Old 05-18-2018, 05:01 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Drum to disk from a donor truck. What parts?
My buddy has an 8 lug front disk truck and I have a 4 drum 8 lug truck. Hes hooking me up with the front disk and parts.
What all do I need to put the front disk setup on my truck?? Thanks.
desert-rat is offline   Reply With Quote
Old 05-18-2018, 06:30 PM   #2
demian5
demian5's Avatar
Re: Drum to disk from a donor truck. What parts?
Just ask for the front cross member with the suspension still bolted on it.
What year are both trucks?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-18-2018, 07:53 PM   #3
palallin
Best scenario: park the donor next to the donee.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 05-19-2018, 12:30 AM   #4
desert-rat
Mine is a '69. I forgot his, but I think his is a '67. I'll have to fined out.
Old 05-19-2018, 12:31 AM   #5
desert-rat
That's another idea. I'll park them togethers and see what we got.
Old 05-19-2018, 03:52 PM   #6
zicc1835
zicc1835's Avatar
take the MC and the proportion valve and the whole front crossmember out do a complete swap brake lines an all ......trust me that the easier way
zicc1835 is offline   Reply With Quote
Old 05-19-2018, 04:25 PM   #7
davepl
davepl's Avatar
I took the whole front crossmember except the crossmember itself, if that makes sense. In other words, everything attached to suspension and crosssmember except the crossmember.
And if you've got room, by all means, take the crossmember!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-20-2018, 07:59 AM   #8
zicc1835
zicc1835's Avatar
x2 what he said take it all.....
Old 05-20-2018, 11:08 AM   #9
kenr74
Is swapping the whole cross member still the way to go if you are changing spindles?
I'm in the same boat but doing drop spindles also.
kenr74 is offline   Reply With Quote
Old 05-20-2018, 08:55 PM   #10
zicc1835
zicc1835's Avatar
now thats not just a yes or no answer what year? are you doing drum to disc? ball joints are not all the same
Old 05-20-2018, 09:05 PM   #11
kenr74
I have a 69 C20. Picked up a 71 C20 front end. Was going to swap it but I am rethinking that. Seems like I could do the tie rod and ball joints while I have the 69 apart and not do the full swap.
Old 05-20-2018, 09:11 PM   #12
zicc1835
zicc1835's Avatar
yes sir much easier .....
Old 05-20-2018, 09:15 PM   #13
kenr74
Easier to NOT do full swap? I am leaning that way since I am taking so much apart to do spindles anyway.
Old 05-20-2018, 09:23 PM   #14
zicc1835
zicc1835's Avatar
well you have 6 grade 5s on each side of the engine cradle( if my memorey is right) and that will seperate it from the frame take lots of pictures of brake lines and anything you may be changing beteween the years .....brake lines are different 71-72 vs 70 and down brackets that hold the rubber brake lines are on the front of a 71-72 on the back of other years brake lines up to Master are different too
Old 05-20-2018, 09:27 PM   #15
kenr74
Makes sense. Sorry for the hijack.
