Old 04-18-2018, 09:43 AM   #1
jfnar
Sagging master cylinder
I'm trying to finish up my disc brake upgrade on my 68 gmc but keep running into challenges. I found yesterday that the booster is very close to the holly 4 bbl carb on the 292. My brand new 10" air cleaner will interfere and I'll have to modify the throttle linkage. I have a plan for those issues. Next I noticed that the booster/master cylinder assembly is sloping down toward the front. I don't know if that causes any problems with the functionality but I would prefer for it to be level. Should I shim the mounting bolts at the firewall to level it up? Any other suggestions? Thanks.
jfnar is offline   Reply With Quote
Old 04-18-2018, 11:08 AM   #2
B. W.
B. W.'s Avatar
Re: Sagging master cylinder
It's mounted correctly. They all run down hill for some reason.
B. W. is offline   Reply With Quote
Old 04-18-2018, 11:35 AM   #3
jjzepplin
jjzepplin's Avatar
Mine is 3/4 ton and is very similar in angle.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-18-2018, 11:48 AM   #4
jfnar
Thanks for the input. It looks a little sad but as long as it works I'll leave it alone.
Old 04-18-2018, 01:36 PM   #5
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I just had a disc conversion done on my 68, and my new master cylinder is a mile from the firewall now! No clearance issues with the breather because I put a smaller one on there.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 04-19-2018, 05:52 AM   #6
panhead59
By the way- Those stock brake lines will bend and fit nice if you're REAL careful. I just did mine. Just bend and don't twist. Good luck. Go slow and it'll work!!!!
panhead59 is offline   Reply With Quote
Old 04-19-2018, 11:05 AM   #7
demian5
demian5's Avatar
Only thing I don't like is that if you have any slight issue with the gasket for the cap, your frame rail is swimming in brake fluid.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-19-2018, 11:30 AM   #8
un4gvn!
un4gvn!'s Avatar
Contact Captfab here on this web sight. He makes a bracket that eliminates the factory bracket that holds the booster to the firewall. My booster was close to the valve cover. By using his bracket, it lifts the booster away from the cover and it's more level. It also moves the booster closer to the firewall. By the look in your picture, it should move the booster back away from the carb.
un4gvn! is offline   Reply With Quote
Old 04-19-2018, 12:13 PM   #9
Bigdav160
Bigdav160's Avatar
If you keep it "as-is" there are two additional support bars that you seem to be missing.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-19-2018, 05:09 PM   #10
cleszkie
cleszkie's Avatar
Is that really how the Holly mounts to the manifold? I'm not used to seeing a carb in that sideways orientation. If it where turned 90 degrees it sure would provide more room for the booster. If all else fails, swap in a hydro-boost unit and get rid of the chunky booster.
cleszkie is offline   Reply With Quote
