Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-14-2018, 07:00 PM   #226
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
thanks for the orders!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 03-11-2018, 02:01 PM   #227
'70_402
'70_402's Avatar
Interested in a radiator with fans for a '68 with an LS swap and auto trans.
Do they use "Fbody" style fans? That's what my wiring harness is built for.
'70_402 is offline
Old 03-11-2018, 06:29 PM   #228
SparkyRnD
SparkyRnD's Avatar
With some modifications you can use the factory fan shroud, or we have an electric fan and shroud kit. My guess is you would have to do some modifications to accept an F body fan set
Old 03-11-2018, 08:33 PM   #229
'70_402
'70_402's Avatar
What kind of connections do your fans have?
What the easiest way to order?
'70_402 is offline
Old 03-11-2018, 08:49 PM   #230
SparkyRnD
SparkyRnD's Avatar
Our fans will either have a plastic Molex connector, or they will have bare ends. I recommend using weather pack connectors as they are able to be easily disconnected if needed and are weatherproof. To order, simply send me a private message with your email address, ZIP code, and what you want to order, along with what engine and transmission you have Etc
Old 03-20-2018, 06:31 PM   #231
SparkyRnD
SparkyRnD's Avatar
up top!
Old 03-30-2018, 10:33 PM   #232
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have a '70 C20 with a 402 (bored, but don't know how much), 400 trans, AC and tow a 6000 pound travel trailer. I'll be pulling the engine out for a rebuild soon, and was wondering about an aluminum radiator. It currently runs pretty hot, so I'm going to replace the fan clutch with a higher duty one. It has a 4-row brass radiator in it at the moment. I may go to a 454 if this engine can't be bored again. Sleeving is out of the question, given the cost, if it can't be bored again. What do you have for this application
Thanks,
Steve
~Steven
Simi Valley, CA
Steeveedee is offline
Old 03-31-2018, 10:53 AM   #233
SparkyRnD
SparkyRnD's Avatar
our normal rad will work fine for both engines
Old 03-31-2018, 02:34 PM   #234
Steeveedee
Who Changed This?
Steeveedee's Avatar
Ok
~Steven
Simi Valley, CA
Old 04-05-2018, 03:32 PM   #235
sangell
Edit: Thanks for getting back to me.
Sparky,
Please check your emails, I need an update.
Thank You
Scott
sangell is offline
Old 06-01-2018, 11:59 AM   #236
SparkyRnD
SparkyRnD's Avatar
back up!
Old 06-13-2018, 01:03 PM   #237
SparkyRnD
SparkyRnD's Avatar
Old 07-03-2018, 10:39 AM   #238
scoobiedoo01
Sent you an email for a order and a couple questions.
Thanks!
scoobiedoo01 is offline
Old 07-05-2018, 01:02 PM   #239
SparkyRnD
SparkyRnD's Avatar
thanks, replied!
Old 07-21-2018, 06:44 PM   #240
Ctgry5
Need quote please. 1972 GMC Jimmy 2 wheel drive 454 with th400 auto tranny. Thanks in advance.
Ctgry5 is offline
Old 07-21-2018, 06:50 PM   #241
Ctgry5
Forgot to state that I need the whole package... plug and play as they say... radiator, shroud, dual fans, relays, connectors, polishing if available, radiator cap, installation hardware, everything please. Thanks
Ctgry5 is offline
Old 07-21-2018, 08:20 PM   #242
SparkyRnD
SparkyRnD's Avatar
pm sent!
Old 08-08-2018, 07:24 AM   #243
elf w/capital T
Bump to the top for RnD.
You said you can do both ports on passenger side and sized for the LS motors, by chance are they 1-1/4 top and 1-1/2 bottom? If not, thats going to be on my request, no trans adapter ports either. I am getting excited!
elf w/capital T is offline
Old 08-09-2018, 11:03 AM   #244
SparkyRnD
SparkyRnD's Avatar
We can get various sizes depending on what you need. Just make a note when ordering and we'll confirm.
Old 08-27-2018, 08:50 PM   #245
fast2002
Could someone tell me how to contact a person RnD to get an update on radiator delivery I have left several messages by phone and e mails. bbsports@msn.com. Thanks
fast2002 is offline
Old 08-27-2018, 08:56 PM   #246
elf w/capital T
Sparky email is info@rndfabrication.com
Old 08-27-2018, 09:41 PM   #247
sangell
After multiple emails, left voice messages, and private messages on here I ended up having to post in this thread for him to check his email, VM, and PMs then get back to me. He did get back to me pretty quickly after that, what I was told and have no reason not to believe was at the time he had been out of town and was also having trouble getting the correct size cores from his supplier. I ran up against a deadline and had to go elsewhere but that happens sometimes in this game of old trucks and custom parts.
sangell is offline
Old 08-27-2018, 09:54 PM   #248
fast2002
Did you get refunded who did you go with.
fast2002 is offline
Old 08-27-2018, 10:08 PM   #249
SparkyRnD
SparkyRnD's Avatar
Steve, your radiator is still about a week or two out. I wonder if my emails are going to spam / junkmail? I'll send a test email in a few with 'radiator' as the subject
Old 08-28-2018, 10:56 AM   #250
sangell
Yes I got a refund, I'll send you a PM with the other info as I don't what to put competitors name in RnDs thread.
I would not hesitate to run an RnD Fab radiator and have no ill will towards them, things just didn't work out for us.
Edit: fast2002 the forum won't let me send you a PM. If you search for my build thread in the 67-72 forum you can see what/who I went with.
sangell is offline
Closed Thread
