Old 07-02-2018, 11:01 AM   #26
mrtoni
Re: post photos of backup camera
Where'd you find that toggle switch plate? I want one that looks old for overdrive, winch, lights. Matt
mrtoni is offline   Reply With Quote
Old 07-02-2018, 07:27 PM   #27
ricklaplante
dash manufacuring
dashman.net
$70.00
ricklaplante is offline   Reply With Quote
Old 07-04-2018, 05:17 AM   #28
Green Monster
Green Monster's Avatar
Originally Posted by ricklaplante View Post
on the one i installed the screen is a little to small i will show some photos as soon as i take one
ricklaplante- Nice work and thanks for sharing. I agree that the image on a single DIN receiver looks small when compared to modern double displays but it is an added improvement to mirrors only.
Where is your camera mounted? Can you share a photo of the camera mounting setup too?
Green Monster is offline   Reply With Quote
Old 07-04-2018, 04:29 PM   #29
ricklaplante
Old 07-05-2018, 09:40 PM   #30
ricklaplante
camera is mounted on the plate no very good picture i think i will be looking for a little better one but have a few other things to do first
Old 07-23-2018, 07:54 PM   #31
Green Monster
Camera version 2.0 pictured below.
NOAUKA IP68: CAM01($12.99)
https://www.amazon.com/gp/aw/d/B06XN...op_mb_pd_title
Still need to connect wires to the head unit (monitor) to determine if this new camera offers an improved viewing angle. The new camera angle will likely not be impacted by the glare from license plate light.
The camera will need to be taken as part and lens rotates 180 degree since the camera mounting post is designed to be mounted vertically, not horizontally as shown here.
Old 09-16-2018, 07:46 PM   #32
Green Monster
To correct the upside down image issue. I opted not to take the camera apart but instead mounted it on a horizontal surface as designed instead of a vertical surface as originally photographed.
Old 09-17-2018, 08:43 AM   #33
Some nice clean camera installations here. I never thought of buying one myself, after spending my life adapting and using safe backing practices. I find no fault in others who feel the need. I hate getting backed up over or having my vehicle hit because someone can't back up. My girlfriend's solution is try to never have to back up. She certainly could use a camera.
So anyway, here is a picture of my backup camera, just for fun
Old 10-22-2020, 07:35 PM   #34
Green Monster
FWIW, it's been years since I initiated this project, but I finally installed the camera in a location and position I'm happy with and completed wiring. Here is the result. The dash was already cut to accommodate a CD player by the previous owner otherwise I would have kept it stock.
Rear view visibility over the rear bench seat and spare tire on a Blazer is limited therefore this has been a tremendous improvement.
