Old 04-12-2018, 07:16 PM   #276
roushinator
roushinator's Avatar
Re: Roushinator's 72 C10 Stepside Restore/Build
Trying to sort out the routing of my Speartech Wiring Harness. Going to try and hide the wires as much as possible
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 04-12-2018, 11:50 PM   #277
Trackman101
Trackman101's Avatar
None of my business but I would suggest using a Y and distribute fuel equally to both rails.
If your pump is not up to the task the last couple cylinders might get thirsty.
Trackman101 is offline   Reply With Quote
Old 04-13-2018, 09:46 AM   #278
knomadd
knomadd's Avatar
That would only change the location of which cylinders are thirsty, as you say. If the pump isn't up to the task, the pump would need to be changed.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-13-2018, 09:48 AM   #279
knomadd
knomadd's Avatar
Originally Posted by roushinator View Post
Trying to sort out the routing of my Speartech Wiring Harness. Going to try and hide the wires as much as possible.
Looks good Ryan! Might I suggest trying to run the injector and throttle body section of the harness under the intake? That might help conceal it a bit. Just a thought though.
-Duane
Old 04-13-2018, 10:00 PM   #280
roushinator
Yeah i'm going to do that. I am taking the intake off to get a Ceramic clear coating. So when i get that back i will do that.
Ryan...
Old 04-13-2018, 10:02 PM   #281
roushinator
I have a Boyd Welding tank with a In-Tank Aeromotive Stealth 340 Pump. I will double check to see if it good enough.
Ryan...
Old 04-15-2018, 08:48 PM   #282
roushinator
A little more progress....
Ryan...
Old 04-15-2018, 09:02 PM   #283
Hart_Rod
Hart_Rod's Avatar
Looks great Ryan!
Hart_Rod is offline   Reply With Quote
Old 04-16-2018, 10:13 PM   #284
roushinator
Originally Posted by Hart_Rod View Post
Looks great Ryan!
THanks!!
Ryan...
Old 04-20-2018, 08:43 PM   #285
roushinator
A little more work done..
Got my steps primed* and had my radiator core support painted.
Ryan...
Old 04-28-2018, 08:34 AM   #286
will69camaro
Awesome build!
That pump should be plenty for that setup.
As you said no need to change the fuel line routing. Mine deadheads same way and is a TT LSx427 making 1000+ (I have bigger pump obviously).
1969 Camaro - Protouring build, 427 LSX TT
1969 C10 - Cruiser build in progress
will69camaro is offline   Reply With Quote
Old 04-29-2018, 09:11 PM   #287
roushinator
Trying to get a little work done on either my truck, car or garage organization. Here is wht i did today...
Here are the custom badges. Dont know if this will be the final location. Going to wait until the fenders are on the truck before deciding.
Ryan...
Old 04-29-2018, 09:14 PM   #288
will69camaro
Maybe this has been answered, but I'll ask again cause i didn't see it. What radiator and fans are you running? Looking for something for a similar build in my C10 (LY6/6L90e planned). Want to be sure it'll stay cool towing!
Old 04-29-2018, 09:33 PM   #289
roushinator
It's an Entropy radiator.
https://www.entropyrad.com/1967-1972...uck-radiators/
Ryan...
Old 04-29-2018, 09:39 PM   #290
will69camaro
Excellent thanks. I've been looking at cheap (champion) and more expensive C&R. Just trying to figure out my costs for swapping.
Old 06-02-2018, 12:15 PM   #291
1enick72
1enick72's Avatar
I like the radiator mounts and brackets. Nice work on everything.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 06-02-2018, 09:50 PM   #292
cornerstone
cornerstone's Avatar
Any updates?
cornerstone is offline   Reply With Quote
Old 08-25-2019, 10:32 AM   #293
roushinator
Got rid of my cab and opted for another one.....
Ryan...
Old 08-25-2019, 10:35 AM   #294
roushinator
Here is some progress pics of the current one..
Ryan...
Old 08-25-2019, 11:00 AM   #295
KMC3420
KMC3420's Avatar
Cab is looking excellent. Is that Nsane doing the cab work?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 08-25-2019, 11:19 AM   #296
roushinator
Thanks. Yes.
Ryan...
Old 08-30-2019, 10:37 AM   #297
roushinator
Getting Closer...
Ryan...
Old 08-30-2019, 03:59 PM   #298
KMC3420
KMC3420's Avatar
Getting Closer...
Better than new! It will be nice to not have to tweak anything but adjusting your doors and fenders going back on.
Keagan
Old 09-03-2019, 03:58 PM   #299
Snake72
Snake72's Avatar
Wow, they did a great job on the metal work, cab looks fantastic
Snake72 is offline   Reply With Quote
Old 09-04-2019, 05:23 PM   #300
siggyfreud
siggyfreud's Avatar
Looking great. That motor looks MEAN AF. Can't wait to see this build progress!
siggyfreud is offline   Reply With Quote
