06-25-2018, 11:21 AM | #1 |
Pusher Fan Recommendations
Want to add some airflow help to my 81. All I currently have is the factory clutch fan and fan shroud. Would like something to help with the condenser air flow. I think Mississippi & Louisiana heat is a little much for the factory setup to keep AC efficient and cool things some.
Thanks all.
06-25-2018, 02:15 PM | #2 |
Re: Pusher Fan Recommendations
Mines not a pusher but I put dual fans on mine....I got em from summit...I know they've got a huge selection to pick from both pull and push...just have to measure and see what'll fit...
06-26-2018, 08:36 AM | #3 |
You will end up blocking air flow with a pusher fan, and the factory clutch fan.
Humidity in the south kills capacity of your account. Try taking your hose, and flushing out the condenser coil + radiator fins. Verify the charge is correct after you clean the condenser. |
06-26-2018, 06:42 PM | #4 |
I ran a pair of 9 or 10 inch zirgo fans on my condenser. it will freeze you out. they are on a relay that runs when the a/c is on. works great in Louisiana, as I am down that way alot.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
06-26-2018, 07:24 PM | #5 |
It would help a lot to seal the gaps around the condenser to the radiator,so the air goes thru instead of around them.
And,it should still have a factory rubber seal at the bottom between the rad and condensor. Mike. |
06-26-2018, 10:22 PM | #6 |
Is yours a 5 or 7 blade fan?
06-27-2018, 07:22 AM | #7 |
All above is good suggestions . Are you sure your clutch fan is working proper . You may think so and all looks ok but those things will fool you and not be working to its capacity . Before I did anything I would put a new clutch fan on before I added a fan . If the clutch fan is not working like its supposed to a added fan is just a band aid .
