03-15-2018, 05:01 PM | #1 |
Front Axle Identification chevy 3100
Can anybody advise me how I can tell from the front axle and spindles only ( no drums or rotors present)whether I have a 3100 (1/2 ton) or 3600 (3/4 ton) axle on my truck.
I need to buy a set of rotors but It looks as though the front axle has been swapped before I bought it. Hopefully for another 3100 truck axle. My truck is a 1952 3100 pickup. Any help would be really appreciated. |
03-15-2018, 06:20 PM | #2 |
Re: Front Axle Identification chevy 3100
Howdy,
One way to tell is that 3/4 ton trucks have more robust steering arms. 3100: 3600: |
03-15-2018, 06:32 PM | #3 |
Brilliant thanks, i'll check that out tomorrow.
Much appreciated. |
03-15-2018, 08:20 PM | #4 |
Measure the diameter of the spindle. The 53-59 3600 trucks used a 1.49” inner bearing. The 47-52 used a 1.4” bearing
03-16-2018, 12:14 AM | #5 |
Scroll down to page 128 and it gives the differences between the axle. https://www.gmheritagecenter.com/doc...olet-Truck.pdf
After seeing that you should be able to tell with a quick tape measure check.
03-16-2018, 04:34 AM | #6 |
Thanks for all three reply's.
I snuck in the Garage this morning before setting off to work and confirmed I do have a 3100 axle and spindles. Brilliant. Thanks so much for taking the time to help. |
03-16-2018, 12:08 PM | #7 |
I learned something when I looked that up. I knew that there was a difference in the axles but didn't know what the exact difference was.
03-16-2018, 03:25 PM | #8 |
