#351 | ||
"I ain't nobody, dork."
Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
I had recently installed CPP 4" HD rear drop springs to replace the standard CPP 4" drop springs. While I was in there I installed the CPP rear shock relocation brackets too. Now the truck can be used as a truck again, and still have a lowered stance. The HD drop springs make a HUGE difference over the standard drop springs as far as hauling and towing capability. The new shock brackets gave me over an inch more of shock travel as well. Complete difference!
It was a gorgeous day here in the PNW this past Monday. It was my day off and I was headed over to my stepson's place to assist him with his "1970 C20 conversion to C10 project". So I stopped out by our mailbox on the backroad we live on, and snapped a couple of pics. Still no hood on the heap yet... which makes it look kinda mean when ya see it. ![]() Pics are of the new HD springs, Shock relocation brackets... and of course the heap... ![]() Gary
#352 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looking good, it's nice to see it out and about
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#353 | ||
I had mentioned that the rig has a bad vibration somewhere around 45-55 mph. I have yet to have the drive line balanced, but did some research on driveshaft "phasing". I had taken the 2 piece shaft apart when I put new U-joints in it. Just made it easier to handle while using a press by myself. Anyhoo... I marked the 2 halves before I separated them so I could slide them back together the same way it came apart.
I either screwed something up when putting them back together or the drivline was out of phase in the old frame and I just never noticed. ![]() Took it for a quick test drive and the vibration is pretty much gone! I have some road feel through the steering wheel and front end. but I have to still get the rig to a professional alignment shop. I am still going to get the driveline balanced as well. Stay tuned... ![]() Gary
#354 |
Sounds like good news to me.
#355 |
Well isn't that the S*I*s!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#356 | ||
Progress has been kinda slow as we've been busier than a one legged cat burying a turd around here...
![]() But I finally got all the old seam sealer out of the drip rail "ditch", and then wire wheeled it, and gave it a good dousing of Rust Mort. After it sat for a week I masked it off yesterday and hit it all with some self etching primer. Will do one more coat of primer before I start on the self leveling seam sealer. I bought self leveling sealer from 3M, and an applicator gun made by Cox Industries. Got it all off of Amazon. I'll report back when I have the area sealed up. I looks like I'm gonna have to raise the rear of the truck to make the front edge of the drip rail "ditch" fairly level. The pinch weld is towards the front, and I want the sealer to stay over the seam instead of pooling at the back along the roof line. Gary
#357 |
Nice, kinda wondered myself how runny that stuff is and what to do about the down side (back of windows) to make sure it stays thick enough.
#358 |
![]() Join Date: Mar 2017
subscribed
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
#359 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
#360 |
Subbed for the story, great inspiration
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
#361 |
![]() Join Date: Jan 2012
How did those drip rail sealant products work out? Any issues applying it? I saw you mentioned possibly having to jack the back of the truck up. How's the truck looking now?
