#51 |
Re: I Found the Magic Button!
If you check out the alignment thread in my signature I addressed swapping the upper control arms there. Everything you want to know should be there. Have you checked your truck over fully to verify you won't be cobering up some other issue?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#52 |
I gave up on alignment shops a long time ago. I just line up the wheels with string and go by eye and how it feels on the road. I shifted my LCAs forward 3/4 inch and have not noticed a bump steer problem. Seems to handle better. Also my truck does not have power steering.
#53 |
The bumpsteer problem can be remedied by swapping the outer tie rods to the bottom of the spindle. There are several good threads in this.
#54 |
I probably should have said specifically, I gave up on alignment shops (in my vicinity) Glad to see someone taking the time to figure out these trucks.
#55 |
It didn't take long to figure out the basics and do a bit of experimenting. Doesn't take much to get a better alignment. Seems like the hardest part is getting someone to work with you...unless you do it yourself.
#56 |
I researched the string method and found it works great and is really simple, are you familiar with it?
#57 |
I just use a tape measure to set toe to be good enough to get it to the rack.
I guess I should mention I am no longer a mechanic. I am now a Realtor so I don't have access like I once did.
#58 |
This explains it. Typically, our front tires stick out more than the rear, so just reverse the method.
https://www.youtube.com/watch?v=0sguZ-gRF9I |
#59 |
![]() Join Date: Feb 2004
Has anyone confirmed this? Where are said threads? I'd like to know for sure before I drill out the spindles😁
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#60 |
Here's one I have bookmarked: http://67-72chevytrucks.com/vboard/s...d.php?t=620584
72 C10 lwb fleetside -stock 350/350 combo |
#61 |
Yeah, thats the one I was going to post
#62 |
Lol, yea I'm subbed to that one, you can see my parts there. I'm not sure if I'm going to have clearance to install them. I was looking for more people with this mod. I don't agree with the OP's set up cause it looks like it will bind. Was hoping to find more than one person who has done it. I would think anyone with forward arms needs them.
#63 |
When I did the Caster Mod it didn't raise the end all that much but I need to take a second look when its back on tge road and ready for another alignment.
#64 |
Just chiming in... It can not be overstated how important it is for a front end alignment be performed by a Fully Qualified Mechanic. Following the Manufacturer's specifications for Caster, Camber and Toe on the front is as equally important as a proper alignment of the rear axle as well. The rear axle is singularly important with the Thrust-Line Measurement. This measurement ensures the vehicle tracks straight.
As stated above - a Fully Qualified Mechanic...
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993** My 1966 GMC Value Van Project 1951 GMC 9430 1-Ton I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day. |
#65 |
Good luck finding a "fully qualified mechanic". I was a BMW Master for 20 years. Most "qualified" people know "green is good" and "set toe and let it go". Its honestly a joke. Anyone can learn and take their time doing an alignment on their vehicle.
#66 | |
![]() Quote:
#67 |
At the body shop.
I'm about to try the lower control arm and lose the shim stack.
Maybe that will help center the wheel in the fender well.
" That didnt make it any newer " " Dont antique the equipment " |
#68 | |
I aligned my stock height C1500 years ago at about -.25 camber, +1.5 caster, and toed in a little bit. I could probably add a little more caster, but it drives fine as it is. If I decide to change it, I'll have to go get some shims. The shop I currently work for doesn't have any, even though some of the older vehicles we work on require them for adjustment. As far as doing an alignment without an alignment machine and rack, I think it could be fairly close, but definitely not perfect. Even slightly off can cause a crooked steering wheel, a pull, or tire wear. The best bet is to find somebody that knows what they are doing and has access to the proper equipment. |
#69 | |
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 04-15-2018 at 03:11 PM. |
#70 |
FOLLOWING
#71 |
And these are the reasons I started this thread. You don't have to go on the stock specs and shop guys don't know enough to know that. We already know 6 or 7° Caster is preferable but its hard to get there. The closer the better. -1° Camber is close to max. Those aren't even close to stock specs but if a guy knows it'll work on ANY car he wouldn't hesitate to align ANY car. When yhey won't touch a modified suspension you automatically know they really don't know much about an alignment.
#72 |
Ok so I’m aligning a stock suspension frame off on a 70 c10 and the specs call for +3-4 castor, +1 preferred camber, and a lot of toe in! So I’ve got the castor first then dialed in camber but thinking .8-.12 for total tow in. What’s y’all opinion? It likes to road wonder and requires a lot of attention when driving... Need this thing to go home next week.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#73 |
1/8" total toe (1/16" each side, toe out). Negative camber (1ish degree) as much caster as you can muster.
#74 |
x2
#75 |
Don't think too hard about it as long as your camber is negative and your camber is as positve as possible. Make both sides as equal as possible. If it keeps wandering rotate the tires until tire pull is minimized.
