Old 06-17-2018, 07:37 PM   #1126
mikebte
Re: What did you do with your truck today, Part 3
Finished the battery mount. Side post to the rear. Cables run down the back and down the firewall.
mikebte is offline   Reply With Quote
Old 06-17-2018, 07:42 PM   #1127
MARTINSR
MARTINSR's Avatar
You better mount that battery straight or all the acid is going to run out!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-17-2018, 07:47 PM   #1128
mikebte
Brian
Your not kidding. This is driving me crazy. Wont post an upright photo.
Old 06-17-2018, 07:51 PM   #1129
MARTINSR
MARTINSR's Avatar
Now it's correct so my joke is stupid. LOL I rather have joke wrong than your picture so cool!
Brian
1948 Chevy pickup
Old 06-17-2018, 07:52 PM   #1130
mikebte
You know you are working hard when you go into the house to have a shower and change into clean work clothes and go back out.
Brian
I get caught with the same issue. Not going to have any nice clothes left at this rate.
Old 06-17-2018, 11:24 PM   #1131
evilokc
drove the death rattle all day. I fall more in love every time I drive it. I didn't get any work on the truck done. I did clean out the garage which will lead to better work later on. well I guess I did a tiny bit of work if you count prep/research. I took the new a/c bracket out and held it in place and went over the directions while looking at the motor. I already knew I was going to have to move the fuel line over a couple of inches but I will also have to cut the alternator bracket spacer to allow the a/c compressor bracket AND the alternator bracket occupy the same mounting hole the on the head. that means im going to have to get a bolt that matches all of the a/c compressor bracket bolts for the alternator. I believe I found a winner though. its supposed to rain all week here so maybe I will get some work done during the week.
evilokc is offline   Reply With Quote
Old 06-18-2018, 02:28 AM   #1132
MiraclePieCo
MiraclePieCo's Avatar
I went to an antique swap meet and even though it was a non-automotive event I miraculously found a set of inside door and window handles for my AD, and a pair of tail lights.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-18-2018, 10:09 AM   #1133
MARTINSR
MARTINSR's Avatar
Now that's cool, and probably at a better price. I plan on running 53-55 Corvette tail lights. I have one I bought years ago and now all I am seeing are pairs of them on ebay...for the $500-900 range! Repro lenses are even $125! So being I have the one I need to get another and I just bought a rough as hell bezel for $40. We will see what I can do with that and then will only need the lense.
Brian
1948 Chevy pickup
Old 06-18-2018, 11:45 PM   #1134
mikebte
Tested all my gauges for proper operation, installed a rheostat behind the dash for final brightness configurations.
Old 06-18-2018, 11:46 PM   #1135
evilokc
okay.. I got out to start on my compressor bracket. I didn't get as far as wanted. mistakes were made along with messes. I had to lay my alternator to the side. easy. then I started following the installation instructions. the first step is to grind a small area. did it. install the cradle on the top water pump bolt. done. remove 1st manifold bolt. done. here is where it gets messy. I needed to remove the heater hoses from the manifold and water pump just to have some room to move. coolant everywhere. its a disaster in my garage. got that handled. the bracket sits just about right but I have some more work to do. I need to make 2 spacers and make sure my belt lines up. the good news is that the bracket will work on top of my alternator bracket. im stoked about that.
Old 06-19-2018, 12:39 AM   #1136
MARTINSR
MARTINSR's Avatar
I was BEAT today at work, fell asleep in the lunch room! And I love my five minute a day plan, that's all I was going to do, clamp the seat riser in to place, that was it. Well, I got it all welded and ground and the front brackets welded in, it's done!
I then went out for a 2+ mile walk!
Brian
1948 Chevy pickup
Old 06-19-2018, 04:57 AM   #1137
MiraclePieCo
Raised my truck on jackstands and had my wife step on the brake pedal while I spun the wheels. My brakes are now fully functional!
Between the faulty proportioning valve, adapting GM hoses to Ford calipers, and the inevitable leaks, what an ordeal these brakes have been!
Old 06-19-2018, 12:50 PM   #1138
jweb
jweb's Avatar
First drive after the new paint.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 06-19-2018, 12:59 PM   #1139
mikebte
Dang, That looks good.
Old 06-19-2018, 01:13 PM   #1140
MARTINSR
MARTINSR's Avatar
So cool!
I remember reading an article in the old "Rod Action" magazine back in the seventies about taking that first drive and how all the busted knuckles are forgotten. I wish I had a copy of it, it was really well done.
Brian
1948 Chevy pickup
Old 06-19-2018, 01:22 PM   #1141
robertsjm711
robertsjm711's Avatar
I really like that color
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 06-19-2018, 01:51 PM   #1142
jweb
jweb's Avatar
So cool!
Brian
Well I can't claim this as my first drive that would have been '06. I pulled it out of my parents yard in '05 when my dad passed away. It had sat for 25 years in pieces and I had it driving a year later. I've had it together (and apart) many times over the last 13 years.
Also my first ride in this truck was as a newborn, my parents brought me home from the hospital in it back in '78.
It did feel pretty good taking it out on Father's day.
Old 06-19-2018, 01:56 PM   #1143
jweb
jweb's Avatar
Thanks, I'll be in your neighborhood this weekend. There's a vintage trailer rally up at Riverbend Campground. The whole campground will be full of vintage trailers and there's an open house on Saturday if you're interested.
I'll have my truck and camper there.
Old 06-19-2018, 02:10 PM   #1144
MARTINSR
MARTINSR's Avatar
OMG that is so awesome it's crazy! I have a license plate off the 50 Olds I came home from the hospital in 1959. Wish I had the car but that license plate is a treasure of mine.
Brian
1948 Chevy pickup
Old 06-19-2018, 11:21 PM   #1145
oldman3
oldman3's Avatar
jweb, cool truck and great story...Jim
oldman3 is offline   Reply With Quote
Old 06-20-2018, 01:38 AM   #1146
MARTINSR
MARTINSR's Avatar
I had a meeting for work 50 miles away that was 3 hours of mind numbing crap, got home after 10 pm and got out to the garage for my five minutes! I punched and drilled holes in the cab and in the panels I am welding in at the cowl at the bottom of the hinge pillars. WHOOO HOOOO!
Brian
1948 Chevy pickup
Old 06-20-2018, 09:56 AM   #1147
MIKESAD50
Looking very nice, great color and story.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 06-20-2018, 09:11 PM   #1148
mikebte
Started my wiring tonight, guess this counts as my 5 minutes.
Old 06-20-2018, 09:22 PM   #1149
idbeast
My 5 minutes was to go pay for the PPG paint, over $1000/with tax for a gallon of paint and nothing else.... and I need 1 1/2 gallons minimum!
idbeast is offline   Reply With Quote
Old 06-20-2018, 10:08 PM   #1150
Black_Sheep
Black_Sheep's Avatar
You work pretty fast!
Black_Sheep is offline   Reply With Quote
