Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 07-23-2018, 07:21 PM   #1
Roundhouseman
91 GMC LSX swap & 96 dash swap
After doing some searching and not finding allot of info on doing a dash swap, I document my conversion here. I purchased the 91 GMC C1500 for $500 a few months ago. It came with a 4.3l V6 and a manual trans. The truck has a dually conversion and is slammed, rear frame is notched and lowered spindles in the front. I pulled the engine @ a month ago and sold it to a friend.
Roundhouseman is offline   Reply With Quote
Old 07-23-2018, 07:25 PM   #2
Roundhouseman
Re: 91 GMC LSX swap & 96 dash swap
I removed what was left of the broken dash and cut out the steering column bracket.
Old 07-23-2018, 07:32 PM   #3
Roundhouseman
Drilling out the spot welds on the steering column bracket.
Old 07-23-2018, 07:45 PM   #4
Roundhouseman
Drilled out spot welds.
Old 07-23-2018, 07:48 PM   #5
Roundhouseman
The 91 (left) and 96 steering column brackets side by side.
Old 07-23-2018, 07:50 PM   #6
Roundhouseman
Welded in the 96 steering column bracket. I bolted it to the brake booster and held it in place using a bottle jack and a block of wood.
Old 07-23-2018, 07:52 PM   #7
Roundhouseman
91 and 96 steering columns are very different.
Old 07-23-2018, 08:19 PM   #8
Roundhouseman
I will be wiring up the 96 electronics to work with the 91 harness. Looks like I need to swap over to the 96 fuse panel though. The LS engine is a 03 5.3L with a 4L60e.
Old 07-23-2018, 10:57 PM   #9
Big Daddy Bear
Big Daddy Bear's Avatar
Cool, looking forward to more. Love following well-documented build threads!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 07-24-2018, 02:01 PM   #10
SCOTI
SCOTI's Avatar
Interesting..... I'm following as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-25-2018, 08:44 AM   #11
Interesting build. I am in for it also.
Old 07-25-2018, 01:09 PM   #12
Willie G
Nice Steve. I will be here until the project is finished.
Willie G is offline   Reply With Quote
Old 08-06-2018, 11:47 AM   #13
Roundhouseman
I had to go back to the junk yard and cut the section of the firewall out there the steering wheel goes thru. Keep in mind the Pick Your Parts do not allow you to take a cut off wheel/angle grinder in. I made it past the check in gate with mine and was able to cut what I needed and got scolded on the way out. Oh well, got what I needed.
Learn from my lack of paying attention to the details in the differences in the trucks. The 91 firewall opening has a oval hole and the 96 has a round hole that is flanged. I made some measurements and then cut along folds in the firewall sheet metal.
Old 08-06-2018, 11:49 AM   #14
Roundhouseman
On another note, this step would have been MUCH easier before I welded in the steering wheel bracket.
Old 08-08-2018, 10:19 AM   #15
Willie G
oming along pretty good. Keep it going.
