common place, special order colors were phased out except for large fleet orders.
Several codes were used on the Fisher Body trim tag to indicate a special-order paint. Codes varied between the years and between Fisher Body plants. Some of the codes used were:
1= Standard GM paint, not a Pontiac color
2= Special Pontiac color. Sometimes offered a half-year "springtime" color.
3= Cadillac FireFrost color. This paint was not normally allowed on a Pontiac build because of the special processes required to apply this type of paint.
4= Body in primer
SPEC or ** would indicate a paint color from a source outside GM (Ford, Chryco, AMC, John Deere, International Harvester, etc.) Colors could also be ordered to match school or business colors. As long as a formula no. could be identified by the dealership just about any color hue could be specified.
• The order was then routed through the Pontiac Zone office, which then routed it on to the Central Office.
• Central Office then entered a request to the paint supplier, usually PPG/Ditzler, for the appropriate paint.
• The paint supplier shipped a quantity of paint to the appropriate assembly plant.
• The special-order build was scheduled and coordinated between the Fisher plant and GMAD or Pontiac assembly.
• Build was delivered to dealership with a quart of touch up paint in trunk.
I would add that, back then, GM would paint one car using this process, if requested.
For Pontiacs the cowl trim tag will indicate the vehicle received a special paint color but will not designate what that color was; It is not documented anywere including through Pontiac Historic Services. The only real way to determine is to pull off rubber trim or otherwise disassemble the car and look for remaining splashes of the original color.
These days you have to have a minimum of 10 or so, and it is not available to the general public but more specific to fleets and special orders (police, Mary Kay, Grand Trunk RR, RCMP, etc).
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-23-2018, 02:54 PM   #5
Keith Seymore
Additionally, when we painted special colors or fleet orders in the assembly plant we did not use the regular paint supply system.
In Flint they had a separate and distinct setup with smaller paint "pots" which could be loaded with the specific color, used, and then purged with less waste than the high volume production system.
Some of the other locations did not have this and would run special colors through their paint repair line in the paint shop.
K
1979-1986
1986 - 2019
Old 02-23-2018, 04:43 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Special paint. Loaded with some nice options too. All it needs is a K chassis under it....
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-23-2018, 05:54 PM   #7
54blackhornet
54blackhornet's Avatar
This is mine, 71 C-20 ordered originally by Burlington Northern Rail Road, delivered new in Seattle.307 4spd, power brakes, heavy duty rear springs , pozi, white painted bumper. 52000 original miles. It’s beat up pretty good around the bed area, but amazingly dependable.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-23-2018, 07:10 PM   #8
HO455
HO455's Avatar
I remember when the Burlington Northern took over the railroads through north Idaho. That green was a pretty wild color at the time and it seemed like for a while everybody was talking about it especially after the black engines they were running before. There was a guy who worked for them down the road from us and often had a 1 1/2 ton service truck parked at his house that was the new green with the angled white stripes on the back of the service boxes. I don't remember what kind of truck it was but boy was it bright. When they were freshly painted they really popped
http://www.carrtracks.com/idnp1456bn8104.htm
Now back to your regularly scheduled thread.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 02-23-2018, 07:29 PM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
Working on finishing this one. Long story but I found the original salesman that ordered this for his friend 'Charlie'. The special paint was Black Cherry, a Chevelle color for 1970.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-23-2018, 08:52 PM   #10
ElKotze
ElKotze's Avatar
558 dark blue/med. blue.Unfortunately it has been repainted to light blue/ white. Will start a tear down as soon as it warms up a little. Plans are to paint it back to original color. It's not a special color but fairly rare.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 02-23-2018, 09:36 PM   #11
jocko
jocko's Avatar
RenoKeene, THAT is cool. Black cherry is a great color.
Just to be clear, there is a difference between a "Special Paint" RPO and a "Custom Two Tone" RPO. My 557 truck, for example, is a Custom Two Tone - you can see these in the LINK posted in the very 1st post in this thread. Special Paint are ones that actually state Special Paint on the SPID, i.e. no actual colors listed - and the need for a thread to group all the examples so we can figure out what unique colors and combos are out there. ElKotze, for the record, I think your 558 is about my absolute favorite paint that was available on these trucks. I like my 557, but 558 to me is about the best looking combo out there.
Old 02-23-2018, 09:39 PM   #12
70cst
70cst's Avatar
Originally Posted by RenoKeene View Post
Working on finishing this one. Long story but I found the original salesman that ordered this for his friend 'Charlie'. The special pant was Black Cherry, a Chevelle color for 1970.
Me like
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-23-2018, 10:04 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by 70cst View Post
Me like
That is so close to the paint code 77 Marlboro Maroon that I just figured people were getting it wrong. I worked for a Chevrolet dealer on and off from '70 to '72 and never saw the code 78 Black Cherry. But it was a small dealership, so we probably just didn't sell enough cars to get one that color.
~Steven
Simi Valley, CA
Old 02-24-2018, 12:40 PM   #14
RenoKeene
Florida Edition
RenoKeene's Avatar
Here's a daily double...67 with a SPID and Special Paint. Really hard to make out but says SPECIAL in the PAINT box at the top. Was originally Orange under the Black. Unfortunately I have no history on this one.
Old 02-24-2018, 01:14 PM   #15
jocko
jocko's Avatar
Thanks for all that great info Keith! Very helpful.
Old 02-24-2018, 03:28 PM   #16
KevinK7
KevinK7's Avatar
I've already posted this, but to bring it into this thread.
1968 with "SPECIAL PAINT 91001LG" on the SPID.
link to original post/thread for reference (http://67-72chevytrucks.com/vboard/s...83#post8195883)
KevinK7 is offline   Reply With Quote
Old 02-24-2018, 03:32 PM   #17
jocko
jocko's Avatar
Thanks very much Kevin - was hoping you'd bring your recent post over here. Yours was the most recent in a bunch of separate threads about Special Paint RPOs, so thought it might be nice to get some one stop shopping. Really like your truck!
Old 02-24-2018, 07:27 PM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
70 C20 CST Longhorn
I owned that truck 3/4 years ago. Mark do you remember where you got the picture from as I never seen that pic of the truck. As you can see in the Spid the first digit number in the serial number is kinda scratched out and when I was dealing on it I thought the seller was trying to hide something but he wasn't..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-26-2018, 10:10 PM   #19
jocko
jocko's Avatar
I didn't realize that Greg! Sorry. I kinda thought in the back of my mind that you had a Canadian purple in addition to ol Pinky, but I didn't think you had a Longhorn. I believe I got that pic from Tim in approx. 2014-ish. Didn't know anything else about it (or I forgot).
Old 02-26-2018, 10:16 PM   #20
jocko
jocko's Avatar
Here's one I saw on here not too long ago, but I don't remember how old the post was when I found it. At first glance, appears to just be ochre, but on closer look, appears darker, more brown in it than ochre. Not sure what it is... Nice K20 though! Special Paint Code: 4001BB
It's also possible (likely) this is a repaint, it's not a "known" original paint truck, but it doesn't look like it was repainted in a stock color either. Is this a members?
Old 02-27-2018, 12:53 AM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
That definitely isn't ochre. I wonder what color it really is. Nice, in any event.
~Steven
Simi Valley, CA
Old 02-27-2018, 04:16 PM   #22
Already Gone
Nothing to be sorry about..
Old 02-28-2018, 10:18 AM   #23
mr.precision
mr.precision's Avatar
Interesting. My 1970 has the identical special paint code, and the truck is white. I mean white all over. If there is a non-white color anywhere I cannot find it. Lots of things can happen in 48 years I guess.
mr.precision is offline   Reply With Quote
Old 11-30-2020, 02:29 PM   #24
GJB
Active Member
Just bringing this one back to the top in cases anyone had anything to add.
GJB is offline   Reply With Quote
Old 11-30-2020, 02:48 PM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Member argonaut has this beautiful highlander Blazer (please sell it to me ). http://67-72chevytrucks.com/vboard/s...d.php?t=741141
Blue original paint I guess? Any way to decode what paint was used?
special paint
