rear view mirror gauge problems
mirror gauge for the comp and outside temp not working , how do I fix?
Re: rear view mirror gauge problems
Check temperature sensors in the front of the truck to make sure they are connected. What exactly is it doing?
1969 Chevy c20(Miss Hackjob) |
ok first it would flash on and off the function weather temp of compass. I went through the procedure to reset and it was ok for a while then goes out . I pulled it and disassembled it thinking loose connections and appears ok. at this point it is not bright and barely able to read
