Old 01-14-2018, 01:01 PM   #1
Zook75
Zook75's Avatar
Tires and wheels
I know this has been covered some ware, but the quick and nasty, will 33-12.5-15 mud tires fit on the stock rims and will they fit with out rubbing on stock suspension?
Zook75 is offline   Reply With Quote
Old 01-14-2018, 01:45 PM   #2
Ski-me
Ski-me's Avatar
Re: Tires and wheels
Yes, I was able to get 33x12.5r15's under stock suspension. Just mount the front tire and check the clearance of the fender wells. If you hit a big bump while turning, you might get a touch of rub, but each truck is a little different.
Most tire shops will mount one to be sure it will clear the front area, before mounting the remaining 3.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 01-18-2018, 11:58 AM   #3
xs-style
xs-style's Avatar
Test fitting is the only way to know for sure. 33/12.5/15s rub on my fenders. I went ahead and got them based on the general online consensus that they fit... Now I'm looking for a small lift.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 01-18-2018, 07:02 PM   #4
Zook75
Zook75's Avatar
Had the tires mounted today. they look awesome and no rub. also mounted ne RS5000 rancho shocks and steering stabilizer.
Old 01-29-2018, 05:29 PM   #5
Zook75
Zook75's Avatar
Still got some items to address but she is a fun ride with the new shocks.
Old 03-27-2018, 04:31 PM   #6
stomper
Junior Member
stomper's Avatar
When I got my '83 it had 33/12.5's on the stock white steelies and no lift. They rubbed occasionally.
I'm assuming it has standard 3.07/3.08 gears with the 700r4. Because - What a dog! The trans fluid smells burned (not surprising). I put 235/75's on it right away. Hopefully the trans will last with a fluid flush.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 03-28-2018, 09:10 PM   #7
determined
They can be mounted on stock rims.
Will look kind of bulgy.
Clearance wise without any lift the rear will be fine.
On the front make a cut from the bottom up on the lip at the bottom front of the fender about 1 inch in and fold this portion up with a hammer.
You may think you have enough clearance now but the day will come when you will hit a bump with the wheels turned, you might get lucky and not cut your new tire up but you will fold up the fender lip with less finesse than if you cut it first.
determined is offline   Reply With Quote
