Old 03-19-2018, 07:35 PM   #1926
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Oh yeah! That looks so much better! TDI in the Jeep sounds sweet too!
Ryan
1969 Chevy milk truck
Old 03-19-2018, 10:14 PM   #1927
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
cheaaaaahhhhh
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-19-2018, 10:15 PM   #1928
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Always getting good ideas here. The playing card trick is a new one for me. Nice!
Truck looks really good....like it is lounging there on the lift.
Advanced Design is offline   Reply With Quote
Old 03-20-2018, 07:55 PM   #1929
lower50's
lower50's's Avatar
Re: My 52 GMC Build
That looks great!
Originally Posted by oldman3 View Post
Looking good there buddy...Jim
It's what it needed I think
Thanks I think so. Ya a few reasons for the TDI swap one is, where we go offroading is 170mi away and with my 4.3L I burn 10 gal so hoping it will be better. Also it will be cool.
Originally Posted by 99 to Life View Post
cheaaaaahhhhh
Yes sir
Glad to pass it on. Looks quite comfortable up there.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-20-2018, 09:04 PM   #1930
MIKESAD50
Re: My 52 GMC Build
That looks Awesome! Shop is great also.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 03-21-2018, 03:03 PM   #1931
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thank you!!
1951 MG TD
Old 03-21-2018, 03:24 PM   #1932
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So I have been working on improving the cooling of the motor over the past year. It never overheats just runs hotter than I like on the highway, due to the inter cooler blocking half the rad. I had made big improvements by blocking off gaps around the rad. So this round I cut out 4, 3" holes through the front cross member and sleeved them with pipe. Also cut down the angle iron that holds the bottom of the inter cooler. I figure I just gained 3" of unrestricted air to the rad.
Old pic
New pic. Just has to be painted and front trans cooler bolted up.
1951 MG TD
Old 03-21-2018, 04:08 PM   #1933
dsraven
Re: My 52 GMC Build
can you reposition that trans cooler to the frame side and direct air across it so it doesn't add heat and take away flow to the rad? some of the modern trucks have them behind the trans, in front of the axle
could you install some air directors in the holes you just made to direct air flow to the rad fins?
how about just reshaping the whole cross member to still support the weight and stress but not be in the flow path?
Old 03-21-2018, 05:31 PM   #1934
rusty76
rusty76's Avatar
Re: My 52 GMC Build
Looks awesome Bob. Man that’s one sweet looking ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-22-2018, 07:50 PM   #1935
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thank you for the ideas. Originally I did have the cooler back there, it did not cool well at all. I drive at 3-4" off the ground so no cool air. For the past 1.5 years the trans cooler has been below the rad (all good). On our 13hr trip south to Charlotte NC pulling our trailer last year I only had to shut off the cruse 3 times on the really big hills. So I'm just trying to give it a bit more cooling.
Thanks Matt
1951 MG TD
Old 03-22-2018, 08:39 PM   #1936
MIKESAD50
Re: My 52 GMC Build
What do you have for a fan shroud? Maybe some vents in it covered with rubber or plastic flaps that open with air flow while driving down the road?
Alot of newer cars have flaps of somesort to increase flow
1950 3100 5 window
Old 03-25-2018, 11:35 AM   #1937
piratexpress1369a
piratexpress1369a's Avatar
Re: My 52 GMC Build
So when will you test drive it to see the results
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 03-26-2018, 08:07 AM   #1938
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I have a 16" electric mounted directly behind the rad (no shroud). I have no issues below 50mph its only on the highway doing 60-70mph, I'm running 2-4psi of boost at that speed.
Weather looks good Wednsday, Thursday for a test drive, but I won't know until it gets above 20*C 70*f or so.
I have put 10,000 mi on the truck in 2 summers, so I think it will do what I need.
1951 MG TD
Old 03-26-2018, 09:02 AM   #1939
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So another thing on the list was respraying the rear fenders due to the clear coat flaking off. I took off the fenders and scuffed them and flat cleared. Turned out good.
1951 MG TD
Old 03-26-2018, 12:38 PM   #1940
Advanced Design
Re: My 52 GMC Build
Yes, those came out nicely. Nice lines too. Did you do those?
Old 03-27-2018, 07:52 AM   #1941
lower50's
lower50's's Avatar
Re: My 52 GMC Build
No my pin stripper (Petts) did them before. I just scuffed over them so I wouldn't loose them.
1951 MG TD
Old 03-29-2018, 07:54 AM   #1942
lower50's
lower50's's Avatar
Re: My 52 GMC Build
OH WOW the truck works better than ever!!!!!!
There obviously was a problem with my old hydro-boost because first time I hit the brake peddle I almost locked up the brakes and through my dog on the floor lol.
The new front rubber having a taller side wall rides so smooth.
My son and I took it out to an abandon building I have been eyeing up and got some pictures. Oh and did a few burnouts just to make sure.
1951 MG TD
Old 03-29-2018, 08:29 AM   #1943
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
so the new season begins!!!! looking good
Old 03-29-2018, 09:07 AM   #1944
OutlawDrifter
Re: My 52 GMC Build
New fronts and paint on the rears made a huge difference, looks great!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-29-2018, 12:08 PM   #1945
Coach529
Coach529's Avatar
Re: My 52 GMC Build
Love the new look......
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-29-2018, 05:03 PM   #1946
Dieselwrencher
Re: My 52 GMC Build
It looks just right now! That's nuts on the brakes. I bet your dog got a wake up call.
Ryan
Old 03-29-2018, 05:29 PM   #1947
rusty76
rusty76's Avatar
Re: My 52 GMC Build
Awesome. Looks really good.
My build thread
Crossmembers CC
Old 03-29-2018, 08:16 PM   #1948
piratexpress1369a
Re: My 52 GMC Build
Let's see the burnouts lol
63
Old 04-02-2018, 01:51 AM   #1949
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Yes sir Thanks
Thanks I can't believe the difference
Thanks. So do I
Ya I know. I grabbed him he's good lol
Thanks Dude
Oh I did several little ones that night, you know just to be sure
1951 MG TD
Old 04-20-2018, 08:15 AM   #1950
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Something fun. I finally got my cross walk sign working. Bought a flipping relay circuit board off Ebay. I have it switching every 30 sec.
1951 MG TD
bagged, build, diesel, gmc, hot rod
