1st start-up on swap
will start then die, will not idol for longer than 10-15 sec. but if I rev it up, say 2500-3000 rpm's runs like a top, motor just setting in truck, no 02 or maf sensors hook up,2000 5.3 thanks for any help
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
Re: 1st start-up on swap
VATS removed in the computer?
lt1 wiring did the harness said they did
meowMEOWmeowMEOW
Vacuum leak? Fuel Pressure?
What codes is it throwing? give us something to work with.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Does it run better without the MAF connected? If so, that'd indicate that your measured and actual air amounts are different. That could be air leaks or MAF placement if so.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Why are you attempting to run it without the MAF and O2 sensors installed and connected?
no codes,fuel pressure 58-60 lbs
maf was on a long tube took it off and put it up to tb and tape it up good,still start and die but give it a little fuel and let off it would idol everytime I would start it I would have give a little fuel hen let off before it will idol
motor is just sitting in truck,with core support and grill off wanting to make sure everything is ok before I put it back together, exhaust don't have 02 sensors in yet
I have a very hard time believing there are no DTC's with the MAF and O2's disconnected. I'd recommend finishing the installation before attempting to run the engine any further. Without the MAF and O2's, the EEC has no reference to calculate load and determine appropriate fueling.
