#276 |
Re: 69 Olive Verde
Interior wise I still need to build my speaker kick panels, adjust door panels, and do some custom floor mats.
Exterior is just tail lights, bleed brakes, Finish engine covers, and put tub back in. Then alignment, ac charge and I will probably repaint wheels (few chips during the build process).
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#277 |
Re: 69 Olive Verde
Post plenty of pics of the kick panel build, Im probably going to build some for my truck this next winter.
#278 |
Re: 69 Olive Verde
Here's a shot of the speakers and lighting. Sorry I didn't do any build pictures I was on a role and didn't want to pick up my phone.
#279 |
Re: 69 Olive Verde
Wiring to 69 c10 using:
Advanced Key System AK-PSB06 AAW harness with only 4 wire ignition switch Battery RED, Ignition PINK, Neutral Safety PURPLE, Starter/ ACC BROWN LS Swapped truck AUTO trans (not sure if I would run remote start on non fuel injected motor or any manual transmission.) This is nothing more then the way I installed mine on my particular truck build, using push start, smart key entry, remote start. Push-Start Module All jumpers left on default for alarm and remote start function through 2nd module 8pin Main Harness Pink- N/A White - Purple neutal switch Red - Bat 12v at ignition switch Blue - N/A Green - Pink ignition wire Black - Ground Red - Bat 12v at ignition Yellow - Brown Acc/ starter wire 10pin Accessory Harness Orange - N/A Gray - N/A Black - Ground (if you have a functional neutral safety) Purple - to second module Pink - N/A Brown - signal out on your brake light switch Yellow - engine tach signal Second Module (Jumpers left on default) 8pin main harness Brown - N/A Grey - Front parking lights Grey - Rear parking lights Red - Bat 12v source Green - N/A (not running locks) Blue - N/A (not running locks) Black - Ground Purple - Horn 7pin Accessory Harness White - N/A per my application Purple - Push start module purple wire Brown - signal out on your brake light switch Blue - N/A per my application Green - N/A per my application Red - Tie into first modules YELLOW ACC wire at ignition I choose not to run shock sensor or rear antenna. The provided instructions are really well laid out in the installation manuals provided by Advanced Key So I highly recommend reading through every bit of it before beginning install.
#280 |
Re: 69 Olive Verde
Hope this helps someone out. I know every vehicle will be slightly different depending on the specs, but maybe it will help trouble shoot.
My remote start did not want to crank correctly until after complete installation which I am guessing had to do with tach programming during first fire up. But with the good step by step info in the manual I was able to reprogram it and remote start works flawlessly.
#281 |
Re: 69 Olive Verde
Finally stitched the material to finish my engine covers. Here's a few pictures of the stages. Only shot I didn't get was the 6061 aluminum strip I fit in the recess threaded and held in with button top allen head bolts.
Pattern matches the seats.
#282 |
Re: 69 Olive Verde
Amazing work as usual! Thanks for the detailed push button starting wiring for dummies. I think its basic enough for me to do it, appreciate it.
#283 | |
Re: 69 Olive Verde
Hopefully the wilwood brake fluid shows up tomorrow and I can finally finish up this build with a cruise. Last night I was able to run the truck in the garage (no brakes) for a while to build up temperature. I just sat in the truck listening to tunes with the air blowing watching the temp creep up. Finally...216degrees on the dot the fans kicked on just as we had programmed in the computer. No leaks, as temp fell back around the 208 mark. Apparently these all aluminum ls motors like those hot temps. I am planning on changing out my tail lights to the fesler lights but not sure if they will ever show up seeing how I ordered them in mid March.
#284 |
Re: 69 Olive Verde
Spent a few hours pulling wheels and detail cleaning chassis parts. Then got it in the sun for the first time.
#285 |
![]() Join Date: Feb 2011
Re: 69 Olive Verde
Sweeeeet!!!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#286 |
Re: 69 Olive Verde
Thank you. Just ordered fatter wheels and tires for the rear. The 255/40/20 20x8 looked lame from the back.
#287 |
Re: 69 Olive Verde
#288 |
Re: 69 Olive Verde
Got new rear wheels in. Time to do some painting.
#289 |
Re: 69 Olive Verde
Thinking I might do white letters on the tires this go around. Could be a neat contrast to the black lip and give it a little more race attitude. Thoughts???
#290 |
Re: 69 Olive Verde
I think that would look sweet with white letters.
#291 |
Re: 69 Olive Verde
Finally got brakes bleed...what a nightmare. Every single fitting leaked and I am absolutely positive I paid careful attention to good double flares and made sure every line seated as tight as possible when I assembled everything. But I guess when the fluid gets in there under pressure it allows gaps inthe fittings because I was able to tighten every fitting another turn, crazy. Luckily it's all good now.
Other brake issue was the pedal throw. The stock pedal arm bottom out quickly and required more throw to pump. So redesigned the pedal arm (which looks way cooler now) and made new push rod linkage for the booster. Good news is I actually got to drive it down the road and wow does it run and sound like a beast! Could not be happier with the power it is making. It flat pins you in the seat until you get off the throttle. Bad news: broke the end of the throttle cable at the throttle body right before puling in the driveway. Little redesign work and we will be good to go again.
#292 |
Re: 69 Olive Verde
New wheels got painted this afternoon. Man am I sick of painting when it's a 100* out.
#293 |
Re: 69 Olive Verde
Figured I would try on my extra wheels first. Only did half the tire before I got frustrated with the oil marker. Any thoughts...likes or dislikes. I really want people to know the truck means business but not take away from the clean look of the truck. Guess I'm going to have to sleep on this one.
Probably won't do tire size and just do brand and model.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 Last edited by builtbyKane; 07-25-2018 at 09:15 PM. |
#294 |
Re: 69 Olive Verde
I kind of like it, it ties into the white on your truck. I agree do brand and model only
#295 |
Re: 69 Olive Verde
Have to replace inner tie rods because they are not seating correctly, one of the final pieces from the last owner haha.
And here's the brake pedal I made to correct the angle and give it more throw on the bottom end before hitting the floor.
#296 |
Re: 69 Olive Verde
Got the new rear shoes on and it's first wash and wax today.
#297 |
Re: 69 Olive Verde
Few more.
#298 |
Re: 69 Olive Verde
Looks great.
#299 |
Re: 69 Olive Verde
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#300 |
Re: 69 Olive Verde
