Old 01-17-2018, 12:25 PM   #1
Jsfucttruck
Manual 465 to 90v20 Burb q's
So my friend wants to swap manual clutch setup, 465/205 into his 90 3/4 4x4 burb with a 400 and vss. I told him that I would love to help, but I have never done this swap. I have done the hydro swap and it was not too bad.
I am thinking the clutch linkage bracket could be the most pita thing to do. Any tips or pointers?I
Jsfucttruck is offline   Reply With Quote
Old 01-17-2018, 01:23 PM   #2
kwmech
Re: Manual 465 to 90v20 Burb q's
Pretty sure the square body still had mechanical linkage in 90. Find a truck with all the goodies under the dash and install.
what's going to happen to the existing transmission and t-case?
Old 01-17-2018, 02:26 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
I have that bracket. Let me find it and I can get some measurements for you. I don't think it would be hard to make from scratch.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-17-2018, 08:35 PM   #4
Jsfucttruck
I think the first yr for Hydro clutch for 83-84. I used a dually one as a donor for another swap. It was easier without the linkage.
The trans has no reverse. Not sure.
Old 01-17-2018, 08:43 PM   #5
Jsfucttruck
I appreciate it.
I have
465/205 early style
Pedal Assembly and Z bar linkage from pedal
a 78 k20 frame with a bracket and linkage
Early Flat trans crossmember and t case skid
He is offering up a 74 K20 350/465/205,with a Dana 44/14bff that runs and drives as a payment with current reg.
Old 01-18-2018, 10:55 AM   #6
68Timber
68Timber's Avatar
I misunderstood, I thought you were missing the bracket. When you said it's going to be the worst part of the swap, you meant locating the bracket on the new frame?
John
74 Honda Z50 build
Old 01-18-2018, 07:24 PM   #7
v30crewcab
v30crewcab's Avatar
85 is first year of the hydro clutch.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-19-2018, 01:08 AM   #8
Jsfucttruck
I have a bracket. I meant getting the bracket on. Would one have to lift the body off the frame a bit to drill the mounting holes?
Old 03-10-2018, 09:55 PM   #9
Jsfucttruck
Well my bud decided to stick with the manual setup. Potentially down the road, he is considering the Novak hydro retrofit.
He dropped it off a few days ago and since the weather is shot and we are still amassing parts. I most likely won't start for a few more weeks. This will give me the time to get some needed parts ready.
So, what I have.
465/205 10 spline input, twin stick rails, 30 spline front output.
Pedal assembly with z bar and brackets.
What I need to get for the swap
465/205 bolt in floor hump(optional & needs to be cut out)$80
Clutch kit #04-902
Flywheel for the newer crankshaft #lwf201
Starter. #Ns3838
Vss conversion for the 205 output. Behemouth Drivetrain $300
Driveshafts. $800-1000
Now there has been some discussion on weather or not he wants me to just leave the column in park and not wire in a clutch start switch.
He wants to just leave it, but he has little boys... I think I am just going to wire in the pedal switch. I would hate to hear about it later and someone got hurt.
Pretty nice looking truck, I actually had the opportunity to get this burb before my bud got it. It was for sale for $400 with no moving gears. He put a vacuum modulator on it and got forward gears only.
Old 03-10-2018, 09:59 PM   #10
Jsfucttruck
And boom... Just like that. Everything is on hold until I find out if the headers will work with the mechanical linkage.
Dang it.
I think they are thorely tri's.
Old 03-18-2018, 01:30 PM   #11
cal30_sniper
cal30_sniper's Avatar
They would work fine if you ran the factory hydraulic clutch setup for that truck.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 03-18-2018, 10:28 PM   #12
Jsfucttruck
Correct. He doesn't have the cash for it.
I found a whole 88 k5 donor, but he opted out.
He pays my time, so I let him decide. I tried to explain all the benefits. The blazer even had a tilt column and bench seat. It was mechanically sound with a rotten body. Guy was asking $1500. Even passed smog.
Old 03-18-2018, 10:30 PM   #13
Jsfucttruck
The owner said the headers had holes in them so he had planned to change them out.
Manifolds are on order.
