Old 03-02-2018, 02:53 AM   #101
Woodyboat
Woodyboat's Avatar
Re: Shop truck build
If he's all that much of a Ford guy, maybe you can talk him out of that lil red truck. It's worth a try...
Dave
Woodyboat is offline   Reply With Quote
Old 03-08-2018, 10:17 PM   #102
Whamo
Whamo's Avatar
Carpet and seat back in...yeah, I know, I know, seatbelts don't match - I'll get to it..
Temporarily installed the dash...need to paint the interior sheet metal and get it black...but wanted to see if I hated it - I don't...I left all the dents and flaws on purpose...
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 03-08-2018, 11:59 PM   #103
Different look. Nice job!
Old 03-09-2018, 08:09 AM   #104
Whamo
Whamo's Avatar
Thank you Bill!
Old 03-18-2018, 02:37 AM   #105
cable666guy
cable666guy's Avatar
That dash doesn't look bad at all !! The whole slower than you wanted to deal, I can relate. I was aiming for slow and steady, I ended up with slow and sporadically !! Keep plugging away !!
cable666guy is offline   Reply With Quote
Old 03-18-2018, 08:34 AM   #106
Whamo
Whamo's Avatar
Thank ya Cable666guy...
and the hits keep a'coming...1st one to spot the problem wins a cookie...
Old 03-18-2018, 01:46 PM   #107
StorminNorman
pinion angle ?
StorminNorman is offline   Reply With Quote
Old 03-18-2018, 02:51 PM   #108
Whamo
Whamo's Avatar
Originally Posted by StorminNorman View Post
pinion angle ?
Would you like chocolate chip or snickerdoodle...
Old 03-18-2018, 06:27 PM   #109
StorminNorman
How did you lower the rear ? Extended shackles ? I would have thought they would angle the pinion even more down.
Weird. Somethings not right there. Especially on a leaf spring suspension where the pinion will rise under torque, And is usually set pointing down for that reason.
Old 03-18-2018, 08:47 PM   #110
Whamo
Whamo's Avatar
Belltech shackle and hanger kit for a 4" drop...3" in the front...I'm a bit stymied...
Belltech says it happens and just to shim it...
I've helped with lowering before and not seen this happen...advice please
Old 03-18-2018, 09:08 PM   #111
StorminNorman
I am working on lowering mine so don't have much to add. Mines a flip job.
But, Get the angle finder out and see what angle the engine/trans is sitting at compared to the rear axle.
Old 03-22-2018, 04:18 PM   #112
Whamo
Whamo's Avatar
After adjusting, maneuvering, swearing and measuring...I believe 4 degree shims will get things back in place...they have been ordered...
Old 03-25-2018, 07:52 PM   #113
Whamo
Whamo's Avatar
While I am clearly not finished, I looked back over this thread to see all that I've accomplished and how much I haven't...here are my thoughts...
- Dang it took a long time to get my arse movin on this thing...
- Belltech just works...
- I still prefer long beds (but dig shortys)...
- Experience is truly the best teacher...
- Necessity is clearly the Muther of invention...
- Roadkill has changed what I now consider cool...
- Frustration is accomplishment being grilled to medium rare...
The road goes on forever and the party never ends............
Old 03-29-2018, 05:53 AM   #114
Whamo
Whamo's Avatar
The shop truck is buttoned up and ready for a shakedown...
https://youtu.be/hUDAwfXfs-8
Old 03-29-2018, 11:20 AM   #115
Whamo
Whamo's Avatar
To back up a bit...I ended up needing 6 degree shims to get the pinion angle right...what can we learn from this? If you are lowering a long bed with a 2 piece driveshaft...plan on gettin shims.
Here is a slo-mo of a baaad pinion angle...
https://youtu.be/H0yjIEpIuw8
Old 03-31-2018, 02:25 PM   #116
Whamo
Whamo's Avatar
rolling her back into the shop...I guess my burnouts took a toll on the carrier bearing...
https://youtu.be/ZcOeABl6-bg
Old 04-16-2018, 08:43 AM   #117
LT7A
I'm enjoying watching your take on modifications. I think that dash came out startlingly well. 'Frustration is accomplishment grilled to medium rare' cracked me up. Keep at it. All of it. The truck, helping at the mission, the life philosophy.
We're a couple of the lucky few who get to go through being torn down, and building back up.
LT7A is online now   Reply With Quote
Old 04-17-2018, 07:21 PM   #118
Whamo
Whamo's Avatar
Thank you for the kind words LT7A...and about being some of the lucky few...Right On Brother!
Old 04-19-2018, 02:44 PM   #119
Whamo
Whamo's Avatar
Put a lot of effort into my center console / cup holder...it’s functional and secure!
Old 04-28-2018, 11:39 AM   #120
Whamo
Whamo's Avatar
Dash prep and mock up...150 year old barn wood
Old 04-28-2018, 11:41 AM   #121
Whamo
Whamo's Avatar
Still need to cut air vents in wood...
Old 05-01-2018, 09:48 PM   #122
Whamo
Whamo's Avatar
I see no issue with this sitting on my stove!
Scored this intake for $40 today...anxious to slap it on...
Old 05-03-2018, 02:39 PM   #123
LT7A
Whamo, remind me of the specs on your motor? You may want to look up the target operating range for that intake. It's a great-looking Edelbrock and you got a deal on it. It just looks like it's made to make power at high RPM to me.
Old 05-22-2018, 01:14 PM   #124
Whamo
Whamo's Avatar
...good observation! Just collecting parts for a future build my friend...
Old 06-18-2018, 08:27 AM   #125
naphtali5725
naphtali5725's Avatar
the dash looks awesome!!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
