06-14-2018, 05:00 PM | #1 |
Re: Crusty Rusty Leaky Squeaky 67 Step
If the oil mist/film is on the drivers side, check the oil cooler port that you've probably put a bypass cap on. Mine has a small leak because the damn factory metal "gasket" doesn't work very well. I may end up putting some "right stuff" on it later. I don't know if it would contribute to a whole quart of oil going unaccounted for. Otherwise, pull your throttle body and check the inside of the intake for a film. The catch can might not be working very well. Grasping at straws here, but hoping it might spark something to help you find the source.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-15-2018, 04:02 PM | #2 | |
I finished up the plumbing and tested the lines and the regulator. It came preset at 61psi from Aeromotive. Only had one small leak in the lines and tightening the fitting a bit more fixed that. I cranked the engine over and it fired on the first try. Not only that, but it's fired instantly each subsequent time. With the vacuum reference line hooked up, the fuel pressure drops to 55psi with the engine running. If the regulator works like it's designed, the fuel pressure should approach 61psi at full throttle. The serpentine belt still squeals like a pig, but it's on my list of things to fix. Time to get busy putting a few things back together for a change.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
