06-04-2018, 04:01 PM | #51 |
Re: Eric's 1966 Turbo 6.0 build
any updates on the truck? Love the build, and ill be going turbo at some point, so any more pics would be great! The truck is looking awesome!
06-14-2018, 08:45 AM | #52 |
We need updates!
06-14-2018, 09:09 AM | #53 |
Picture dump in progress! Final hood, doors mockup done. Disassembled the bed. I planned on re using the cross members and front panel, but decided to replace them when Brother's Trucks had their spring sale going on.
06-14-2018, 11:08 AM | #54 |
So far the hood has been Primered and Blocked twice. we ended up finding some imperfections after the first coat. Beyond time consuming but knowing that most body shops would have stopped 2 steps earlier keeps me going. I'm gonna be afraid to drive this thing!
06-14-2018, 11:27 AM | #55 |
This is the bed assembled. perfectly squared and front panel DP epoxied and bolted in for good. The rear crossmember is also bolted, welded and epoxied.
I modified the tailgate with parts from s chevy colorado. I modified the tailgate to accept the half circle part that makes it so you can remove the tailgate without taking the hinges off. ( like the newer trucks). Added Mar-k stainless straps and latches. Filled the holes in the gate where the chains were before. |
06-18-2018, 11:11 PM | #56 |
Awesome! Im building my 66 with an LQ9 turbo. I just joined and will start a build thread. Keep up the good work!!
03-13-2019, 04:26 PM | #57 |
Back From my Long Hiatus. Gotta get this thing caught back up! cut and reinforced the core support for the intercooler and piping
03-13-2019, 04:36 PM | #58 |
Perfect timing! I was planning to do the same this weekend. Thanks for the idea.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-13-2019, 05:10 PM | #59 |
Mocked up my boost gauge/ heater control panel. Also rebuilt the 12 bolt. 3.73 auburn posi. bigger yoke for the 1 piece drive shaft
03-13-2019, 05:13 PM | #60 |
Had someone come to my shop and Sandblast the cab. Luckily we found no more rust!! I then Epoxy primed, seam sealed some of it and used Defender bedliner on the bottom and lower firewall
03-22-2019, 02:29 PM | #61 |
Looks killer!
03-22-2019, 02:41 PM | #62 |
Got my frame back! Poly bushings in the trailing arms, Some CPP control arms. I also bought a rattlecan of the paint I want to use and just had to test out how it's gonna look on the cab.
07-18-2019, 11:39 AM | #63 |
Summer Stinks. Too Many weddings, Family functions to get any C10 work done. I did get the Cab Coated on the inside. Inside is also blocked and ready for paint!!!! As a side note I'm doing some work for a friend's truck. He pulled it our of a field in Georgia so I'm trying to make it drive able for the summer.
07-18-2019, 11:35 PM | #64 |
60-66 Nut
Looks good. What brand of bedliner did you use?
07-19-2019, 02:07 PM | #65 |
USC Defender Pro From my autobody supply place. Shot really well and seems super durable, definitely not the cheap stuff!
https://www.autobodytoolmart.com/usc...r-p-19147.aspx |
07-19-2019, 04:03 PM | #66 |
Is the turbo exhaust going to run outside the frame and out back, or a hater pipe through the fender, or what?
I've got to plan out the same on my '61, and I'm looking for ideas. Thanks!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-19-2019, 04:29 PM | #67 |
goes through inner fender and planned on running down outside of frame and just dumping it out the side
01-02-2020, 11:45 AM | #68 |
New Year, New Update. Long Story Short, WE found out my shop Dog Charlie has ( had) cancer in his jaw. As we prepared for the surgery and many months of taking care of him, I decided I wanted to give him a great summer just in case. Sold My lifted K20 and picked up a 73 c10. Not the prettiest, but solid for Ohio. 383 th350. Did tons of burnouts and went to all the car shows this dog could handle.
01-02-2020, 11:48 AM | #69 |
Once 5 teeth and the upper jaw were removed, and we had him stitched up 3 times ( Stubborn Dog) he was given a clean bill of health. SO I got busy the last few weeks......
01-02-2020, 11:52 AM | #70 |
AS of Now I'm fighting decision paralysis. I can finally start assembling and the " where do I even Start" Mentality is kicking in. So I'm taking lots of small bites and taking my time and hoping it adds up to progress. Next big job is the American Autowire harness and The Holley Terminator to wire.
01-10-2020, 03:59 PM | #71 |
I'm just glad to be here!
Sounds like Charlie had a very cool summer! Good to hear he got a clean bill of health.
Small steps always is a good way to move a project forward. Pick a task and complete it, even if it is just putting in a light bulb or two.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-10-2020, 04:31 PM | #72 |
Great build man. Definitely follow this one.
Posted via Mobile Device |
01-15-2020, 10:09 PM | #73 |
Little Bit of Progress: Made a mount for the Aux Trans cooler and started on some Hardlines
Battery installed radiator installed ( coming back out) Intercooler Gotta change my crank pulley to a smaller under drive to fit my turbo oil drain. I swear I checked clearance the million years ago it seems I mocked it up... 2 steps forward one back I guess!! |
01-27-2020, 11:33 AM | #74 |
Looks good! Its so annoying that this forum doesn't straighten out the pictures (iPhone?)
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
02-02-2020, 06:23 PM | #75 |
Progress so far:
Sound deadening and high hump installed Made an overly complicated bracket for mounting the Dakota digital stuff and slapped on some fancy blue plug wires |
