05-25-2018, 09:14 PM | #51 |
Re: My Chevy 1500 W/T 94 V6
05-26-2018, 08:08 AM | #52 |
What kind of boat you working on DP?
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
05-26-2018, 08:37 AM | #53 |
The truck cam out great. Glad someone else likes the ole V6
05-26-2018, 01:50 PM | #54 |
05-26-2018, 01:51 PM | #55 |
06-19-2018, 01:57 PM | #56 |
another little update installed a nice addition hitch brake and rear light LED combo looks fantastic on truck.
06-19-2018, 04:00 PM | #57 |
i had a issue with stop lights not engaging, and i lubed the piston going through firewall
waa la the brake lamps work flawless now. these year of trucks its a known design issue. other thing to check is stop lamp switch, and of course your fuse. so anyone else having brake lamp issue try this fix. |
06-19-2018, 04:03 PM | #58 |
Glad you are still getting to do things on the truck. Thanks for the brake tip. I'll probably forget it before I need it though
06-24-2018, 03:26 PM | #59 |
got tool box back on polished , tip for anyone else , used rubber padding on outside edges on bed and lined inside with padding to reduce vibration noise.
next up is polishing the alloy rims. |
06-24-2018, 03:32 PM | #60 |
new bright orange led lamps installed keep it authentic like from factory.
06-24-2018, 04:25 PM | #61 |
Looking good!!
No bolt or nut in the world will remain tight if you turn it to liquid!!! |
06-25-2018, 01:14 AM | #62 |
Here's the alloy rims, started wet sanding them to a high shine finish.
06-25-2018, 07:43 AM | #63 |
Those came out nice!
06-27-2018, 04:44 PM | #64 |
thx and they are not even polished yet either.
07-11-2018, 06:33 PM | #65 |
on the final stages of polishing rims, the product am using is mothers alloy rim polish and protect, its amazing guys.
09-30-2018, 11:37 AM | #66 |
got the decals all on and edge sealed , same as factory with the addition of 4.3L vortec decal on tailgate compliments it nice.
side doors have 1500 decals and chevy symbol. looks fantastic. |
09-30-2018, 11:41 AM | #67 |
https://www.amazon.com/sealitpen-Sea.../dp/B000FT56OQ
highly recommend applying decals with the wet method, soapy water , this allows you to move the decals around on painted surface , takes a few hours to dry, wipe clean gently then you can apply seal it pen edge sealer to decals, this extends the life of your decals. |
09-30-2018, 11:46 AM | #68 |
next task is final light polish for alloy rims then installed.
09-30-2018, 02:29 PM | #69 |
Looks great!
09-30-2018, 04:31 PM | #70 |
thx bud..
11-22-2018, 12:09 AM | #71 |
nice pick of truck warming up cold morning chu chu..
11-22-2018, 12:10 AM | #72 |
decided to take tool box off going with a cover later date and low profile box soon.
12-23-2018, 10:10 PM | #73 |
another little sweet upgrade some mud/water spray flaps for my truck, fronts installed...helps reduce road tar and paint chip as well.
12-25-2018, 12:19 AM | #74 |
Nice!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
12-25-2018, 01:19 AM | #75 |
thx bud..
