Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-01-2018, 09:13 AM   #23
CJM72
Re: 3 Kids, 1 Wife, and 1 Lonely Blazer
Originally Posted by ls1nova71 View Post
Just reading through your thread and noticed something. You're correct that the power steering pump with 2 ports is from a hydroboost equipped truck, but if you're not running hydroboost, then you need to cap off the upper fitting on the reservoir and plumb the return from the steering box to the lower one. Running it to the top fitting can cause fluid foaming, which is why they return the fluid to the bottom of the reservoir.
Wow, thanks for the heads up! I capped the bottom port and couldn't find much info on how to plumb the dual return pump. Should be a bit of a challenge to make the turn around the frame without hitting the pulley! Would like to convert to hydroboost eventually though.
I have some family stopping by to help put the front clip on tonight. Guess I'll have to fix it the hard way this weekend with the inner fender in the way.
CJM72 is offline   Reply With Quote
