Old 03-05-2017, 02:31 PM   #126
Kevin McPherson
Kevin McPherson's Avatar
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Thank you, sometimes I miss the big things because I am looking for the fine print!!
Kevin McPherson is offline   Reply With Quote
Old 03-05-2017, 04:54 PM   #127
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by SS Tim View Post
Kevin, While a 67 GMC could have a 14 digit VIN, the 12 digit VIN on your 67 Chevrolet Suburban is correct and clearly so !
As was indicated it breaks down as,
K Conventional Cab 4x4
E V-8 engine (base 283 in your case)
1 10 Series 1/2 ton
6 Suburban
7 1967 model year
Z Fremont California assembly plant
156477 Unit serial number
Additional SPID coded information
Paint code 451 is Medium Blue Poly (metallic) code 506, applied as a two-tone with a code 526 Ivory roof.
Model number KE10916 confirms it to be a 4x4 V-8 1/2 ton Suburban with tailgate.
Curious as to what would the other 2 digits denote if there was a 14 digit serial number on a 1967 GMC?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-05-2017, 05:39 PM   #128
SS Tim
SS Tim's Avatar
Its not that simple,
In a nutshell the big differences are an added GVW range as a suffix, two digit wheelbase, two digit model and a four digit serial.
To see the differences clearly just go to the begining of this thread and compare the 67 GMC to the 12 digit 67-71 Chevrolets. In 72 Chevrolets used a 13 digit VIN with an added maunfacturer digit.
SS Tim is offline   Reply With Quote
Old 06-02-2018, 11:23 AM   #129
Joerg
Junior Member
Joerg's Avatar
Can anybody help me to decode this vin?
1C154L113981
its on a 60 Apache, here in Germany.
What I found:
1 = 1961
C = 2WD
15 = 1/2 ton
4 = Pickup
L = (found Los Angeles but not for this year)#
113981 = ser. number 3981, but that be?
Could this be real?
thank you for your help.
Joerg.
Joerg is offline   Reply With Quote
Old 06-02-2018, 12:37 PM   #130
bruceman1968
bruceman1968's Avatar
1C154L113981
What I found:
1 = 1961
C = 2WD
15 = 1/2 ton 127'wb
4 = Pickup
113981 = ser. number 3981, but that be? Serial numbers started at 100001 with the first truck. So your truck is number 13981 off the line.
Could this be real?
Joerg.
Joerg, I also have L=Los Angles in 1959. But I can't find L in 1960 or 61. sorry, I'll keep looking.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 06-04-2018, 02:27 AM   #131
Joerg
Junior Member
Joerg's Avatar
Thank you for the information.
I have a title which shows built in 1960 but the vin says 1961.
Can you explain how this works?
https://photos.app.goo.gl/RN7dwK3aTkBuMW2K2
regards
Joerg.
Old 06-04-2018, 09:29 AM   #132
bruceman1968
Jogre, that's pretty common. 1961s were built from August 1960 to July 1961. So a early 61 build is often titled as a 1960. Or if a late build sat on the lot till 1962, and then sold it could get titled as a 1962.
Old 06-06-2018, 03:27 AM   #133
Joerg
Junior Member
Joerg's Avatar
Thank you for this information.
Joerg
Old 06-07-2018, 02:14 AM   #134
Joerg
Junior Member
Joerg's Avatar
Another question. How can I identify the colour, engine and tranny of this old one?
Old 06-07-2018, 06:52 PM   #135
bruceman1968
Joerg, Start a thread in the 60-66 section. Here's a link.
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=6
The guys in that section can answer your questions better than me. Also ask them about your L= Los Angeles assembly plant code. And don't forget to include a pic of your truck. They love pics.
Old 06-08-2018, 12:53 AM   #136
Joerg
Junior Member
Joerg's Avatar
Thank you, I'll do after it arrived this weekend...
Old 09-11-2018, 07:31 PM   #137
preciador6
Can anybody help me to decode this vin? PB1001NC2 For a GMC Value Van 1965 I think
preciador6 is offline   Reply With Quote
Old 10-03-2018, 11:37 AM   #138
BERT1972GMC5500
Hello All
I have a 1972 GMC 5500 grain truck and want to know if its a 3 ton or a 5ton
The vin is TCE53WV508362It is a Canadian truck with a GVW of 20000-24000 lbs
BERT1972GMC5500 is offline   Reply With Quote
Old 02-21-2019, 10:47 AM   #139
iriereggaeman
iriereggaeman's Avatar
I made the discovery today that my '72 burb has two different VINs. One on the glove box, one on the door jamb. I imagine this happens from time to time as these old vehicles use parts from donors to be restored?
I guess my question is which is more accurate? Any opinions?
VIN =
glovebox: CKE162F145864
door: CKE262F143439
C = Chevy
K = 4WD
E = V-8
1 = 1/2 ton | 2 = 3/4 ton
6 = Suburban
2 = 1972
F = Built in Flint Michigan
145864 | 143439 serial number
iriereggaeman is offline   Reply With Quote
Old 02-21-2019, 11:29 AM   #140
Travisarmenta
Travisarmenta's Avatar
VIN =
door: CKE262F143439
C = Chevy
K = 4WD
E = V-8
6 = Suburban
2 = 1972
Attachment 1877854
Attachment 1877855
Hell of a SPID,
6 LUG OR 8 LUG?
Door jamb is probably correct
Have you verified the rear axle has a locker in it? or front?
I really want to believe that the person typing up the VIN on the SPID was just extremely hungover and screwed up, but there are too many numbers off.
Shame really because that's a highly optioned truck.
I hope its just a mistake.
Travisarmenta is offline   Reply With Quote
Old 02-21-2019, 12:08 PM   #141
iriereggaeman
6 lug. The front wheels have locking hubs. I guess I don't know how to tell if the rear differential is a locker.
Old 02-21-2019, 01:56 PM   #142
Travisarmenta
Glove box door may be correct then, 1/2 ton.
Post more pics, looks to be a nice truck.
Old 02-21-2019, 05:11 PM   #143
iriereggaeman
not my pics, but photos of my vehicle posted by others (before my ownership in 2011) I have made some mods since purchase
https://www.youtube.com/watch?v=SZHcWFrI1AQ (private owner selling the old girl)
and
https://www.mecum.com/lots/SC0511-10...olet-suburban/
(Mecum listing that didn't apparently reach reserve.)
Old 02-21-2019, 07:00 PM   #144
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
VIN =
door: CKE262F143439
Look for the VIN on the frame. Driver side rail up by power steering pump. There may be one under the cab as well but thats hard to see.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-26-2019, 04:10 PM   #145
Balto Bob
Still looking for one that includes the bigger trucks. EM 4640M C1303D Cowl and chassis like for a school bus (this is a linen truck)
Balto Bob is offline   Reply With Quote
Old 06-25-2019, 10:16 PM   #146
eengledow
Getting ready to buy a 1972 GMC Sierra Grande, the vin is
CE234-S132178
Reading the decoders the 4 in CE234 should indicate Model year.....this is a 1972?
eengledow is offline   Reply With Quote
Old 06-25-2019, 10:20 PM   #147
jocko
jocko's Avatar
CE234-S132178
No, that VIN indicates a 70-71 GMC 3/4 ton fleetside 2WD V8 truck.
Old 07-04-2019, 11:37 AM   #148
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Bruce this is a great resource I've relied upon many times. Thank you.
I'd like to add that Blazer VINs for the 1969 model year begin with "B". Here's a link to an example on the K5 SPID thread (where several others are documented): http://67-72chevytrucks.com/vboard/s...&postcount=370
EDIT: Is there a chance you know the assembly month for a 1971 model year Blazer assembled in Flint with a sequence number of 654572? Prior to 71 all K5's were assembled in St Louis and I'm curious in what month Flint began K5 assembly. As I don't see many 71 Flint K5s I suspect is was later in the model year.
Old 07-04-2019, 01:48 PM   #149
bruceman1968
Deadhead, thank you for the props. We're glad you are finding the decoders useful and very pleased at the number of people that have found the resource useful.
We knew about the Blazer VINs when we put the decoders together but left it off to save space. It was just the one year and only on Blazer models, so we figured not enough affected to include it. We kept to the essentials so that the characters and boxes could be as big and readable as possible. We also left out things like the starting sequence number of 800001 for the 1969 model year and 600001 for the 1971 model year. But your absolutely right, First year Blazers had a B for Blazer as the first Character of the VIN.
As far as your 654572 Blazer build date. Lucky it's a 1971. I can only do this for 1971. Any other year and we would have to do it the hard way. Checking blue door stickers, Engine date codes etc. against the VIN number in a made/collected database. But for 1971 I have some documentation from GM that helps a lot. Your Flint Blazer 654572 was built on assembly line 2 on June 17th 1971 give or take a day or two. I estimated the date. All I really know is that the last light duty truck built in flint, line 2, in May 1971 was 649411. And the last LDT built in Flint line 2 in June 1971 was 658369.
Hope that helps and thanks again for the props.
Bruce
Old 07-04-2019, 02:07 PM   #150
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Amazing! Thank you sir! Confirms my suspicion. I'll keep an eye out for additional 71 Flint K5s but of those so far documented (total 4) all were assembled in June of 71. Perhaps a trial run ahead of the 72 MY when Flint figured prominently in K5 production.
