![]() Join Date: Jul 2016
Another perplexing question as I continue to install AAW (American Auto Wire) & Classic Auto Air in my '67 Chevy C20.
Its coming along OK, (see pictures,) but not quite sure how the rear body harness exits thru the firewall, or where, and then back down the Driver's side (left) frame rail? Most of the wiring has been completed from these pictures now; all that is really left is a bit more in cab to sort-out and connect (radio, speakers, dash cluster), the relays for electric fans, & front & rear lights.... But could use some feedback on this question. For some reason I thought it went back like the cab light & fuel gauge wiring under the sill plate and out that corner of the cab. But memory is like the color that faded in my grey-white beard. ![]() I tried to find something with a picture or explanation of this, but had no luck. Any helpful feedback is appreciated. ![]() |
All about them K’s
![]() Join Date: Jun 2014
Re: Best Routing for Rear body Wiring thru Firewall?
From the factory It comes out the firewall below the wiper motor, near where the oil pressure line comes thru the fire wall.
Edit: this should help. http://67-72chevytrucks.com/vboard/s...d.php?t=766775
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#3 | ||
"I ain't nobody, dork."
There is a 4 wire plug next to the oil pressure line on the fire wall. The plug is a grommet as well, and the rear harness plugs into it and then runs along the drivers side of the transmission tunnel and then cuts over to the drivers side frame rail under the cab. Then they terminate to another 4 prong plug/grommet at the rear that the rear harness plugs into.
Gary
AWESOME Feedback, thank you thank you thank you!
