03-14-2018, 09:58 AM | #26 |
Re: Dana 44 Front axle no oil?
Look for a 1971 to 1976 big hub Dana 44. These all use the same locking hubs as yours, and it is a direct bolt in. The only changes will be what I noted, brake master cylinder, proportioning value and brake lines.
If you watch for a while you can find good deals on these. The first thing you need to do is figure out your gear ratio. If you find one with the same ratio, your way ahead money wise. Pull the cover and do an inspection if it has been sitting, walk away if you see any rust. Good luck. Last edited by outfield; 03-14-2018 at 04:11 PM. |
03-14-2018, 12:23 PM | #27 |
Ok excellent, thanks for the info I will keep my eye out for a big hub axle. I know that my gear ratio is 4.57. That axle that I found for sale looks like it is the small hub, so I will keep looking. My truck has a brake booster and a master cylinder that was installed by the PO so I dont know very much about it but I dont think its original to the truck. I am assuming it may be out of a later model square body truck but Im really not sure. Ive attatched some pics of what I have, maybe someone can help identify these parts?
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
03-14-2018, 12:36 PM | #28 |
Yep, basically looks like mine. Mine had the booster added too. I'm still drum brakes front and rear too.
The Disc/Drum master has a larger reservoir for the front then the rear, and the brake proportioning valve looks similar, but is different. Do some more searching on the forum, there is a lot of good info. This is where I learned about it. |
03-14-2018, 03:49 PM | #29 |
Just in case you decide to stick with an original axle and don't mind driving to Michigan
I have a set d44 and h052 w4:56 gears I'll be listing for sale next week Both were driving and stopping when I removed them 3 weeks ago from my 67 k20 for an axle upgrade Just an option Good luck |
03-15-2018, 12:49 PM | #30 | |
03-15-2018, 12:51 PM | #31 | |
03-15-2018, 01:23 PM | #32 | |
Just installed front this past weekend it is a direct swap everything bolts up nice Used the 76 steering linkage Have fun Good luck Almost forgot the rear need to move spring pads inward 2.5inches total And reposition shock mounts Last edited by Mts67C10K20; 03-15-2018 at 01:27 PM. Reason: More info |
03-15-2018, 10:14 PM | #33 |
Ok awesome thanks for that info. I posted an ad and found a guy a couple hours away who has a few trucks. He says he has a Dana 44 out of a '76 Military truck with the 4.57 gear I need. He also said he MAY even have a Dana 44 front and a matching Dana 60 rear out of a '72 GMC... both with a 4:10 gear! Awesome!! So as far as I know that would be a direct bolt on, front and rear, to my truck. Can someone confirm this for me please??
Either way it sounds like he is going to be able to help me out. He says he even might have the other brake parts I need to complete the job.
03-16-2018, 09:50 AM | #34 |
Yes, the 72 GMC axles would be a direct bolt in. Once again, if they have been sitting around, pull the diff covers and inspect for rust.
I'm changing out the 4.56 geared axles in my '69 K20 for 4.10 geared axles to help with highway RPM's and the disc brake upgrade up front. |
03-16-2018, 10:14 AM | #35 |
Excellent find
If the inspection pans out the 72 stuff is perfect Think you'll like the 4.10s endless your running tall tires Don't forget the master old prop valve for the front disk Good luck |
03-16-2018, 11:59 AM | #36 |
Agree with above. Plus my two cents.
I think the 4.10s are a good middle compromise for all around usage. But if you're set on a tire size for sand, mud or highway, now's the time to calculate for good gear/tire combo based on where you want the truck to perform best. For highway, I like the 4.10. You can still pull some weight up a hill, especially if you stay 31 or 29". Here's another thing you can do after you put in the axles. You can borrow different tire sizes from buddies and stick them on the rear and run it and see if you like where the sweet spot is. Really takes the calculated theory out the decision before you buy tires... tires ain't cheap! Of course once you've owned the truck a while you'll be telling us! j
White K20 |
03-16-2018, 01:07 PM | #37 |
Ok so unfortunately the Dana 60 rear end is no longer available. But he does still have the other axle with the 4.57 gear in it. He says it is a full time axle... should I be concerned about excessive wear?
I'm currently running BFG 35s on my truck and I would like to stay with a 35in tire. What do you guys think about 4.10s with 35s? I don't really do any highway driving, mostly just around town and a little off road as well. I also haul a 6x10 cargo trailer occasionally. The more I think about it maybe I should just keep my 4.57 gear. I'm happy to cruise at 55 and my truck turns about 2700rpm (although I think my tach reads about 200 rpm high). The truck has a 307 and the sm465 trans Thanks again for all the info guys I'm learning a lot here
03-16-2018, 01:13 PM | #38 |
If you are happy with the HWY RPM's with 4.57 gears and 35's, and having the 307, you would be better off sticking with those gears.
I have a 350 with the SM465, I'm running 33's, that's why I'm going to the 4.10's |
03-16-2018, 01:16 PM | #39 |
Some day I would like to upgrade to a 327. What do you think of that? Would I still be happy with my gear?
03-16-2018, 06:08 PM | #40 | ||
I agree, if you like what your getting out of your current setup... why monkey with success? j
White K20 |
03-18-2018, 09:26 PM | #41 | |
For now I sealed up the crack in my diff and filled it with that corn head grease just in case. I ran the truck enough to make sure everything was coated nicely. No leaks yet, but I'll keep an eye on the grease in there, and I'm on the hunt for a nice Dana 44. Once I find one I'll swap it out, but I think I'll keep my rear axle and stick with my 4.57 gears. Thanks again for all the help and great info to everyone who replied and helped me out. Very much appreciated!
04-09-2018, 09:44 PM | #42 |
Hey guys... So I'm back with some more questions. I've been looking around for a nice Dana 44 out of a 71 - 76 truck. I've found a few, but so far they're all with a 4.10 gear. I did find one with my gear ratio of 4.56, however it was from a 77 truck and had the smaller hubs. I want the big hub style so I can reuse my locking hubs i currently have on the truck. So my question is this: can you take off the hubs, spindles etc and install hubs and spindles from an earlier model of axle? Will it bolt right up? Are the axle shafts still the same? Or is this too much hassle and should I just wait to find exactly the axle I want
My next question is: my axle currently in the truck has the power-lok posi unit. I wanted to take that out and reuse it in whatever new axle I find. Can I do this without having to worry about the lashing of the gears? Or if I change the carrier will that throw everything else out of alignment? Thanks
04-10-2018, 02:55 PM | #43 |
Hi K68,
To use the 77 axle, and have big hubs, you will need to find a 1971 to 1976 bug hub axle to pull the bearing hubs and possibly the spindles off of. Then you could convert the 77 axle to big hubs. it may be more trouble then its worth, but that is up to you... The 77 axle shafts will be the same. I believe you could use your Power-loc, but I would check with a gear guy to make sure. You would want a gear guy to do the swap, ge will need to set up the gears. this will cost a few bucks too. |
04-16-2018, 03:43 PM | #44 |
Thanks for the info... I was thinking if I found an axle with my proper gearing I wouldn't have to take it to a shop which would save me a few bucks. However if I want to reuse my powr-lok unit Ill have to take it in to a shop anyways. Im thinking what I may end up doing is going with the 4.10 axle I found, and completely rebuild it with a new ring and pinion in my 4.56 gear. Ill replace all the bearings and put new clutches in the powr-lok so everything is good to go. It will be expensive, but then it will be done and Ill never have to worry about it again. I know it will be an awesome upgrade for my truck, and I dont mind spending the money on the truck because I plan to keep it for a very long time.
The guy with this 4.10 axle says he also has a master cylinder and prop. valve out of a 1970 truck which was disk brakes and 4x4. Does anyone know if that will work? Thanks again.. Ill update my progress as I go along
04-16-2018, 04:30 PM | #45 |
Since the master and prop valve were from a truck with the disc brake swap, yes, they will work.
04-16-2018, 05:57 PM | #46 |
My truck has power brakes, if I change out my master cylinder will my brake booster unit still work properly?
04-16-2018, 08:58 PM | #47 | |
I see an axle truss and I suspect this truck has done some hard wheelin'. Probably gotten air a time or two or smacked a rock or two. The truss ain't so pretty either
06-24-2018, 11:52 AM | #48 |
Thanks to everyone who contributed to this thread and helped me along, I learned a lot and I really appreciate all the great info I received from everyone. Just a quick update... I went to a scrap yard and found an open knuckle Dana 44 in my gear ratio. I bought it and brought it home, however when I got it home I discovered the pinion gear was all chewed up (I had inspected it at the junk yard but the ring gear looked fine and I couldn't tell that the pinion was screwed) So I searched for a new gear set and ended up finding an axle out of another 68 K20 a guy had for sale locally. I bought it just for the gears and original locking hubs, but when I got it home I took it all apart and found it was in really good shape. I took both axles to a local shop and was going to have them swap out the gear set from the closed knuckle axle to the open. However they took a look at the open knuckle axle and figured it needed a total rebuild, and were quoting me $2600 to do it. I thought for a while and decided that I could take the good closed knuckle axle, bolt it in my truck and save myself a lot of money. Like I say, the axle was in great shape and there was nothing at all wrong with it. So that's what I decided to do for now, and I'm currently in the process of swaping it out. I still kept the junkyard axle, and someday I may go ahead and install that. But for now it was just way simpler and easier to put the good closed knuckle axle in the truck and run it that way, and I'm happy with that.
Thanks again for everyone who helped me out!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... Last edited by 1968_K20_4x4; 06-24-2018 at 11:57 AM. |
06-24-2018, 11:55 AM | #49 |
Here's how I'm making out so far... old axle out and new one ready to go in
