02-19-2017, 11:03 AM | #26 |
Re: Babe: The Blue Ox
I love the gauges! Check Vintage Air for the vents, I be they have something that will work. Great progress!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-21-2017, 02:46 AM | #27 |
Active Member
Porterbuilt hood hinges installed. Also installed the hood brackets from Hart_Rod. Worked out good!
-Chad '72, C10, SWB, fleet, 4L80E, 406sbc, EFI, TruTrac Blackfoot '69 C20 Suburban, PB Dropmember, 3rd row, LS3 6.2L, 4l80e, rear A/C, Dakota Digital HDX Babe: The Blue Ox |
02-21-2017, 09:20 AM | #28 |
Looks awesome!
03-08-2017, 11:46 AM | #29 |
Awesome. So glad someone is dojng a mild rear before i do on a suburban. Im doing the same. Got to keep. The rear row seats for the cool factor
03-11-2017, 03:10 PM | #30 |
Wow! That will be a fun Burb! Are you going to open up the rear wheel wells any, or will that effect your rear seat?
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
06-03-2017, 04:28 AM | #31 |
Active Member
Making more progess. Shaved firewall
06-03-2017, 04:30 AM | #32 |
Active Member
looks like I may have to shorten the seat by an inch but maybe I can squeeze it in there without cutting it. We'll see
06-03-2017, 04:37 AM | #33 |
Active Member
Mocking up rear end. I went with a 9-inch with Detroit trutrac
06-03-2017, 09:13 AM | #34 |
The hood plates look grat under there!
11-25-2017, 06:30 AM | #35 |
Any updates on this project
02-27-2018, 04:08 AM | #36 |
Active Member
Made a bunch of progress since my last post.
I love the look of these Wilwoods
02-27-2018, 04:22 AM | #37 |
Active Member
Prepped underneath then sprayed with truck bed liner. This is gonna be my daily driver so need to make it durable.
02-27-2018, 09:08 AM | #38 |
Any pics on how you did the cover over the rear notch and did you widen the tubs.what size tire ate you running ?.sorry for all the questions.im doing the exact same notch in my burbon .with intentions on a 20x12 rim
02-28-2018, 02:50 AM | #39 |
Active Member
I have 20x11 in the rear. I had to widen each tub by 3" (I think). Here are some pics of the cover for the rear notch. I also had to cut about 4" from the middle section out of the 3rd row seat. Hope that helps
02-28-2018, 02:58 AM | #40 |
Active Member
Parts back from powder coating.
02-28-2018, 03:07 AM | #41 |
Active Member
A buddy made this aluminum fuel tank for me.
02-28-2018, 08:53 AM | #42 |
Looks great!
02-28-2018, 01:25 PM | #43 |
Looking good! I would love to stop by and take look at this burb sometime.
02-28-2018, 07:59 PM | #44 |
Looking Good must be nice to have a shop and skills. Lol.
Been working on my in the dirt and snow. Looking forward to seeing how you'll be doing the 3rd seat.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
03-01-2018, 02:54 AM | #45 | |
Active Member
I'm further along than the photos show but It's taking me a while to post progress on here. We should definitely meet up sometime. I really like your build.
03-01-2018, 03:12 AM | #46 |
Active Member
Accuair setup. Credit goes to my friend Zach Airth (Airth Defined Hot Rods). He does awesome work. The wood is in excellent shape for being nearly 50 years old.
03-06-2018, 03:51 AM | #47 |
Active Member
Putting stuff together for the final time.
03-06-2018, 08:59 AM | #48 |
Fantastic job! Can't wait to see this on the road, .
03-07-2018, 02:48 AM | #49 |
Active Member
Heat shields for the air lines
03-07-2018, 02:59 AM | #50 |
Active Member
I know some of these images might be out of order, but I've done a pretty lousy job at organizing them, so just go with it.
